my winbonds :) :
bh-5 khx3000 256mb 257mhz 2-2-2-11@3.3v (i must check week)
bh-6 twinmos pc2700 256mb 253mhz 2-2-2-11@3.3v (4 chips 0307week, 4 chips 0308week) lol :D
all test's on dfi infinity; bypass, cpc etc on :D
my winbonds :) :
My bh5 vio 3.9v (vddr 3.8/3.9v) (We0313)
http://www.membres.lycos.fr/boblemag...cpumark340.PNG
http://stephen.mounioloux.free.fr/Ov...TA_BH5/BH5.jpg
307WE
i865PE : 2 2 2 5 (Dual) 260MHz (superpi) @3.75 V
http://www.all4amd.netfirms.com/ that is the ram that mushkin sold back in November2004. i need to remove the heat spreader and c what chips its got
256MB Infineon 6a BH6 233MHz 2-2-2-5 @ 3,0v @ DFI infinity
512MB Corsair XMS2705v1.1 BH6 240MHz 2-2-2-5 @ 3,1v @ DFI inifnity
*edit*
ups, week follow soon!
*edit2*
hmm, dont know, infineon 6a stickes are relabeled
Really nice sticks you got there, my German fellow :D
I am impressed what this Infineon is able to do!
4x256MB A-Data Winbond BH5 306we
227mhz@2.80v vdimm on Abit IS7 (i865PE) cl2.0 2-5-2-2 dual channel & PAT FULLY enabled
235mhz@2.85v vdimm on Asus P4P800 (i865PE) cl2.0 2-5-2-2 dual channel & PAT FULLY enabled
I've to do the vdimm on IS7 to supply higher voltage than 2.8...
I think that @3.0v vdimm these chips will "pass" 240-5mhz bus...
bye bye
Crim
EDIT: tested on an IC7-Max3
250mhz@3.1v vdimm cl 2.0 5-2-2 dual channel
KHX PC3500 BH-5 2x256mb
All chips in the first module are 314WE, the other module has 314WE on one side and 315WE :stick: (they are double sided).
LP NF2
2-2-2-11 3.3v 263mhz CPC Off
2-2-2-11 3.3v 255mhz CPC On
2-2-2-11 2.9v 230mhz CPC On
Greetings :)
why CPC OFF with 256 modules ?
woa! nice :D many new entries, thx a lot guys! :D
will update the db in a week or two when i have internet @home again :)
Got a couple of sticks for your most excellent database saaya :)
Corsair XMS PC3500 V1.1, 2 X 256 Meg (all BH-5)
Stick #1 - all 8 IC chips are '310WE' BH-5
Stick #2 - 4 IC chips are '310WE' BH-5, and 4 IC chips are '322WF' BH-5, the two sides of the stick are different :stick:.
322WF is an as-yet unreported stepping too - weird huh? :). If you want, I can take a picture of the chips to verify them. Although I can't really take a picture that proves that each side of the stick is actually different.
Anyhow, these two sticks do 260 MHz 2-2-2-11 in dual channel, with 24 hour memtest86 test #5 looping stability, at 3.6V of VDIMM, in my old DFI Ultra Infinity nForce2 board.
They could probably do a good ~5 MHz higher, if stability testing was only done with Prime95 ;) :D
I am also confident that they will do much better in an nForce4 board, with just a little more voltage :D
thx a lot felinusz, JuanFlaiter, Crimson_dAWN, arbiter, HermS and pershoot :toast: :toast: :toast:
SheeP, please at least post the stepping info from aida or cpu-z :)
zytrahus, 256 or 512mb? you got two sticks, right?
boblemagnifique, what manufacturer is that? 100% prime stable? :slobber:
MaSell, whats the full week stepping? i need the two letters behind the week stepping :)
ShadowScorpion, i suppose your using an nf2 board?
iddqd, i need the stepping infos ;)
thx zytrahus, results added :toast:
Hmm, I was sure that I posted the stepping in the previous post somewhere... but the BH-5 is 338WE. Don't remember what stepping BH-6 is, though.Quote:
Originally Posted by saaya
thx boblemagnifique and iddqd :toast:
added your results :)
Yes im useing an Abit NF7-Sv2
"thx a lot felinusz, JuanFlaiter, Crimson_dAWN, arbiter, HermS and pershoot"
;) :toast:
Special thanks to arbiter.He is my friend and I used his excellent memories in my fx55 benchmark studies. :toast:Quote:
Originally Posted by arbiter
http://forum.donanimhaber.com/upfile...z811754310.jpg
http://forum.donanimhaber.com/upfile...n364514142.jpg
My Corsair PC3500C2 2 x 256MB 3,72V.
http://www.weber-steuerungstechnik.d...ock/277mhz.jpg
what steppings are those chips? did you remove the heatspreaders? can you post the aida32 infos if you havent?
Everest/Aida/CPU-Z don't show me any information about that. :(
Maybe i take the spreaders off today or tomorrow.
Here we go. :)
http://www.weber-steuerungstechnik.d...corsairbh5.jpg
ohhhhh nice! its a special week stepping :D
Twinmos BH-5
1x256 -->304WE \ W942508BH-5
1x256 -->307WE \ W942508BH-5
http://img.photobucket.com/albums/v231/Fosco/27sek.jpg
This is with 3.8v
The best one did 282 MHz in a DFI 754
http://img.photobucket.com/albums/v231/Fosco/282mhz.jpg
Why special? :DQuote:
It's not 2432D .. it's 2452D ! ;)Quote:
week 45
"2432D" 2.0-2-2 3.70v 275mhz (corsair 3500 256mb@nf3)
