Originally posted by emtp563
Trying it with a different video card, in my opinion, is not acceptable. The Radeon 9700 is the fastest out there, there is no reason why anyone should have to "settle" for a slower card just to use this motherboard.
No one has to "settle for another card" to use this board, the board runs fine with this card at normal spec, if you are going to run it way beyond specs as we do...then it's up to you to make it work. I used my G4 Ti4600 instead of getting a new 9700 because of this problem, works fine.
