9800 Pro Luck of the draw
I haven't loaded rivatuner yet because the omega guy says it may have conflicts with his driver. So, at this time, I am stuck with overdrive.
If the chipset hadn't said r360, I wouldn't have flashed a new bios as it would run 412/365 stock. However, I had the r360 and thought it would be nice to get the few extra optimizations and overdrive from it. I am sure that the card was a refurb because it would not oc very well (414/385). But, I think it will do better once I get a better cooling solution on it.
I have a homemade water block that would fit, but my case is pretty full as it is, and it wouldn't take much to drill and tap an old Alpha PEP 66 that I have, plus I have a drawer full of heatsink material I can cut for ramsinks.
If it wasn't for the heat (and you can feel the heat a couple inches from the card) I would just keep it as a stock 9800xt for the 228.00 I paid. I paid 329.00 for my 9700 pro just last Febuary!
Compared to the 9700 pro (still a great vidcard), Farcry plays very smoothly with all settings highest and looks very sharp at 1024. With the 9700, I had to play it with medium settings with just a couple set to high.
I have gotten two refurb vidcards from newegg that "checkered" right off and had to send them back. One was an AIW 9700 pro, and the other (2 weeks ago) was a Sapphire 9800 pro 256mb "Ultimate", which, by the way, is NOT a rebadged XT. So I guess it was worth the rma as I would not have gotten this card.
I got lucky, this time, and am happy.
