Gettin' there
http://img17.imageshack.us/img17/1244/m9vx.png
Gettin' there
Weekend with Impact!
http://img543.imageshack.us/img543/5241/9mas.jpg
thanks Peter & TL:)
http://i.imgur.com/qM1BBdr.jpg?1
http://i.imgur.com/3wRnrVC.jpg
MFR time tonight, dat der valid!
today i started with XP32 and tested my Gskill TX 2666CL10 Samsung IC's on the M6E
CPU Water / RAM Air ALL BOOT straight from BIOS
http://i.imgur.com/Bq1Kfyc.jpg
4770K 4900HT / 2666CL10@ 3100CL13
http://i.imgur.com/IwSUBV5.png
4770K 4967HT / 2666CL10@ 2700CL9-12-12-25 1T tight
http://i.imgur.com/gBBGWj1.png
Cheers to all !
Sergio
This is in regards to a 4770K and a Maximus VI Extreme.
I must have a bad motherboard or at least a real dog! I will explain why I think this and let me know what you think.
I have had the same results with two different CPU's and two different ram kits.
The first ram kit was a G.Skill C11 2800MHz kit. At a 4.4GHz OC with the ram set to 11-14-14-35-2T / 2800MHz I can not pass OCCT AVX even with NB set at 3900MHz it either stops on error or BSOD's. If I change the ram frequency to 2400MHz it will pass with the NB set to 4300MHz.
The second ram kit was a G.Skill C9 2400MHz kit. At a 4.4GHz OC with the ram set to 9-11-11-31-2T / 2400MHz I can not pass OCCT AVX even with NB set at 3900MHz it either stops on error or BSOD's. If I change the ram frequency to 2000MHz it will pass with the NB set to 4300MHz.
Here are the setting in BIOS that I have changed.
MONITOR MENU -
ANTI SURGE SUPPORT: DISABLED
ADVANCED MENU - CPU CONFIGURATION
HYPER THREADING: DISABLED
EIST: DISABLED
TURBO MODE: ENABLED
CPU C STATES: ENABLED
ENHANCED C1: DISABLED
CPU C3 REPORT: ENABLED
CPU C6 REPORT: DISABLED
C6 LATENCY: SHORT
CPU C7 REPORT: DISABLED
C7 LATENCY: LONG
PACKAGE C STATE SUPPORT: C3
AI TWEAKER MENU -
AI OVERCLOCK TUNER: XMP
CPU STRAP: 100
BCLK FREQUENCY: 100
CPU CORE RATIO: PER CORE
Each core set to: 44
MIN CPU CACHE: 43
MAX CPU CACHE: 43
DRAM FREQUENCY: Confirmed this is set to XMP Profile 1 value
CPU CORE VOLTAGE: MANUAL MODE
CPU CORE VOLTAGE OVERRIDE: 1.21
CPU CACHE VOLTAGE: MANUAL MODE
CPU CACHE VOLTAGE OVERRIDE: 1.30
CPU SYSTEM AGENT OFFSET MODE SIGN: +
CPU SYSTEM AGENT VOLTAGE OFFSET: 0.300
CPU ANALOG I/O VOLTAGE OFFSET SIGN: +
CPU ANALOG I/O VOLTAGE OFFSET: 0.150
CPU DIGITAL I/O VOLTAGE OFFSET SIGN: +
CPU DIGITAL I/O VOLTAGE OFFSET: 0.200
SVID CONTROL: ENABLED
INITIAL CPU INPUT VOLTAGE: 1.88
EVENTUAL CPU INPUT VOLTAGE: 1.95
DRAM VOLTAGE: 1.65
CPU SPREAD SPECTRUM: DISABLED
DRAM TIMING CONTROL: Verified memory timing
Enter the DIGI+POWER CONTROL MENU
LOAD LINE CALIBRATION: 8
CPU POWER PHASE CONTROL: OPTIMIZED
CPU POWER MANAGEMENT MENU
ENHANCED INTEL SPEEDSTEP: DISABLED
TURBO MODE: ENABLED
ADVANCED MENU -
SYSTEM AGENT CONFIGURATION; CPU AUDIO DEVICE: DISABLED
NB PCIE CONFIGURATION;
Verified PCIe slot the card is installed into displays: X16 and the LINK SPEED dropdown is set to GEN3 for the 780
DMI LINK ASPM CONTROL: DISABLED
PEG ASPM: DISABLED
GRAPHICS CONFIGURATION;
PRIMARY DISPLAY: PCIE
IGPU MULTI-MONITOR: DISABLED
MEMORY CONFIGURATION;
MEMORY REMAP: ENABLED
MEMORY SCRAMBLER: ENABLED
So now I have two different CPU's and two different ram kits that will not run a 4.4GHz OC with the NB at 3900MHz with the ram set to its rated frequency, you have to lower the frequency by 400MHz to get it to pass and then it passes with the NB raised to 4300MHz.
At this point in time I do not know what else to do but RMA the motherboard.
Does anyone know if there is a setting that I need to change that I am not changing or do I just have a bad M6E?
Maybe my real question is:
Why will C11 2800MHz ram pass OCCT AVX Enabled with the ram at C11 2400MHz and at the exact same settings C9 2400MHz ram will not pass when set to C9 2400MHz, you have to lower this to C9 2000MHz to get it to pass OCCT CPU 64 Bits AVX Linpack Enabled?
Edit, well with a vcore of 1.23, CPU @ 4.4GHz, ram @ C9 2400MHz, NB @ 3900MHz I passed OCCT 64 Bits AVX Linpack.
Hopefully I can get this to pass with the NB set to 4200MHz or better yet 4300MHz with the 1.23 vcore. I can probably go to 1.24 maybe 1.25 with the AC turned down before my max core temps get to high while running OCCT.
my best time for now
http://i.imgur.com/NB8F801.png
http://i.imgur.com/FzYodr7.png
put some nice 6:15 :)
dropped down :)
4770K 49x 102.1 BOOT from BIOS on TT Water Xtreme / MEM 2721CL9-12-12-25 1T on AIR LB 7
http://i.imgur.com/eEfZyCk.png
http://i.imgur.com/fXtvrWj.png
http://valid.canardpc.com/show_oc.php?id=2887169
Cheers to all !!
Sergio
With a vcore of 1.28 I was finally able to get past the 3900MHz NB barrier of my M6E. I passed OCCT 64 Bits AVX Enabled with a 4.4GHz OC, ram @ C9 / 2400MHz, NB @ 4200MHz.
Getting acquainted with the little guy:)
http://i.imgur.com/BxjEX4N.jpg
http://i.imgur.com/x8m6syX.jpg
Looks good LS.
testing RTL & waza files with some MFR
no wazoooo
http://i.imgur.com/gwNObG9.png
wazooooooooooo
http://i.imgur.com/SGgeo3J.png
waiting for a pci e extender to mount the Ney Pro.
^Dumo you have inspired me, no time to wait for the extender, must do the opposite of flaccid and . . . . . . go HARD!
http://i.imgur.com/4vTxEe2.png
http://i.imgur.com/WSssHxR.png
M6E + TeamXtreem 2666CL11@ 3330CL13 :)
5075MHz HT / 3300CL13-15-15
http://valid.canardpc.com/2891664
http://i.imgur.com/nb0F9hu.png
im proud of this :)
Cheers to all
Sergio
this is a video i made to show you guys how easy to boot at the above settings :) hope you like it !
booting 5075Mhz HT 3300Mhz mem
its on my page u can visit it :)
https://www.facebook.com/AndressergioUruguayOC
or
youtube
http://youtu.be/EPAFO5wjGIQ
Looks like we have a winner, folks. I'd been enjoying the Gigabyte OC Force with the ease of high 4 DIMM clocking but the BIOS was lacking, especially when it came to memory profiles, etc. Tried the M6E once before, then AsRock Formula twice. Decide to give the M6E another go around. I guess it helps if you read the UEFI guide :doh:
http://i.imgur.com/cZ9spEB.jpg
Latency boundaries and Latency Compensator are my friends :)
Just a pic of my Pandora's Box.
http://i.imgur.com/4qcaFWh.jpg
My Hero review is live:
http://www.hardwarecanucks.com/forum...rd-review.html
Spent many hours with this board so if anyone has questions LMK!
