:cord:
I7-3770K is enough to hit 5k, the one i have there is running with a stock cooler, stock clocks and 0.85v. pulling about 75w~ :lol2:
Just found your post, Evantaur. I'd add my thanks to the list, but the link gives me a page load error just now.
Looks like I'd better break out those tubes of Coollaboratory Liquid Pro & Ultra that I bought a while back, and apply to my 2 3770Ks.
Any 4770Ks in the stats yet? It will be interesting to compare output/clock speed for the 4770K vs 3770K (vs 2600K).
And if there's an Android on there, he's lying :rofl:
The link works just fine for me at the moment.
And my 2600k and 3770 (non K) should be on there is a few days.
you can try http://nikita.tnnet.fi/~evntr/xs/
Thanks ET, but same problem. I actually saw that the URL you posted before redirects to there.
I found a workaround though.
A number of websites, including Skype, hate me.
I think it's because they insist on learning where I'm located geographically, and they use one or more brain-damaged geoip services that think I'm in the middle of the Atlantic ocean, or at the geographical centre of the North Amerikan continent, or whatever. My ISP is not hidden, and if they took the trouble to look up where that ISP provides services, they'd see where I am. And some geoip providers see me OK anyway, eg http://www.geoipview.com/ .
tnnet.fi would appear to be one of those sites that hate me. So why do they want to keep track of me (and you!). Maybe Edward Snowden could enlighten us?
Anyway, I just called in from Algiers, no problems. No problems calling from the peaceful Middle East!
4 of my 5 machines are on your list ("Rickjb") - near the bottom, but they're there.
And hopefully they'll be there all summer, crunching away at the same speeds in my non-airconditioned house, even if the official temp down by the cool breezy harbour heads north of 45 deg C like it did last year. (Meaning: so why do some Team XS-WCG members stop crunching over summer? Yeh, some have rigs that are so far overclocked that they'd melt in summer. If they back off the speed a little and the Vcore a lot, they could keep em crunching all year. It takes a very big extra overclock to make up for a couple of months offline)
Oh - so how did I do a quick teleport from Sydney to Algiers? TOR Browser
history is halfway there, you can now browse old results, also fixed some bugs that made site look like a slice of pizza on IE (if someone is actually using it)
- fixed some bugs
- added team info
- cleaned up a little
history page is next
thinking about doing the same for our other projects, like gpugrid and einstein@home and maybe milkyway@home
ooh, I like this page! :D
didn't expect to see this:
evantaur 1123048 1155 BS FDC Linux Linux AMD Phenom(tm) II X6 1100T Processor
:cheer:
The Lonely AMD :ROTF:
:p:
I had a 6h DT due to powergrid maintenance.
Was up there on 14th place before that though..
My 3770 is now on Linux. Lets see if that will get it back it to the 5000+. :cool:
we're talking RAC here. On a "new" Linux machine that will take longer than Sunday
It may take even a little longer. There is still some work on the Win7 install that I will have to finish.
tell me if the history page is bugging out, just added a line chart there
See the chart fine not sure if you intend me to be able to go back beyond the 10th yet ....if so, can't.
EDIT: just noticed chart shows November
http://www.lakecityquietpills.com/ph...9938409189.png
zooming to 1 day or 5 days is good but 1 month is as above
it seems to be bugged on Google's end...
https://code.google.com/p/google-vis...detail?id=1058
i think their months starts from 0 and ends to 11, if not it'll be bugged again when we hit January, anyways should be fixed now
there's no data before 10th, that's when i added team stats :)
Ah OK. I thought that the calender was indicating a start date of the 5th due to the bold print.
Nice work my friend.
Updated OP to point to Evantaurs site :up:
Evantaur,Quote:
Thanks for providing a revamped XS WCG top 40 chart. As stated bu OC, if you click on days prior to the 10th, for instance the 5th, you will get a top 40 chart for that day. Somehow there seem to be pre-10th data in your database.
You may wish to mod the Y axis point ratio of your graph to smoothen the peaks and valleys for relatively small total team point changes. Also, would it be possible to have and option to show all active XS WCG members instead of only the top 40.
Thanks again for producing a very useful tool, :up:
Jean-Guy
The i7-3770 isn't quite there yet, but the i7-2600k that I switched to Linux one day later made it already. Should be on the list tomorrow.
I love the amount of work Linux does and the points it's getting. :)
And the i7-4770k is getting close to after only 6 days.
Now I just hope the new projects that we should get this fall will do just as good on Linux.
Rob_B rank 29 :clap:
Evantaur,
What brand of Linux are you running with your 4770K & 3770k CPUs? Also can you provide the version and the edition if applicable?
Thanks,
Jean-Guy
