Originally Posted by
Miwo
That really is too bad s1nner. sorry you must have the worst of luck...
If its not too late, i would just return the cpu/mobo you got from AMazon. Like I said 3 months ago, it made zero sense to buy into FM1 right at the end of its life
I think Asrock's MVP was one of the later FM1 boards so i dont know if there are any besides you that actually have that board. Still the general tips and quirks probably still apply. Sticking with multiplier ocing on a K chip is about as easy as it gets. Avoid bclk ocing so it doesn't break AHCI... which you actually do want if you are running a daily build with a half-modern SSD. Llano doesn't get that hot until you start pushing volts.
My LLano @ 3.5GHz has been my daily gaming rig for about 9 months now. Pretty fun to mess around with, but its time for trinity in less than 2 weeks!
