I make wallpapers ;) how do you like?
http://img69.imageshack.us/img69/284...seba842005.jpg
well i am stuck at 106.7
i clock every 25mhz on dram
been trying for 107.8/107.9 to get 2300mhz
hmm the i/o skews seems to change when i change dmi A/B skews.
and the rtl thingy seems cant run anymore other than 14.
So... 16x/16x with NF200 has better performance than native 8x/8x???
Very nice seba :up:. Are you taking any requests on the wallpaper?
Personally I'd like one in 1920x1200 with just the RoG logo in the middle and not the board on the lower right. 2560x1440 and 2560x1600 would be nice for future-proofing as well.
-sf
There You go ;)
1920x1200 RoG logo only in the middle:
http://img831.imageshack.us/img831/5...inglero.th.jpg
2560x1600 RoG logo only in the middle:
http://img191.imageshack.us/img191/3...inglero.th.jpg
1920x1200 fixed.
Very nice again; (edit: thanks for the quick fix).
-sf
So you gonna allow people to download it/them and use as wallpaper, is that your plan?
Has anyone tried the latest/new BIOS? :) How is it compared to the recent 1101?
1303 best so far :)
my luck.. i buy P8P67 Deluxe B3 last week and i can run my Hyper 2133 7-8-7 @ 1.725v n 2133 8-8-8 @1.6v (24/7), this is my 2nd board that can run my hyper go to 2133, my first board was UD7 that can too... other board like P67 pro, Giga UD4 or Asrock Fatality failed to run my Hyper to 2133 :(
+1 for Asus P67 Deluxe B3 :up:
http://img861.imageshack.us/img861/6154/corsair.jpg
http://img638.imageshack.us/img638/3853/55ghz2133c7.jpg
1485 is out
http://www.kingpincooling.com/forum/...t=1041&page=14
Changed some memory stuff
added Memory timings:
I/O Latency + RTL Offset
can play with it with oc memory...
Hi
i show 1.38V CPU for 5000Mhz
but me have 1.45V CPu for 5000Mhz
how do that on maximus 4 ex ?
the P8P67 deluxe is better than maximus 4 ex ?
i have number on CPU : L101B540
Thanks ;)
Sorry for this being off topic but i have this board and a MM 10 slot pci case and would like to fit 2 Asus GeForce GTX 570 DirectCU II to run in sli recon they would fit ok?
they will fit but 1 will be in a x8 slot I believe
2x NF200 pcie will run SLI at x16/x16.
Both 470s are double slot and have a nice gap between card`s but the 2 slot card`s will be to close i think and will maybe overheat them.
Hi
i have a question for a choise (memory) on M4E
the best kit 2x4Go ?
corsair DOMINATOR GT pc 16000 cas 8 9 8 24
or
[ Ripjaws-X ] F3-17600CL7D-4GBXHD cas 7 10 7 27
thanks
What software do you guys recommend to stress-test the cpu?. I have been using Prime95 for ages now and want to use something else. Maybe something new "on the marked"...I feel that running small fft is just overkill and not beeing nice to me at all :D
Or is it still Prime95 wich is the main test software?
