Martin i know it wouldnt be fair for the san ace, but they really change when placed in a shroud.
Have you tried them with shrouds?
I noticed the noise level is the first one variable that changes noticable.
OR are my fans just tripping out?
Does Martin still have hair???
Can't help feeling that he will be pulling it out at the thought of re-testing with a shroud fitted :D
You make a valid point though ... when this is about sound and sound quality it is one possibility that must be investigated at least for a few of these even if only to prove or disprove the theory.
Shazza, good thinking there. Personally, I came to this wanting to know if there is a high speed (read performance) fan which would also be capable of being turned down when the rig is not being pushed hard. I am still looking for that one that overlaps the ap15 and Delta .....now just need to get another couple of fans to Martin.....and hope he is willing :up:
I like your workflow, that's a great decision process and example..:up:
I tend to use the "Listen blindly by matching up FPM only" video approach as well. In the end if you're deciding between a few fans, just get a couple of windows going on the videos and match up similar air flow levels and pause each video. Then simply play each video back and forth and simply listen blindly (close your eyes) and go back and forth between fans. I tend to be one that doesn't trust meters or instruments very well. Noise level is one thing we can quantify with a tool, yet it doesn't at all fit what is annoying, etc. The good ole...trust your ears first...forget the numbers for a bit method..:D
No, I only tinkered a little with shrouds, but I plan to do some of that after I get all the main shroudless testing done. I suppose I could try a San Ace if that's what you guys want.:up:
I only did one quick shroud vs. no shroud test with the yate, and couldn't really see any difference, but there are a few ways you could make a shroud. Do you bolt all the way through, or do you bolt the shroud to the rad, then the fan to the shroud to help isolate vibrations. Do you use grommets, or certain gaskets. The options are endless, and figured I'd save some of those tinker tests for last.
+1 on that. That's really where my next interest lies as well. Just trying to make sure my simple mind can comprehend all the data.Quote:
I'm really grateful to Martin for doing this, but also don't want to burn him out! For example, it would be fun to see how some GT fans that have been painted compare to the originals - but that might drive the poor guy over the edge ;)
I've could probably do that to my wonky GT15, but it's pretty inconsistent, so I could very well come back and tell you it's and improvement..:rofl:
Vapor said he's ok with my keeping these, so maybe I can try that at the end. It'll probably be kawasaki green or something like that though...:D
FYI, these are next on the testing short list, thanks to Old Chap for two more Deltas and RatDog for the bottom three including some more PWM options...:)
http://img684.imageshack.us/img684/4...ditions106.jpg
I think some of these detlas should dial down better than the previously tested VHE that ruled the high speed area..
I don't need any of the fans back :)
:lol: @ censorship :rofl:
http://media.onsugar.com/files/ons1/...ana.xlarge.jpg
So, how much space 25mm, 38mm, 50mm??? Yep I'm thinking of using fan frames.
Ultimately I suppose a duct from the rad with a fan at the far end.....
OK, I'll plan on doing a little shroud experiment run. I need to do one for the 140 vs 120+adapter controversy anyhow. I've got a few gutted 120 fans lying around, so I'll plan on running the San Ace120, yateSM with/without shrouds and maybe even try 25 vs 38mm or more depending on time.. Going to save that shroud work for later though, the new fans and PWM work is next in line.
30mm is about right? I'm using old 25mm fan frames though ;)
http://www.xtremesystems.org/forums/...d.php?t=193953
If you have the space for it:
push -> shroud -> rad -> shroud -> pull
High speed fans:
push -> shroud -> rad -> pull
Low speed fans:
push -> rad -> shroud -> pull
Looking forward to the test of the upcoming fans, think we will find the lower speed Deltas really closing the gap between the GT and the rest...
Martin thank-you so much for all your amazing work, I'm in awe of the time you're able to set-aside to help the community!
Coming back to this for the 1st time in months, only just been advised by a local retailer (aust) I pre-ordered with, that my AP-15's are available.
Apparently they've been ready to pick-up for many weeks!
I plan to read this latest round in it's entirety tomorrow, but as it's now 320am I must get some shut-eye.
Just wondering if anyone can summarise, is the AP-15 still considered the noise/CFM king, or is there a new contender or contenders?
How does the 2150 & 3000 RPM compare to the 1850, are either a better alternative IYO?
Perhaps the 2150 is not a substantive enough improvement over the 1850?
I have some AP-15's ordered as rad fans, but if the CFM to noise ratio of the 2150 or 3000 is as good, & one can still make them comparatively quiet (as needed)...
...then perhaps they're a better option?
Any thoughts/experiences greatly appreciated, thanks/night!
Thanks!
GT's are still doing very well in the 1000-1850RPM range, although it does have some quirks. I've had two AP-15's with resonance issues depending on the radiator, so some sound quality issues to be aware of. Below 1000RPMs, I think they are all fairly close (within the 3dbA "barely perceptible" range, so plenty of options to choose from at the low end.) 1850+, some of the newer Delta's are also performing similarly like the VHE which came out a good 5dbA lower in noise level than the next best high speed fan. Unfortunately, the Delta VHE is pretty much high speed only and don't like turning down much. This is why there has been alot of interest in exploring some of the other Deltas....hoping to find one that bridges the gap a little better. Plan to test a few more this weekend...
Unfortunately, it seems you're still always best off picking a fan that can run at or near 12V at your desired noise level if possible. Same goes for the GT family, no sense buying GT15s and undervolting them to 7V all day...the AP13 or 14 performs slightly better at slower speeds and has less of an issue with resonance.
In the end, I try not to get hung up on any one fan...none of them are perfect, and as noise always goes...pretty subjective. I tend to be one not to trust numbers or meters anywhere near as much as my own ears, and that's why I've put much of my time into recording the whole process. Trying to record it in the best video/audio quality that I can so you can do you're own review.
My suggestion will always be...let YOUR ears do the review.. Compare multiple videos and match up like air flow numbers, and see which one "sounds less annoying":up: Just don't put too much emphasis in the noise level numbers, I've been tempted many times to completely remove the sound level meter and just have the audio to listen to. I'm still just not very happy with the common tools we have to quantify "annoying sound"...but it is what it is..
As far as the higher speed GTs...I have no idea. I know some folks on OCNs air cooling forums managed to find them by special order through some Japan sites, but it looks like they are paying $60+ a piece for them and their subjective tests seem to indicate they were fairly loud... So until they become readily available, not much sense in testing them.
But, I'm always willing to try one (if someone wants to sponsor) until the wife kicks me and my test rig out of the walk in..:D
Yes, they're damn expensive :( like this "MEAN"-Typhoon. :D
http://i51.tinypic.com/27zw9ah.jpg
Shot with ordinary GT1850.
D1225C12BBZP-00 with rectifier ring at the blades for high speed.
Max speed : 5400 rpm , 150.1CFM , 1.14 Amp , 150 Pa / 0.6 inH2O , 50.5 dB,
Its the PWM version (4 wires) with minimum speed 1000 rpm at 0% duty cyle.
Non PWM part no is D1225C12BBAZ-00
It has the beastie CFM, imo one of the most powerful 120x25mm, 12volt fan and also has a very wide range from silent at 1000 rpm up to max speed at 50db that covers from mid to high cfm range while at 25mm thick.
I somehow doubt in GTs still being best above range of common varieties of them as well. After all, specific shape of blades can work well at specific range of rpm-s. In pics it looks rather unchanged for those extreme GTs. GTs shine in 900-1800 range, what's wonderful that it's most commonly used range noise wise (900-1400), below there are more silent fans, and i'm guessing - above aswell. I don't expect miracle of it being best everywhere. Imho 2000 and above fans with more fit for high rpm blade shapes should show better cfm/db ratio. Of course, i might guess wrong and someone can prove by real testing of those extreme GTs.
Yeah would be interesting to see if the high speeds D1225C might cope with the Deltas (AFB models).
I see B6=2150, B7=3000, B9=4250 & BB=5400
http://catalog.nidec-servo.com/digit...general/g_fab/
You might be able to get them trough:
http://www.cliffinc.com/products/fans/index.htm
What, a 5400 version, I thought the highest GT was 3000? Crazy!
I love that it's still got great RPM variability, & is still only 25mm.
Tempted to get 2x D1225C12BBZP-00 instead of 2x AP-15.
Then again they're prolly tricky to get hold of, & as-you-say, pricey.
Where did you get yours from?
Thanks Martin,
I'm using the MCR-X20 rev.2, it came with my H20-220 Edge kit, hopefully the AP-15 has no issues with it?
I'd definitely be interested in hearing more about these potentially more flexible Deltas you speak of.
AP-15's it is then I think....
As I'd be fine with running at or near 12v most of the time, so long as they happily volt down a bit with a controller if/when needed.
I also want to find the cheapest price for a 3000 (or higher) GT, buy 1x, & send it to you.
So if anyone knows the best spots to buy, please let me know!
D1225C12B7AZ-00 is 3000 rpm GT and is about $28 plus shipping from Japan
D1225C12BBZP-※ 00 is the 5400 rpm pwm GT and is about $53 plus shipping from Japan
Just one source checked for this.
http://translate.google.co.uk/transl...58%26prmd%3Div
Crap $53USD that is a lot for just one fan (I'm Australian), not sure if I can afford it...
Martin if you can give me your shipping address, I can work out how much extra shipping $ is required.
jalyst, that came from the site pointed by OldChap, and unfortunately they ship only to Japan. :(
