Yes I can :yepp::yepp::yepp::rofl:, however folding sheet-metal is a pita, remember I'm making plexi tops that's easy, just cut, drill holes tap the g1/4 in the plexi and the 4mm in the tc-4 block (I have those handy whatever the original thread is I :shrug:) make it work, but sheet-metal folding always carries the risk of tearing unless you heat the folds and that's the biggest pain right there, also the thicker the sheet metal is the stabler it will be, but a frame would be better, that means riviting or welding, which adds to the cost. As for standoff's the catch with that is that you either need to use thicker backing prepunch and I dun have the punching materials.
Just call me Jack (and no that's not my name :ROTF:)
But honestly I overextended myself financially, besides the arima boards which I bought with my x-mas money I bought another MB and a bunch of other things like HSS g1/4 taps (the ones I have are carbon steel HSS is better :D) memory for 1 of the arima's the cpu's for second arima etc. so I think I will have no money left after bills.
anyways that's about it for now
terramir
