does anybody has bootup shorting issue with ek backplate??
i thought they were attaching 480 blocks to teh PSU to overclock it
Definitely not M3x12mm thats for sure, my guess is M2.5x6mm with the guess part on the M2.5. The screws are 6mm though.
so anybody has a working ek gtx480 waterblock with backplate
the first batch came with the wrong screws for the backplate pcb
was given m3x4
now the website manual updated it to m3x6
hence y u see a lot of ppl only screwing the middle portion and the backplate looked bent
so anybody..??
already killed one card trying to solve that
OK, thanks for answering. If anybody hasn't mounted it's Koolance VID-NX480 yet, it's very easy to check up. If a M3-screw doesn't fit to the thread of the waterblock, it has to be a M 2.5 screw.
Its definitely not M3.
My TT 1500watt psu has been reliably powering my rigs for almost 2 years 24/7 :shrug: where do you get these facts? "thermaltake psus break down all the time" thats an incredibly stupid thing to say. it is one of the very few PSU that can power 3 480GTX's and an oc'ed i7 with ease.
Isn't that the 4th revision EK have made since release? that really isnt fair on the early adopters.. I do hope there sending out the correct bits to everyone who purchased one.Quote:
was given m3x4
Not to continue the whole PSU discussion, but "thermaltake psus break down all the time". I wasn't like they ALWAYS, it wasn't to be taken seriously. BTW, what do you guys think about EK vs Aquacomputers. I'm really liking the new nickel plated backplate of the EK way more over the "ugly" AC backplate. Why in the world did they have to bend it????
yes, just doesn't cover the fan hole.
Wait a sec, EK isn't "one of the best" performing blocks? They might not be first, but shouldn't they be at least 2nd or 3rd? BTW, you shouldn't be thinking much about the new revisions, I believe the only thing they did was include a rubber piece because some customers complained of cards shorting out.
And yeah, I was actually wondering whether the EK backplate would fit with other blocks.
All I've ever bought is Enermax, curently have had their Infinity 720W which keeps the case fans on for up to two minutes after shutdown. The power and stability of the Galaxy series is excellent! I'm looking at the Galaxy Evo 1250W unless people seem to think that's not enough power for future builds... I'm in Southern Orange County (CA) and it's 80+ right now at 3:15pm.
On another note is it important to keep the VRM cool for overclocking? I've heard keeping the VRM cool allows for better higher overclocks, but I tend not to believe everything I hear from just one source.
Have you sent an e-mail to Eddy about shorting?
I've just did asking if there's any risk as I have 3 of these backplates in my build which will run first time tomorrow or Wed and wouldn't like to ruing 3x 480s :shrug:
There was a problem with screws in first batch, I've sent a note & pics on it to Eddy and new screws arrived and manuals/stock have been updated with longer.
skinnee, I just noticed you're from Minny...me too!
Can't wait to see the results of the round-up!
well the distro i bought from is dealing with him.
weird actually he met him just a few days back in computex. eddy didnt mention at all to him about the screws.
so waiting for an answer
got another gc and testing with the block is fine.
since my loop is gc - cpu so the cpu and gpu compression barbs+45's with tubing is holding the card in place to prevent any bending etc. with the bottom tube ..the piump is just above it to also to keep it in place.
also those allen keys m3x12 screws.. he needs to caution ppl on how easy it is to stripped it.
the card that died just cant run 3d mode. with nvidia drivers.. when i took off the backplate and tried again.
with the backplate no boot. i didnt screw in the 4 sides for the pcb screws as i havent gotten the replacement for it yet.
So I've had a go at the problem, and it looks like:
1) There is a capacitor on the top of the card, in the middle, which has very long wires coming off the back of PCB.
When I checked my 3 cards, on 2 of them there was contact.
I suspect this could cause shorting so I've bent them
2) The 6 chips near middle 3 screws contact backplate but it would not cause shorting.
According to EK those chips were not on the reference card from nVidia which they used for the design of backplate.
Long term fix is additional channel during the milling
Short term is add PVC washer under each standof of the backplate
I'm very shortly doing the latter, fingers crossed :cool:
are all of these single slot waterblocks?
No, I would consider the XSPC, Danger Den, Aqua Computer and EVGA single slot out of the box. The others are just a little too thick and cross the plane into the next slot. According to my eyes anyway.
Does that mean, a triple-SLI-system with 3 GTX480 @ Koolance VID-NX480 is not possible/practicable because of the "thickness" of the Koolance-waterblock?
OMG, please tell me that this is not the truth, because I've just ordered 3 Koolance VID-NX480, which I want to mount with 3 EK-Backplates.
