I cant work out the fermi clocks section, can any one run trough what is what? Cheers
This Gainward card is great! Closing in on 21k Vantage, all air rig. I need some watercooling, we will see what the summer brings. As for % overclock it sure beats my HD5870 :D
Ill get another card as they are pretty cheap in Norway atm.
is there anyone here that have GTX 470 FTW bios ?
i know man I cant find it anywhere, not on mvktech not on tpu either.
Hi Oliver :)
Could you modify my bios for higher voltage please?
Also, I see that I have the 70.00.1A.00.02 - although you mentioned in a previous post that there were a newer bios which performed better. Is that a bios compatible for all GTX 480's, or? (I have the Zotac GTX480)
And one last thing: which version of "nvflash" do you use?
Thx tent
EDIT: I found a newer bios from techpowerup, so hopefully you could modify that bios for higher voltage :) (the .zip called: GF100M_Zotac.zip)
Just a note to everyone outside the USA planning on water cooling a 470 or 480, the only place you can get warranties on them at the moment is at aqua computers when you buy the ready built 470 or 480
set tointo MSIAfterburner.cfgCode:EnableUnofficialOverclocking = 1
or try this
mine wont go over 1.087 either.
unofficial overclocking set to 1
And the xtreme version dont either.
I got something wrong also. No bios mods here.
NOTHING except afterburner.
Also I have had crash to desktop in 2 different games. MW2 and BadCompany2
And the heat that comes out the back of that card is 'incredibly hot'
Maybe I need a new fan profile? My MSI 470 is really very, very quiet.
My old card (8800gt) was "so" much louder; I dont mind a little noise. I guess im gonna have to edit the bios.
Set the fan a little more aggressive, and run cooler. Is the crash-to-desktop due to heat?
It only happened after an hour or go heavy gaming.
BTW.. Texas is hot; my ac is running non-stop.
Edit: Fan Profile 'really' helps this card cool down. I'm gonna play now and see if it crashes to desktop.
wow my gpu 2 reached 105c while playing BC2. The fan was running at 80%
Just reporting my dead GTX480 here
It took some modification but I am now the proud owner of a pair of PNY GTX470s
Current clocks are 750/1500/1727. Seems the memory is more touchy on my cards than is the core clock which I found suprising.
Max load temp after TIM change is 86C* on Furmark.
When running 2 GTX 480s how much power will it need just for the 2 cards? I am debating to run either 2 HD5870s or 2 GTX480s ... This way i know what power supply i will need. Thank you
@Aedubber
A decent 850W PSU will handle your system with 2 GTX 480's just fine.
Thank you Sir, i know these cards draw a lot of power so i wasnt sure if i needed to up my PSU i have now which is a corsairHX850 .. Do 2 gtx480s outperform 2 HD5870s?
Yes. Very much so. Just google a few reviews, you'll see that SLI scales better than Crossfire, GTX470 SLI actually outperforms HD5870 CF in a few games iirc :)
OH ok cool, i was gonna go to the darkside and go to ATI cards but lol i been a nvidea user for a long time. Guess ill stick with 2 gtx480s
My friggin card now only works in safe mode. Been having issues since yesterday. Had to knock down my system clocks to 21x166 otherwise the dispaly goes blank on windows logo...
Should i treat it to some old school micro oven lovin, looks like it's dying and i got nothing to lose.
GTX 480 dead:
http://img541.imageshack.us/img541/4819/dsc02617.th.jpg
http://img12.imageshack.us/img12/9846/dsc02618c.th.jpg
Overclock to 950mhz (1.19V in softmonitoring)
We patched GTX 470 bios GTX 480 data (shaders/ROPs info) to the address used by the GTX 465 upgrade tool - vcard work, but shaders don't unlock =((
Seems like there is way too many cards burning up ... Looks like I'll have to put a hold on ordering gpu cards .. Might have to stick with the initial plan of running 2 hd5870s .
