Haha love the paint drawing.
Errr thanks for the link, NOT!
After trying to click on the ""Red Link"" and thinking to my self, this dam link is stuffed, I will have to let Kibbler know so I can find out the colour of the LCD.
It then slowly dawned on me that maybe it was a suttle hint that the Aquaero LCD was going to be RED :ROTF:
I knew it was late but after looking at the clock it was 2:30am, hu bugger me, it's time for sleep. :rolleyes:
Love the kitty feeder mod as well.
As to your comment about being able to work suff out in your head in 3D, I know excatly where your coming from, well maybe not so much when I am tired.
It was always easy to see which apprentices would make good tradesmen, just by watching how they worked stuff out and if they could do it in there head or not.
Unless their mechanically minded most people can't.
Double barrel
Just a small update now that I have the right QDC fitting, I've assembled the drain setup. Not much text to go along 'cos I figure the photos should speak for themselves.
http://farm5.static.flickr.com/4003/...1e0b6ce7_b.jpg
Btw those screws aren't final, I'm looking for my missing bag of M5 button heads. Also, maybe 1~2 more spacers to raise them higher off the floor.
http://farm3.static.flickr.com/2700/...2ec51f83_b.jpg
That's where/how the drain line forks from the pump outlet.
http://farm5.static.flickr.com/4068/...67e7581f_b.jpg
And here you can see how the drain lines are routed...more or less out of the way. Left drains rad, right drains res + rest of the loop. And HEADLESS AQUAERO full-frontal.
http://farm3.static.flickr.com/2767/...c83969f3_b.jpg
Thanks for looking! :)
A shocking full frontal shot on XS !!!
Great work, Kibbler. Those drains came out great.
Loved your last drain setup on the Pinnacle, Kibbs. Double Barrel Drain setup on Capella is looking to be just as sick :up:
I like the screws that are in there now :up:
Just paint them maybe? The shape compliments the QDC's quite well.
Definitely raise them up though. If they're anything like the larger QDC's you're bound to wiggle them and potentially scratch that gorgeous case :X
By the way, when did this get to 16 pages????
Good Idea for that, The Screws look fine for it.
awesome drain setup Kibbs!
I have to say I have been creeping on your work for a while now kibs, and I'm giving you my first post on XS because it is that good =)
100% awesome.
Wiring
First, my wiring diagram for the Aquaero + LCD. I used all red wires so they don't show through, which means I had to mark the pins different colors, so I don't mix them up. :(
http://farm4.static.flickr.com/3277/...46b056da_b.jpg
After crimping/soldering/sleeving 16 wires to the Aquaero, done! The end of that cable is an IDC, insulation-displacement connector, typically for ribbon cables. It was a real challenge lining up 16x24awg individual wires exactly for the connector to close properly, luckily in the end it worked. Reason I used this is because there is very little space between the top LCD and the top of the rad, IDC takes up less space compared to normal straight connectors. By the way the ziptie is temporary.
http://farm5.static.flickr.com/4053/...00371e19_b.jpg
Here's how I split up the 16 wires: 4x4.
http://farm4.static.flickr.com/3466/...d8092450_b.jpg
I put the Aquaero back inside.
http://farm4.static.flickr.com/3251/...868791f6_b.jpg
Some routing on the back.
http://farm4.static.flickr.com/3658/...3b7f0901_b.jpg
Uh oh does everything still work?
http://farm4.static.flickr.com/3310/...29b81529_b.jpg
YES!
http://farm4.static.flickr.com/3314/...aab7e6d7_b.jpg
Then I worked on some other things. I put heatshrink around a cable clip (left with heatshrink, right original)...
http://farm5.static.flickr.com/4049/...80670afd_b.jpg
And re-installed the drain fittings so the clips can grip tighter.
http://farm5.static.flickr.com/4017/...b430cda9_b.jpg
Then I took some photos for fun.
http://farm4.static.flickr.com/3509/...e5c0280e_b.jpg
http://farm4.static.flickr.com/3400/...4da8deae_b.jpg
Thanks for looking!
Awesome :D
It's the little things that count. :up:
Still loooking Amazing Cant wait fro final product
I can't see, this beautiful pics made me go blind :bows:
Good lord! :shocked:
I just caught up on your worklog Kibbs, you been a BUSY BUSY man.
The work is freaking amazing, just when I thought that my jaw couldn't drop any further, it kept going further and further down, probably would have went thru the floor if my jaw was incorporeal.
Looking at all that grade A work makes me green with envy.
Awesome stuff :up:
beautiful stuff bro. :yepp:
Where you been? We need MOAR updates!
Stealing the drainage idea, thanks Kibbs! :ROTF:
http://img3.imageshack.us/img3/9369/domonom.jpg
been lurking this worklog for a while, first of its amazing!:shocked:
second, where do hard drives go? :D
Hey where do you buy those clips that you're using... is there a mccmaster car part?
Very, very COOL mod
I love that res and rad combo. It looks awesome and the skills to get everything to fit perfectly is just second to none.
Hey thanks a lot guys. :)
Another small update
While waiting on a custom order (no names, let's just say this is absolutely the last time I do business with them), I made a small but significant change to the pump positioning.
http://farm2.static.flickr.com/1102/...37133407_b.jpg
I turned the pump top 90deg. That's 2mm clearance between the stop fitting and the side of the drive bay. Very close.
http://farm2.static.flickr.com/1023/...839a9e6c_b.jpg
Here you can see that I used a BP Q-plus fitting.
http://farm5.static.flickr.com/4069/...bdf29fc8_b.jpg
Before: I really disliked how bulky it looked. I hate having many fittings.
After: Much better. Leaner. Tidier.
http://farm5.static.flickr.com/4066/...392c1f59_b.jpg
Robertp this is for you, not yet finished though.
http://farm5.static.flickr.com/4027/...135a53b0_b.jpg
Removing the top bezel reveals the 140mm mounts.
http://farm5.static.flickr.com/4003/...c40d6312_b.jpg
Handy-dandy plate.
http://farm2.static.flickr.com/1438/...db02bf10_b.jpg
There you go. I left some stuff out but that's the general idea. Pretty simple.
http://farm5.static.flickr.com/4007/...4fd35bec_b.jpg
Dude that is Going to Look Crazy having it up there !
window mod the HDD!!!!
i think i love your case..
