http://i552.photobucket.com/albums/j...t/DSC_0310.jpg
looks great potii and railmeat, and welcome to XS potii! :D
here is my first attempt at watercooling
http://i471.photobucket.com/albums/r...Picture002.jpg
http://i471.photobucket.com/albums/r...Picture001.jpg
http://i471.photobucket.com/albums/r...Picture009.jpg
Here comes my 4th wc'ed rig- and yeah it's my favorite combo Li-Li + wc :yepp:
wc:
EK Water Blocks EK-Supreme LT
EK Water Blocks EK-FC4870 CF
EK Water Blocks EK-NB/SB 5
Swiftech MCP355
XSPC Laing DDC Reservoir
XSPC RS360
3x Yate Loon D12SL-12
Masterkleer 7/16"
D-Tek High-Flow 1/2" OD, black nickel
http://i399.photobucket.com/albums/p...F/IMG_2353.jpg
http://i399.photobucket.com/albums/p...F/IMG_2352.jpg
http://i399.photobucket.com/albums/p...F/IMG_2360.jpg
http://i399.photobucket.com/albums/p...F/IMG_2367.jpg
http://i399.photobucket.com/albums/p...F/IMG_2370.jpg
http://i399.photobucket.com/albums/p...F/IMG_2387.jpg
Greetings Xtreme members.
First Watercooled build and image post ever.
Koolance case
KT400 Dragon Ultra MB
Athlon XP 2200+ (The good 'ole days, for me at least)
Centon 512mb (Don't remember the speed rating)
MadDog Radeon 7200
80gb WD System Drive
60gb WD Backup and Storage Drive
TDK DVd Burner (when they cost a couple of hundred)
Lite-On Dvd reader
Antec True Blue 350 Watt PSU
I originally started watercooling due to heat concerns with video encoding sessions lasting half the day. I was fascinated by the first watercooled pc I saw on display at Compusa several years ago an I had to have one. This was months after my first build in 2003 (I've been fiddling around with computers since 1999). I've never looked back to air cooling. I was inspired to take the plunge by some of the XS members earlier work. I've been lurking around here for quite awhile an actually ashame to say how long. This system has since been cannibalized and laid to rest. I miss little drippy.
here's a lil update of my main rig, all these cables looked so annoying ^^
http://alexiel.stor.li/Umbau/7.3.09%20top.jpg
http://alexiel.stor.li/Umbau/7.3.09%20top2.jpg
http://www.abload.de/img/sleeved1eamf.jpg
here are some more, sry for the quality:
http://www.abload.de/thumb/8.3.09frontqs4t.jpg http://www.abload.de/thumb/8.3.09topwpfd.jpg http://www.abload.de/thumb/8.3.09linkeseitetzjr.jpg http://www.abload.de/thumb/8.3.09rechteseiteoryz.jpg http://www.abload.de/thumb/8.3.09lin...windowgey7.jpg http://www.abload.de/thumb/8.3.09rec...ewindoqfhs.jpg
After years of my computer siting on a table, I finally took the time to install my hardware into a case.
Unlike the Torture Rack this case did not have the pre drilled holes for the tubes and only two pre- drilled Rad fan holes.
http://i11.photobucket.com/albums/a1...t/S6301287.jpg
http://i11.photobucket.com/albums/a1...t/S6301283.jpg
http://i11.photobucket.com/albums/a1...t/S6301288.jpg
http://i11.photobucket.com/albums/a1...t/S6301225.jpg
Asus A8N-SLI Deluxe MB
Athlon 64 4000 (939 Sandy)
1gb Corsair Platinum PC3200
ATI x850xt
(2) WD Raptor 74gb (8mb cache) Raid 0
Lite-On Dvd burner and reader
Antec TP 2.0 550 watts psu
3/8" Tygon tubing
Danger Den TDX, Maze 5 gpu, and chipset block
DD D5 variable
HWL BI Pro plus shroud (I didn't know any better)
Koolance coolant
Panaflo M series fans
Oh, and C3 case. I used a Lian-Li psu plate on the back to help distribute the weight of the psu across the back, away from the screw pressure points, preventing sagging an cracking seen on acrylic cases.
I don't see alot of members on the forum commenting on Koolance fluid but I have bottles of this stuff that sat on my shelf for years with no signs of seperation.
Same hardware plus SB Audigy 4, swapping BI for Swiftech rad, different case (V1000) and preferred loop order. Better temps overall.
looks mighty good.
My first foray into water cooling.
Intel Q9550
EVGA 9800GX2
Gigabyte GA-EP43-DS3L
4GB RAM
160GB HD
Lian-Li A05B
D-Tek Fusion V2
Dangerden 9800GX2 block
TFC 360
Laing D5 w/ EK D5 X-Top v2
F@H about 10000-13000ppd
http://www.metasheep.com/pics/lc/finished_01.jpg
http://www.metasheep.com/pics/lc/finished_03.jpg
http://www.metasheep.com/pics/lc/finished_04.jpg
@M40TURBO: That is some beautiful looking liquid. I really dig how it matches the sleeving and the mobo heatsinks quiet well. I've never really been impressed by the actual liquid before, but man does yours look incredible!
Built last summer
Silverstone TJ10
Asus M3A32-MVP Deluxe
Phenom X4 9750
4gb Corsair Dominator 8500
Radeon HD3870
SB Audigy 4
500gb WD Backup and Storage
Corsair TX650W PSU
Samsung Dvd burner
All Scythe S-Flex fans (except the front intake)
Swiftech MCR-220 Rad
EK Supreme Plexi and FC3870 blocks
EK Multioption Res 150
DD D5 variable set to 1
3/8" Tygon tubing
50/50 Koolance coolant and distilled water mix
Temps idle at 44-45 and peak at 52 primed using Asus Probe.
Gpu peaks at 46.
There is less than 1mm of clearance betwenn top mb tray brace and rad fan.
Nice cable management and WC too.
Congrat.
this is mine
@Metasheep- VERY ambitious and well executed first time build! I'm impressed!
Wow, that is pure sex.
Nice setup Patty. The coolant in the res looks toxic in the first pic. I've been an AMD fan since Thunderbirds but I might go I7 next time around.
Here's my contribution, which is a slightly-modded Lian Li PC-V2010 based on the Rampage Extreme (X48) platform. It's currently a single-loop with everything mounted internally, still in need of some cable management. Please excuse the photo quality; I'm stuck using a cheapo camera for now. My build log and additional photos can be seen at http://asusindependent.com/forums/in...?showtopic=760
System Specs:
LIAN LI PC-V2010B Full Tower
ASUS Rampage Extreme X48
Intel Core 2 Duo E8400 3.0GHz
4GB G.SKILL DDR3 1333
POWERCOLOR Radeon HD4870 512MB
(2x) SAMSUNG Spinpoint F1 HD753LJ 750GB SATA (RAID0)
X-Fi Titanium Fatal1ty
Antec TPQ-850 850W PSU
LITE-ON 20X DVD±R DVD Burner w/LightScribe
Scythe Kaze Fan Controller
(3x) Scythe SL12M “Slipstream” 120mm Case Fans
Acer P243WAid 24" 2ms HDMI LCD @1920x1200
Logitech G15 Gaming Keyboard
Logitech G9 Gaming Mouse
Watercooling:
Black Ice Xtreme 3 Rad
(3x) SCYTHE S-FLEX "G" 120mm 1900rpm Fans
Koolance 3-Fan Radiator Shroud
D-TEK FuZion v2 (CPU)
EK-NB S-MAX (Northbridge)
Swiftech MCW60 (GPU)
Swiftech MCP655 Pump
EK-Multioption RES 150
Enzotech Forged Low Profile Heatsink (Southbridge)
(2x) Thermalright HR-09U Type 2 Coolers (Power MOSFETS)
Enzotech Pure Forged Copper Ramsinks (MOSFETS)
Feser Tube Active UV Hose - 1/2" ID (3/4"OD) UV Carribean Blue
Feser One F1 Cooling Fluid - UV Blue
http://i143.photobucket.com/albums/r...s/CRIM0043.jpg
http://i143.photobucket.com/albums/r...s/CRIM0051.jpg
http://i143.photobucket.com/albums/r...s/CRIM0044.jpg
http://i143.photobucket.com/albums/r...s/CRIM0056.jpg
AntiHeroUK: beutiful and very clean rig. Congrats
@ AntiHeroUK You should probably loosen a bit those screws on GPU block- your card looks too much bent
