How much proof do you need ? yes it works :up:
It works with latest 197 drivers so far too :)
I would def. SLI if i'd find another card. Great work TiN_EOF
Hi guys,
First of all good job for sharing this info, nice thread !
Ok, i know this hack really works on intel chipsets but if you use a X38/X48 for example, both cards running at 16x ?
I assume for a Maximums II Formula (P45 Chipset), both cards are running at 8x ?
Cheers !
SLI Mod(0.8b Beta) working 100% stable with drivers 257.15 on this rig:
http://xdevs.com/e107_plugins/conten...php?content.30
Asus P5Q-Pro Turbo
Q6600 @ 3.7Ghz
2x2 DDR2 @ 990 5-5-5-15
2x 9600GT @ 750/1900/1020 in SLI Mod(0.8b Beta)(working flawlesly with 257.15 Drivers)
windows 7 x64bit
Auzentech Forte X-fi 7.1 on G-51 Speakers
Silverstone OP 1000w
Everything inside a Thermaltake Armor Case well ventilated and cool running.
Thanks for starting this tread BartonC+++
It would be nice if everyone running this mod posted specifications and screenies of the hardware and software used in order to build a database.
http://img17.imageshack.us/img17/3683/42824085.jpg
copypaste detected :D
What's wrong with mine database from howto ? :)
:rofl: , Hi TiN :ROTF:. Hey Bro i just bumped this old tread for a friend of mine in Guru3D who has problems installing and running the SLI Mod ( hence why the copypaste detected :rofl:)
Nothing wrong with my set ups running SLI Mod with database from you , its not for me its for this guy PillMonster using
Mainboard: ASUS M3N78-PRO here TiN:
(copypaste again :ROTF:)
http://forums.guru3d.com/showthread.php?t=325188
hi, when you only have one gpu on the board, can u see this : set sli and physx configuration ?
http://img641.imageshack.us/img641/8103/semttulo22s.jpg
You should only see the set SLI option if the drivers detect a second sli compatible video card and a sli compatible motherboard. More than likely if you are seeing it then you are good.
have anyone had sucess with the latest drivers?
hello, I have a Gigabyte 9800GTX non plus
http://gpuz.techpowerup.com/10/07/20/599.png
I can do SLI with an Leadtek GTS 250 v2?
thanks
TiN I love u for sharing this driver hack man. Dont know if I ever told you, but I owe you for the 01 wr. Not possible without YOUR contribution here.
THANK YOU!!!!!!!!!!!!! :clap: :clap: :up:
ok, good news:
1. I've GOT TODAY my Zotac 480 AMP! and PNY 480.
BAD news:
259.86 do NOT work with the hack =(.
I'm going to wait for a week, and if nothing going to change, I'm going for a true sli system. ( bye-bye my monitor)
k|ngp|n, you welcome, mate :) Glad, that it helps a bit :D
ALL
We are working to get patch working on latest drivers.
Some of people help are welcome, because some ppl told they have no problems with 258 drivers and SLI.
Other say they have lots of problems with 258 drivers and _OFFICIAL_ X58 sli supported systems with SLI enabled.
So need to know, if it's some kind of protection added, or just bad drivers.
If somebody have X58 sli-ready rig with pair of GTX260/280 or fermi cards, could you test 258 and 259 driver with SLI, if it work ok.
I might be mistaken, but aren't there BIOS modders out there into the "dark arts" of injecting some kind of SLIC into BIOS code that forever makes SLI non-compliant chipsets forever compliant nomatter the driver?
Tin, thank you for your time! Really appreciated! I've attached a printscreen with the last drivers installed on my system (E8600, Asus Maximus Formula 2, 4GB RAM, 2x GTX275 (Gigabyte + BFG OC)).
SLI's not working on this configuration anymore with 258.96
Was working fine with my previous drivers 257.15 though.
Let us know when you have some news! : )
Thank you!
Ket, SLIC in BIOS is NOT enough for having SLI.
I told this, together with anatolymik tons of times :D
Good ! I might try on a P5E3 Pro with 2x 9800GTX+ in a few weeks ;)
Hope something interesting will sort out of this board under SS cus on air it was just crapp !! :/
Would it be possible to use GTX 460 in SLI with this hack?
Sure with 2 cards :D ...to my side awaiting for action I'm bored :( anyway I'll buy a REX just for that ? xD (If nobody can fix my board or give me a UD3P :/ )
Cool news, so is it possible to enable SLI on my DFI X48 T3RS that is crossfire ready? How do I do that can anyone give me a hand? I see the guide on how to do it, but it says we need modified forceware. Any tips on where to get the most recent forceware released by nvidia, with modification?
Any news on the latest drivers? Can they be used without crashes with the SLI mod hack?
