Can you run those 300+ RAM speeds at 'normal' CPU speeds? Like 2.7GHz and up? Or is it for sub 2G only??
Is Vddr/Vbt/vtt all you had to do in order to reach those ram clocks or was there some extra mods involved?
Mine dont need a lot of voltage to do 265 they will do that @ 3.3 V but i dont think the chaintech board does much more voltage ....Quote:
Originally posted by Orak
hey...SmokeyTheBandit
how mutch volt do you fead your BH5 ? I have a problem to run Cas2 on my sticks.. it can be voltage ?
i give them 2.88v on 440mhz on 2.5-2-2-5 now. must go down to 420mhz to get cas2 ..
The higher i go the less posts i get :P .... 3.4V works but sometimes is crashes or wont even boot up .....
Why didn't you picked the Shuttle AN50R :)Quote:
Then you'll have plenty of voltage freedom.
I reached 4.88v so far :D
I heared that the onchip memcontroller won't be damaged on de AN50R because it get the voltages from the 5V rail not from the 3.3v...
btw smokey: I have a green CAAOC 0350 XPMW, you have the brown one with same stepping code?
On GoT there are the results, so then you can draw you conclusion what the difference is between green and brown.
Here is Sandra Bandwidth Benchmark result at 348.75MHz x4.0:)
M/B: GA-K8N Pro / BIOS: K8NNXP-940.F2
CPU: Athlon64 3400+ CAAOC 0345
CPU Cooling: Watercooling
Chipset Cooling: microcool NorthPole
Memory: Corsair PC2700LL 256MB x1
VGA: Matrox G450 PCI
HDD: HITACHI HDS722512VLAT80
Power suplly: Zippy-460W(for system) & AOpen FSP400-60GN(for HDD&floppy)
Vcore: 1.834V, Vddr/Vbt: 3.590/1.791V, Vio: 3.980V
OSFWindows Server 2003
MEMF200-CL2.0-11-13-2-2-5-2-2-2-6-1x4672
Check also please:
http://www.oohashi.jp/c-board/c-boar...ne;no=2016;id=
:toast: only 4080 at 348 1:1 :confused:Quote:
Check also please:
http://219.113.251.125/c-board/c-boa...;tree=2014;id=
I hope they will go cas2 with more voltage.. but im gonna try some Geil PC3500 golden dragon sticks soon.. so ill get a answer on that issue :stick:Quote:
only 1300mhz on the chip. would that be limiting throughput?Quote:
I got a 3200 running at 235 water cooled with stock voltage and stock timmings. Had to lower the ram spped to 333 though to get it stable cuz my hyperx 3500 blows. Dont know the code on the cpu as it is a pain in the @ss to get the water block off. I just learned about the ldt thing so i am going to go play with that now.
Oh and here are my benchs tell me what you think.
http://service.futuremark.com/compare?2k3=1932860
http://service.futuremark.com/compare?pcm04=141342
http://service.futuremark.com/compare?2k3=1932431Quote:
interesting how my chip is 2mhz slower but i have a 30+ point margin on you in cpu marks. i thought the via boards were supposed to be faster clock for clock.
:toast:Quote:
Very nice clocking. :)
But it seems that once CPU is really overclocked its impossible to reach 300MHz 1:1 2-2-2-5 timings even thou the RAM and board runs over 340 at low CPU clocks?
Kyosen, have you tried increaseing the 2.5V voltage (its said to be"Vldt" on ASUS K8V) on K8N board?
my BH5 + AN50R = suxx, on my old NF7 @ 3.3V @ 246 @ 2-2-2-11) --> AN50R max 238 @ CL2 :mad:
here 266 1:1 @ 2.5-2-2-5
http://downhill666.bei.t-online.de/Rechner/4068MB.gif
the maximum on my AN50R is 300 with 6:5
http://downhill666.bei.t-online.de/R...+%20300FSB.gif
wow. how can you use that color scheme all the time??? :eek:
ne1 know why if i try 240fsb it locks up? even when i put LDT @ 2x and multiplier @ 4x?
220mhz is the most i can get
i'm using promise s150 tx2plus to house my 3 HDDs.
only thing on onboard ide is my LS120 n my dvd-rom
http://users.rcn.com/trackstar2002/220fsb.jPG
this is my score at stock speeds
http://users.rcn.com/trackstar2002/stock.JPG
Shuttle AN50R
athlon64 3400+
s0rrie for the huge pic
oh n when i reach like 235mhz my video gets currupted...
i thought the agp was locked? :confused:
P.S. anyone know how to print screen one item (active item) instead of the whole screen?
Here my Overclock results with watercooling by Asetek :D
I upgraded it with a Airplex EVO 240 10mm
http://kakaroto.ntonline.nl/A64_3000/Pifast_2621MHz.PNG
http://kakaroto.ntonline.nl/A64_3000...01_2.56GHz.PNG
:toast:
Totally Insane clock!! :D
I'm maxing out at 2370mhz ATM with only 1.7Vcore to work with.
I'm working on a Vcore and Vdimm mod though..
yeah, i love this color :cool:
My A64 3200 is maxing at 2405 atm. at 1.7vcore.. im working on a vdimm mod and vcore mod my self :) and a vmod for my radeon 9800np, someone knows what speed il get on my mem at ~3.2v ? (infinion 3.0)
Hi ! MickeyMouse
The IDE card is not used.
SuperPai 1M 4x multi Ranking
I want to know how it is possible to get an 350-400 MHz FSB ? What is the maxim FSB that u can put in the BIOS ? Gigabyte let 400 MHz in the bios (2x normal FSB) ? WTF ? Are they crazy ?
280 in the bios and 500 in windows is the maximum...Quote:
mhhh 500 :slobber:
Hi ! marius7
I am using CrockGen.The ClockGen serie consists in a set of overclocking softwares.MAXFSB=400Mhz(DDR800)
