Can I downflash bios to0812 via winflash program ?
Account activated at last!
I was trying to register 5 or more times. Now I'm not even sure what I wanted to ask at the beginning ;)
Well, hey guys :D
I have this board since 2 or 3 weeks. NOT Plus version. I've updated bios to last official release (not beta). I can't get full stable even 400MHz FSB.
First let me ask about such things:
- Do anyone got nice OC on non-plus board? (in dual channel and some normal amount of ram - not 2x512 ;P )
- What is max stable temp for P45 and E8600 (C2D 45nm at all) - I'm on stock coolers for now and without any case yet.
- What are default V for P45 and what are necessary for 400 FSB and let say 4GHz on CPU (10x400)? My board (or PSU) seems to undervoltage...
- Which bios should I use (does plus bios fits to non-plus board) ?
Of course I've read this whole topic.
Cheers!
PS. I'm very happy I could join XS :up:
Hi there all. I am new here as u can all see. I wanna say that all bioses i've tryed for DK P45 T2RS failed to let me OC my 8200 @ 4 ghz. But with that bew version launched in September i manage to reduce the Vdrop to 0 ( like someone said here few post earlyer) . Now i am using something like this : VTT - 1.2v / V.NB - 1.37 , 475 FSB with 137.5 mv added at 1.0625 Vid and i got like 1.184 V in idle an 1.168V in load. I am happy couse till now i have to add 162.5 mv to obtain same voltages. What i can't understand is that i have to set GTL's something like this : 67% / 67% / 58% . I am asking if i can try 500 FSB with the same settings, but i want daily use with theese settings.
you mean from 901 to 812 right ?
just do it like up bios, it may not work for everyone, so I still recommend to flash by usb drives or other devices than flashing in windows
http://csd.dficlub.org/forum/showthread.php?t=1136 , this is how to.
The really difference between "plus" and "non plus" board revisions is much better memory voltage regulator. One chip and one diode added on the "plus" version and better OC potential AFAIK.
Today they added new BIOS 10.03 version with all options was included in 901 and 923, but with one new great ability added - now both are boards supported 1066mHz memory via new BIOS dividers 266/1066 and 333/1066. Not so needed for OC, but for using stock freqs it's really good solution.
Sorry for silly question but where one can download 10.03 bios? I can't find it at DFI site.
How about my previous questions please?
+/- stable temp for P45 and for C2D 45nm
+/- voltage for NB (P45 ofc) @ 400MHz FSB and vcore for C2D 45nm @ 4GHz (E8600)
You can find 10.03 here
Nice, I will flash tonight.
thx
that's the sneaky part ;)
I don't know how you found beta url, but it's enough to change querystring parameter STATUS_FLAG=A to STATUS_FLAG=B
It works also for non-plus version (and probably for all others dfi bios downloads too).
If anyone needs, here ya go non-plus link
I have some problem flashing new bios 1003 via winflash
program pop up msg "The File's BIOS Lock-string Does not match with your system"
I follow each instruction correctly !! What should I do now?
http://img146.imageshack.us/img146/9533/errormf7.th.jpg
10/03 beta link for JR anyone? It is back to 08/10 on the main BIOS page. Where do you guys get these beta links in the first place, I cant find any beta area. :/
yeah man, I used to have that prob too, but finally I flashed with dos
If you have no fdd and so the usb drives, at least I think you have cd/dvd drive
I recommend this cd http://csd.dficlub.org/forum/showthread.php?t=1525 it has 812 bios and works fine, also has another utility like memtest.
and um, if anybody rollin this mobo with e8400 e0, would be nice to share ya config
cause um so idiot about the config (NB, VTT, GTL, REF blah blah blah), for now I hit 4.4ghz orthos red at 31 minutes)
I think that's why bios 901 and 923 have been removed. :)
I flashed from a stick, everything was fine.
I flashed it already by usb drive , it seems fine.
but I still got a problem cant go thru fsb500 anyway
it e8400 E0 + DK P45 Plus version.
Not sure I need to config the DRAM timing or not , I used geil ultra plus 1066 cl5
I just leave it auto now
I've flashed 10.03 with winflash - no problem (check if you selected plus bios or not plus)
For the 1st try I set bit insane voltages for stock cooling. While testing mobo shutdowns system when cpu was at 75C (the value was set at bios)
I'm trying to get ROCK stable only 10x400, mem set @ 800 all auto, vcore 1.29V*, NB 1.23V*, VTT 1.23V*
*) readed from SmartGuardian - my mobo/psu seems to lowering nominal values selected at BIOS
TEST - in the same time:
core0: SuperPi - dropped "not exact in round" quite fast :/
core1: Prime95 - large FFTs (maximum heat and power consumption...)
temps (to high?)
CPU: almost 60C
NB: above 50C
What's the problem in your opinion?
I'm assuming voltages or temps but:
OC isn't high so voltages should be enough, shouldn't they?
Temp... well my laptop works sometimes even at 95C at heat peak - always stable. I know mobile CPUs are more stable, but come on, almost the same core architecture - 65nm even worse.
I'm fresh with C2D ocing (but not OC at all), any explanation is welcome for nooby :D
edit: moving text block
Can someone please confirm for me that the 0901 bios link for the DFI LanParty JR P45-T2RS board is this one http://us.dfi.com.tw/Upload/BIOS/J245D901.zip ? Do you follow the same bios upgrade procedures for this beta bios like it states in the DFI Website? Thanks!
dja2k
Did some more tweaking last night to get my Q66 going fastterrrr.
Originally set myself a 1.35V limit to find a decent 24/7 clock which I hit 370. Past 370FSB though, the vCore needs to be pumped right up.
I decided to go a bit crazy and cranked it straight up to 1.5V and managed 400FSB, also set vNB to 1.35. 405 started to go pear shaped so tried decreasing the CPU GTL.
Weirdly, dropping (or is it increasing) CPU GTL 0/3 to 0.63 from 0.67 didn't make make a difference, but dropping CPU GTL 0/2 made Vista restart 1/2 way through loading. I think alot of my problem the other day was tat CPU GTL 0/2 was set to 0.63. Leaving it at 0.67 made it far more stable.
So I have something to go forward with! :D
seems like DFI took out the beta bioses for the JR...something must be brewing.
DFI left the JR with the 8/12 Official Bios & took out the Betas...but i was able to grab the 9/23 a week+ ago.
i do the DOS/USB drive update...messed up once using winflash & i never did it again.
