Think 1.1 mate, but I run it at 1.2 (for the 4gb) at 400FSB daily/ram at 1066Mhz
I have almost setup like you, but P5Q-E (0702), and QX9650 with Scynth Ninja plus.
however every time i try to OC i get no POST and need clear cmos.
I'm familier with P5B-DLX OC, but here its so diffrent, can you give me guide lines please ?
Well, I've used some hours tweaking Skew. There is one skew setting for eatch DIMM. On my ballistix 200ps delay was the best setting, but this may be different for your system. You simply have to test all settings for finding the best. When it comes to nb and cpu skew, I've not tweaked these yet.
Guys, with the latest bios, what version number do y'all have with regards the embedded Intel Matrix RAID option bios ROM?, 8.5.0.xxxx etc?...any version number for the Jmicron ROM?
BIG 25Cm fan in the sidepanel mate and WC for the CPU...
Try these settings first mate... your CPU prolly can do 3.6Ghz lower than 1.3Vcore but some have really bad ones so if you know it can do 3.6Ghz at 1.2 set 1.2 then instead off 1.30... once you get this stable you can up the multi and add more Vcore... and tweak RAM... but do it all one step at a time and use the OC profile... if it posts save it to the profile, set abother setting, save and reboot if it posts save again to the profile... it needs some time to adjust from 965 to P45...PHP Code:JumperFree Configuration Settings
AI Overclock tuner: Manual
CPU Ratio Setting: 9
FSB Strap to North Bridge: AUTO
FSB Frequency: 400
PCI-E Frequency: 101
DRAM Frequency: 800 or 1000
DRAM Timing Control: AUTO
DRAM Read Training: AUTO
MEM. OC Charger: AUTO
AI Clock Twister: AUTO
AI Transaction Booster: AUTO
CPU Voltage: 1.30
CPU GTL Voltage Reference (0/2): AUTO
CPU GTL Voltage Reference (1/3): AUTO
CPU PLL Voltage: 1.5
FSB Termination Voltage: 1.2
DRAM Voltage: 2.0-2.2
NB Voltage: 1.2
NB GTL Reference: AUTO
SBridge Voltage: AUTO
PCIE SATA Voltage: AUTO
Load Line Calibration: Enabled
CPU Spread Spectrum: Disabled
CPU Clock Skew : Normal
NB Clock Skew : Normal
Advance CPU Settings
CPU Ratio Setting: Manual
CPU VID: Default
C1E Suppport: Disabled
Max CPUID Value Limit: Disabled
Intel® Virtualization Tech: Disabled
Vanderpool Technology: Disabled
CPU TM Function: Disabled
Execute Disable Bit: Disabled
And if it doesn't post, no need to clear CMOS... switch off the PSU.. wait a few secs , switch it back on and start the pc... it should post then..
Good luck
is it my bad cpu? i can only get this high with my P5Q3 Dlx
http://valid.x86-secret.com/show_oc.php?id=374749 591 fsb
:shrug: while others can easily play 600 :confused2
Help Guys!!
I just setup my system, and after the usual bios post (where it tells you CPU, RAM & Bios stuff), it goes to this:
"Marvell 88SE61xx Adapter - BIOS Version 1.1.0.L70d
Initializing."
And it's stuck there!!! I can't even get into BIOS. Even if I hit "DEL to enter Setup" - it goes to this and gets stuck!!!
Help!
Pull out one Dimm, unhook all drives (HD, DVD, etc) and try again... if it doesn't post completely don't reset, just pull the power cable... wait a few secs and then try to boot again...
Tony have you tried the OCZ FlexII 2x2GB kit on this board?
Just put together a P5Q dlx with a 8400 wolfe and the thing won't boot :(
put in one stick of ram in the yellow slot nearest to CPU and have a single card in the PCI slot
have a new ZM1000-HP power supply.
everything powers up but the GPU fan just goes full blast and doesn't post :(
now since I bought a Lainli case the 8pin CPU power won't reach but I used a 4pin extender that came with the case.
I talked to a buddy he said it should power up on a 4pin plug and the 8pin had 1/2 coved via a plastic cover.
any ideas on what to do??
Define single card in the PCI slot, so not a PCI -E card ? did you try the mobo outside of the case ?
Guys, I'm organizing the last details of the import of my P5q deluxe, and I have some questions.
How much voltage on northbridge, fsb, and cpu pll voltage i will need to set 450mhz of fsb with a 8x divider?? with my cpu (E6750)
PS: Don't need to be exact numbers, i wan't just a suggestions!
what is the options of memory divisor with this fsb?
thanks!
mobo in case will remove shortly
tried my old OCZ 520 and same results
tried my old X1800 and same results
Nvidia PNY - 8800GT in blue PCI
Can you mount a CPU wrong LOL Iam removing mobo see if that clears it up let you know.
Thanks for this helpfull tip !!! :up::up::up:Quote:
Originally Posted by Leeghoofd
They are finally showing up in Aus. $266. That's an awesome price.
who should i belive ?
CoreTemp VS. RealTemp ??
and what should be the max temp ? 70?
http://img385.imageshack.us/img385/4117/400x9cg1.th.jpg
not sure what to do
took the mobo out and the case intrusion jumper was off
replaced that and still no boot
took mobo out
GPU powered, Ram installed 24pin powered , 4 pin powered = no boot
replaced 8400 with e6700 no boot
has to be something simple Iam missing or its bad out of the box
Iam going to try my P5W mobo with the 8400 and see if that will boot
