updated:up:
updated:up:
I'm not liking Vista, it's tougher to get stabler higher clocks
my CPU score dropped off going from XP to Vista
This isn't going to be as easy as I thought
I may have to switch to Vantage
Edit:This was a test run I'll give it a few more tries
http://i231.photobucket.com/albums/e...nchr/3dtri.jpg
Thats crazy results for the same hardware and just different OS...
200mhz more with Phenom should actually improve the score more than 250-300points i would think...
:up::up::up::up:
After a bit of tweaking (read hours)
http://service.futuremark.com/compare?3dm06=8612138
Main test results
3DMark Score 15788 3DMarks
SM 2.0 Score 6126
SM 3.0 Score 7366
CPU Score 4637
Phenom 9850 cores 0,1 & 2 @ 3198mhz, Core 3 @3092
PowercolorHD4870 815/1125
This is one fun things about this board,you get to try all kinds of combo's
QuadFire 2x3870/2x3850
http://service.futuremark.com/compare?3dm06=8475061
3DMark Score 18175 3DMarks
SM 2.0 Score 6743
SM 3.0 Score 9481
CPU Score 4577
3870's@776/1126 3850's@669/829
Phenom 9950 @3.4GHz (1.55v)
Vista 32bit SP1
Cat8.9
One for the Nvidia side
http://service.futuremark.com/compare?3dm06=8475562
EVGA 9800GT SuperClocked
3DMark Score 13547
SM2.0 score 5741
SM3.0 Score 5455
CPU Score 4587
Phenom 9950BE @3.4GHZ
9800GT Stock Speeds
Vista 32bit SP1
GeForce 178.24
I thought I had better post this one before I try any more
Saved the best til last
Ask and ye shall recieve Triple 4870'sQuote:
Old news
New, new high score
http://service.futuremark.com/compare?3dm06=8379701
3DMark06 18577 :shocked:
SM2.0 score 7010
SM3.0 score 9146
CPU Score 5110
Ice Spider V2.0
Phenom 9950BE @3.547GHz(on 4 cores)
CF 4870's @750/900
Cat8.8
WinXPSP3
ASUS M3A79-T Deluxe
:party:19709:party:
http://service.futuremark.com/compare?3dm06=8625915
3DMark06 19709
SM2.0 score 7146
SM3.0 score 10519
CPU Score 4901
Phenom 9950BE @ 3570 MHZ(on all 4 cores)
TriFire 4870's 750/900
Vista 32bit SP1
FarCry2 Hotfix driver
(210*17,NBx12,HTTx12,PCIE@105,vcore1.55v NBvid1.3v,HTT1.28v,NB1.28v,SB1.28,disabled ACC,Autoexpress,Microcode update and ganged mode,enabled CPUTweak(that's all I remember for now))
I had to beef up the cooling coil from the 1/8" fridge rad to 1/2" copper tube coil, that came out of a heat exchanger at work, to get a stable run at 3570 for 3DMark06
Temps went from 35c to 25c
It was good enough to get a SuperPi run at 3604 MHz
:toast2:
It's Crown Royal time
Cheers
Grats man that just a great run go AMD/ATI woot!!!!
Message to AMDDeathstar --->:woot: Your prize ->:oscar:
me going --> :slobber::eek2::shock::dammit:
Man that is an awesome score. You are so close to breaking 20,000 with a phenom. That would be great. You have to go out and order another 4870....come on quadfire....woohooo!!! Good Job!!
Also there went my chance at taking back the top spot. I just got the #4 3780 in today, but I am waiting on my Corsair 1000w PSU to come in before I can overclock everything to the max and make a run. I am hoping for at least 18,500 though. We shall see.
Thank guys
No more vid cards
My plan for awhlie has been to replace the heatpipe coolers
I got the guys at work to cut a copper plate to cover the pwn's fully, now I just need to attach cooling to it
Then I have to figure out what I want to do with the NB and SB
If it wasn't for those damn heatpipes the NB block would've been replaced along time ago.
now that I can get past 3.55GHz without blue screening I want to see just how far I can go
:cord:
Show no mercy. Take no prisoners.
nice work man
Well I went ahead and ran some benches last night to see what my 4x 3870s could pull off. It seems that in 3DMark06 they are severely CPU limited. So I hope to at least break 18.5K once I get my new PSU to give me a little more stability when overclocked.
18,211 - http://service.futuremark.com/compare?3dm06=8635984
CPU @ 3366MHz - 4x 3870 @ 864/1272
i just got a 4870 so of course i had to run it with my 4850 at least once before i get rid of the 4850...
http://service.futuremark.com/compare?3dm06=8647044
3DMark Score 17882 3DMarks
SM 2.0 Score 6819
SM 3.0 Score 8979
CPU Score 4659
vista 64
9850 ,,, 14x240 @ 3.36ghz
ht link ,,, 2400
nb ,,, 2400
ram ,,, 4x1gb @ 960mhz 4-4-4-12 unganged
4800's ,,, cat 8.8
4870 @ 780mhz core ,,, 1090mhz mem
4850 @ 690mhz core ,,, 1148mhz mem
Well I messed around with ACC last night and got a little higher score. Still need my new PSU to make everything stable and really overclock these cards though. I am now hoping to break 19,000.....we will see.
18,612 - http://service.futuremark.com/compare?3dm06=8659438
CPU @ 3415MHz - 4x 3870 @ 864/1272
3.5 ghz and you should break 19k ;)
imo
Standard 1280-1024 (17925)
1920-1600, 4AA, 16AF (17504)
Vista 64
M3A79-T
9950 (140w) 3.3
1066 ram
2 4870X2s (800-900)
That was 1920-1200
Well going from 3366 to 3415 brought me about 400 extra points in 3DMark06. That is only 49MHz per core. That really tells me how CPU bound these four cards are. If I can get bench stable with another 50MHz per core I should hit 19,000. Maybe when it gets colder.
I went from Auto on ACC to +2,+2,+4,+4. I am going to test it soon to see what I get when I completely turn off ACC.
i need to get oof my a$$ and volt mod the other 4850...i am getting kicked down the latter again..:p: Nice job guys.. Just think by Dec. we might have a few break into 20,000
OMFG congrats on those scores :up:
need to clock my stuff moar :D
3DMark Score 10371
SM 2.0 Score 4578
SM 3.0 Score 5344
CPU Score 2152
http://service.futuremark.com/compare?3dm06=8675414
X2 4800+ (Brisbane) @ 3GHz
MSI K9N Neo V3
Corsair 4GB @ 800MHz 4-4-4-12
HIS HD 4850 ICEQ 4 (non-turbo version) @ 630MHz/1003MHz
