Any updates on that pump mate?
Or have you looked into big heatsinks yet?
EDIT:
Take a look:
http://cgi.ebay.com/Aluminum-Heat-Si...QQcmdZViewItem
EDIT:
Take a look:
NOL im terribly sorry.
Ive been under tons of backuped work.
NOL also i think i lost your addy. Can you pm me it again.
I'll mail a pump out this week if it kills me.
Also NOL grab that sink and play with it. I'll give you around a 100 dollar play budget. Meaning do whatever you want under 100 dollars.
hey Naekuh I will take that 100 dollar if nol don't use it all :D
http://cgi.ebay.com/Aluminum-Heat-Si...ayphotohosting
Going with that one me thinks
that is one interesting heatsink, but if your chop it right it should be great.
looking forward to seeing those gems rocking some coolness into your system..
Okay, heatsink ordered :)
I'll breakdown the monster I guess into two halves, see if thats better, then we'll see about more tec's and more powersupply, but I think we'd rather avoid that.
Ah come on! im impatient, i want to see how it performs!
:D
Waiting on dat heatsink to arrive.
Heatsink be here, didn't see the package, must have been here since thursday.
Okay, it's really big. 4" tall is very large for a freakin heatsink. A few fins bent but got em back almost perfectly.
Now to figure a way to get this, somehow, attached to to both the pelt setups....
Any ideas? I'm tempted to just grab a wood board and use some big ass clamps.
A couple of pieces of 3/4" alum channel or "T" stock? Do you have a scrapyard in town? It's a great place to find goodiies like this.
ROFLROFL..
nol i held on the pump.
I figured you'd be busy with that sink.
I'll mail you a real pump soon. Im rebuilding persephone. And im gona piss off a lot of people in the WIP.
I am gonna post 1 PIC a day. And each pic will make the people in the work log section drool cuz of the quality of parts.
Heheh.
Blame iany for the idea.
Well I found a fan for it, its a 10" desk fan.... Will work amazingly ;)
I think I'm just going to cut a peice of 3/4" plywood and use that as a clamp board...
Pictures? Results? :confused:
Just finished moving house, setting up the workshop again these next few days, then yes, clamps, wood board, a ten inch desk fan, and we'll see how this fairs out ;)
:rofl:
so you got a new big workbench?!?!?! :rofl:
Nope just setting up the old ones nicer.
Uh oh....
Small problem mate, check your PM's.
Everything seems normal except, the pelts don't seem to be doing anything, but still drawing power...
Any updates? :D
Would be so interested in hearing an update, good or bad. It would help me and probably other people out in the possiblities of TEC chillers for PC use. I am looking at a pretty deep money pit right now to try this and so far looks like people who are more equipped and versed to successfully do this are not having much luck.
Also, what would be a better top material for the cold side of a TEC waterblock, Delrin or copper? Seemingly not much more cost to get copper then delrin for me. For the hot side, I will more then likely do an all copper block and also put fins on the top of the block. For the cold side, I'd imagine any extra attempt at aircooling chilled water will only warm it, so probably best to use delrin for the top?
Anyway, looking forward to some info :yepp:
Pics would be nice to have as well. :)
That seems to be the optimal TEC project: High voltages TECs running at 1/7-1/8 of their rated voltages, working at small temperatures gaps 5-10C degrees across, maximum efficiency is pretty important.
If we want lower temps wouldnt be more efficient to put the TECs in a serial cascade: the first TEC running at a 35C hot-30C cold, then another at 30hot-25C cold an the last at 25C hot-20C cold for example.
The hot side water loop can use an inverse current setup (not sure about the term in english)- the last hot side-which runs at almost ambient temps uses the coolest water coming from the RAD, then moves this mildy hot water to the next stage (+5C degrees) and so on.
At this point of the project i believe that TECs working as a post RAD chiller are a true technical challenge,But the concept is quite interesting:
http://www.xtremesystems.org/FORUMS/...=189043&page=1
Just for consideration: why not plan a post RAD chiller that can run straigh from the 12v or 5v line of the ATX PSU, without adapters (maybe using TEcs in series for optimal operational voltage), in a system that is at or slightly BELOW the total system heat output at idle: instead of running the CPU at sub-zero temps, why not running the entire loop-VGA,mosfets,CPU at 3-4 C degrees below ambient: no condensation problems, no need for special PSUs, no need for a PWM regulator. Sure the temps on full load-OC will be modest, but still better than a classical waterloop, and will be much simplier and cheap to implement, and more important: safer for 24/7 use.
I just accidentally found this.
It seems Cathar did something like this a few years back.
http://forums.overclockers.com.au/sh...&highlight=TEC
http://www.employees.org/~slf/images/tecc1.jpg
http://www.employees.org/~slf/images/tecc2.jpg
http://www.employees.org/~slf/images/tecc3.jpg
