Yes but I wouldn't recommend itQuote:
is 12.b03 the latest beta for this board?
Luck with build:)
From [URL="http://www.clunk.org.uk/forums/4776-post181.html"]M704B_12.B03 Initial Feedback
/URL] for those with browser issues:lol:
1) Bench Comparison
Results show slower performance
....Everest PI32 Pi1M
.....Read
03 8642.....14m.42 14.266
02 8830.....14m.15 14.219
Pi & Everest Benches 12.B03
http://i218.photobucket.com/albums/c...50_Benches.jpg
Pi & Everest Benches 12.B02
http://i218.photobucket.com/albums/c...alcoreNorm.jpg
2)Vcore
On several occasions a selected vcore in this case 1.40v has been set back to the auto 1.265v value.
3) Vdimm overvolt.
1st notived this due to Guru alarm in xp
http://i218.photobucket.com/albums/c...Dimm-Alarm.jpg
There are really 2 issues here:-
3-1) The alarm value in vdimm is 2.2v which seems a bit low as some performance ram will go up to 2.4v
3-2) I had set vdimm to 2.175 as shown in the vcore shot.
Both Guru XP & Guru Bios
http://i218.photobucket.com/albums/c.../GuruVolts.jpg
show it overvolting to 2.20v. As i've said elswhere i've been able to run comfortably around 1080 at 2.175v as on load the board over volts a further .04v see Multimeter tests
So so far nothing particularly worthwhile. Have flashed back to 12.B02 if anyone wants something particular testing i'll try it, but otherwise I'll not be using it.
