My Cpu is know 3dMark stable at 2860, gives me around 4,1k Cpu score.
More intresting is Wprime, preformace very well at 2915mhz.
My first Sub 14sec.
Direct link: http://i30.photobucket.com/albums/c3...ric/Wprime.jpg
My first Sub 14sec.
keep on burn-IN... ;)
BadNizze: Temps/volts after some burn in please. Also what speed is your NB running?
GA-790FX-DS5 I tried like heck to get my 9500 to work with this board. I could run stable enough for 3DMark, Rendering programs and P95. When I started folding at home it would reboot after about 5 minutes even stock after and optimizing settings. Heat was not an issue not power see below for rig. I was able to reach OC of 2.45 and run a little but I had not learned of the NB problem when I tried it. I flashed to F2 and the problem got worse. I have several sticks of ram so I was able to move them around. I RMAed the chip, after I tested a sensitive 4600X2 Windsor in it. I took that chip to 2.5G no sweat on the same RAM and all I did was, hit F7 (optimize), set ram to 1.9V as called for and raised HTT. Folding 24/7 for 5 days now so I know the mobo is good and the ram.
Love this board and from what I saw in the Phenom, great chip.
Rig:
GA790FX-DS5 ( I know this is a DS6 thread but not much diff in mobos).
GP9500
GSkill PC8000-2x2G CL5 or Wintek PC6400-AMPX 2x1G CL5
PC-PNC Silencer 610 (Little Beast of Power).
TT-Armour Case lots of fans and airflow.
Radeon X850-XT.
I've DLed the 3C and 3D patches but not flashed. I'll wait until I get my replacement chip then see where it stands and the updates stand.
Yeah! I saw your warning before that test, so it was just for 2 hours. Now I now what my memory is capable of :D .
BTW how it would be with warranty on CPU if it fail because of overvolted RAM? It shouldn't happen if CPU is designed properly... Or is it a GBT design fault?
PS. What are chances of publishing not-patched F3C BIOS? The one you're trying to get for us :) .
@AlabamaCajun: Do you have an possibility to measure power consumption for your system? Interesting would be diference between 9500 and 4600x2
Very high VDIMM there Lightman. I would never run that on D9's, known to die with only 2.25V continuous and 2.3-2.35V bench. Some experience here. :( Its shows bandwidth falls with higher timings on Phenom regardless of DDR2 speed though, lower timings at lower MHz wins the day. 400MHz has higher bandwidth/lower latency. :)
Phenom cold with Enzotech Ultra-x with Yate\Nexus @ 12v Load under prime is around 51-53c on all cores. Htt\Nb is runnning 2ghz.
http://i30.photobucket.com/albums/c3...c/nb2prime.gif
Did some latency tests the otherday aswell. Booted straight from bios at 2600nb and 2800 nb. CPU @ Stock.
Nb @ 2600
http://i30.photobucket.com/albums/c3...ic/2600lat.gif
Nb @ 2800
http://i30.photobucket.com/albums/c3..._Eric/2800.gif
Some scaling going on here or what?
I´m free from work today and I got my DFI 790Fx... So i´m of playing with that know... My gigabyte will still be my Phenom board, the DFI will be for my 6400+ black.
Very nice. Thank you. :)
About the NB -> does AOD read the same values?
HI, please help, i use giga 790fx DQ6 and phenom 9500, mem is kingbox 1066 D9.
I set NB 9x200 in bios, and can not boot htt over 235, can not reach even 240.
And please give me the tips to setting in bios to fly this phenom.
Many thanks.
I did set in bios NB: 8 x 200 but can not boot even htt 230.
Thanks.
yes! some.. mostly CAS5
sorry bout the delay been caught with with life stuff real bad this week or 2 , some things can't wait :wasntme: hehe
Quite chuffed with the Wprime :D
http://img266.imageshack.us/img266/11/wprmff8.jpg
http://img341.imageshack.us/img341/3...nebenchiv7.jpg
http://img515.imageshack.us/img515/5686/pimh6.jpg
http://img341.imageshack.us/img341/3876/92489505fp7.jpg
Thats´s a good Wprime run majord! And lock at that SuperPi! Could not get close to that!
Best Wprime for me is...
http://i30.photobucket.com/albums/c3...ric/Wprime.jpg S
I just got :owned: @ Pi Going back to my dark cave for a while :D
must be that nb speed nizzle :( you're on a 5x multi aren't you? I can get the 265 HTT with an 8x that is my LIMIT though regardless.
It is however touch and go.. If I get a lockup that requires a reset, it's no boot for me without resetting power completely, odd. And sometimes it won't boot without dropping it a bit.
-edit. A shame, I reckon if I could see 3Ghz on this NB multi i'd see 24.xx Pi time :)
Your Nuclearus/wPrime is very similar to mine at 2849MHz mAJORD (1780-ish NB 4-4-4-4 1T). The 1M was around 26.5s at 2849MHz. :)
But my board has far too many problems, won't even bootup stock many times, or underclocks to below 2GHz and AOD locks system 9/10 times. It also resets voltages to stock. I struggeled getting 2.2GHz all day today.
396HT ref. limit on MB, 270HT ref. limit for Phenom, around 262HT ref. limit with 11x multi in my testing. And NB speed at 2160 is impossible here. Around 2080 is my limit and it affects perf. very much.
32-bit/64-bit and XP to Vista affects perf in some apps very well too. wPrime for instance is much faster on Vista but SPi is slower.
yeah I dunno why Wprime is so fast on vista.. All my tests are on xp32.
That's a shame to hear you're having so many problems. I don't think there's anyone not having some sort of issue though. You're not running too higher mem voltage are you? don't want to fry your chip after what some are saying.
Stock memory rated voltage. which is 2.2V.
Same, on ballistix
Couple more before I go to bed.
Phenom really strong on x264 bench and that little pi proggie from the BM sub-forums. See the relative threads for comparo's (I know you have anyway KTE :) )
http://img411.imageshack.us/img411/5871/x264mh1.jpg
http://img509.imageshack.us/img509/4305/pibmy4.jpg
http://img243.imageshack.us/img243/6792/lmkvy2.jpg
Very nice. :)
I've not benched plus 2860MHz max. No chance, even 2800MHz errors many times. But the last I tried was 2849MHz yesterday with that Pi app and it got near 6350s. I would've benched more had I the time as it wasn't erroring.
Try SuperPrime too if you can. Very good app I reckon. You should be around 1.20m in the 64M I'm guessin.
Also try running 4-4-4-4 1T and then go at these smaller benches again (incl EVEREST). You should be able to do it stock volts on the smaller benches at least (Pi/Pibench/wPrime/Pifast/EVEREST maybe even AquaMark). Not Cinebench/POV-Ray/2k6/2k1 though, they are RAM intensive and will throw errors.
Wow, 2.9ghz very nice.
Now i am hit a wall at htt 235mhz, 2.58ghz cpu. Please help me to go over it.
Well, I was running D9GMH@2.3V for almost one year, but that was Value DDR2-533 DIMM. Might be that PCB makes a difference and high performance PCBs are exposing D9GMH chips more than cheap ones...
For daily basis though I'm running them @2.15V 950MHz... (well cooled as well)
I've read your other post and TBH it surprised me that D9GHM can do 1200MHz 4-4-4 with only 2.2V.... Never saw this before, not form my samples at least ;)
Regarding Bandwidth vs Latency I can only agree with you here :)
I'm afraid you have got similar Phenom sample to mine then
same symptoms...
Try 10x238HTT with 8x or 7x NB and 1400HTT (or in never BIOS 7x for HTT)
If it will boot up then it's same as mine! (Which means BAD)
@mAJORD:
Fantastic results!
How much volts you needed for 2.9GHz?
Normal AIR or chilled water?
Congrats for your achievement! :)
