NP on the answer buddy! :up:
To my knowledge, the mobo's are the same - the ROG cooling.
Just for the record, the SB is almost a freebie with a decent sink. I opted not to water cool mine, due to it adding more resistance in my loop. I only inted on running a one loop system.
Check out the SB heat sink on page 7 of this thread to see if that might keep you happy? ;)
Putting MOSFET blocks in your loop is also restrictive. I would have been more inclined to include them into the loop, before I would the SB.
I hope my Thermalight sinks will be more than enouigh to keep them happy, and successfully relieved my loop of their cooling responsibility. (Pic's on page 8 of this thread)
If I were to do it over, I would get the non SE version I think, and set it up the exact same way I have now.
My build thread:
http://www.xtremesystems.org/forums/...d.php?t=160606
I am a CPU, GPU, and NB water cooling fan, if you are a 1 loop guy like me.
