Thank you for that, time to go and play.
Can someone give me a link to the BIOS/Drivers etc.? The Asus web site has nothing listed for the Maximus.
Thanks!
what setting should i put iin my bios to make a 3.8 stable all i have done is changed the fsb and the vcore to 1.6 but is to hot, which other settings should i change and to how much like the sb v to what nb to what etc...
Geee, guys... how about less whining and more looking? :rolleyes:
I don't even own this board but the first thing I've checked was Asus main ftp site - and there you go, both ROM available for download...
:welcome:
any suggestions?
T2k - thanks for you PM, it wont let me send any back, bloody forum but i have saved the FTP just incase,
Loco sent me it both on MSN and e-mail.
Got it on but it keeps lossing ym RAID array
OK, here is a small statistics about the memory modules people in this topic use with this board:
Ballistix PC8500
Cellshock PC8000
OCZ FlexXLC PC2-9200
Corsair XMS2 Dominator DDR2 800 (CM2X1024-6400C3DF)
Crucial Ballistix PC5300 CL3
OCZ PC8000 (Micron D9GKX)
What's the best kit money can buy for this Maximus (not insanely priced but reasonably priced, up to 1333MHz)?
Well 1 or stick of ether are not doing anything past 455FSB!
0401 BIOS
Settings all on AUTO
Stock cooling on it all, everything!
I'm kinda bord and gettting rather use to a laptop now so tempting to ditch it and just buy a :banana::banana::banana::banana: hot laptop
is there any problem with the 0405 bios??
I used 4 x 1Gb G.Skill 6400 NZ goes upto about 1000 quite happily. Not the quickest or the best but fairly cheap.
Im going to try my mcw30 at the weekend, pretty sure it will fit, i know the maze4 will fit as thats the one Clunk fitted
For 24/7...
3.618MHz@DDR2 1206MHz
http://aycu03.webshots.com/image/319...6284493_th.jpg
Can you post your settings using the "template" provided above? Many issues with 4 sticks on this chipset...got my third board that will not run 4 sticks with default settings.
Fugger assured me this was a non-issue...but I've yet to find a solution for running 4 sticks without errors...got same issues on Giga-DQ6 too.
My rams do 1142mhz @ 2.1v...prime blend stable, so it ain't the ram...even more towards it being the chipset/bios is the fact that two sticks work jsut fine(also giga board exhibiting same symptoms points in this direction as well...)
You, too, Hornet...I realize you're runinng jsut 2 sticks...but...
This is what i have done so far:
Vcore = 1.6v
CPU PLL = 1.8v
NB = 1.730
DRAM = 2.2v
FSB T. = 1.6v
SB = 1.175
SB 1.5v = 1.850
And my mult is set to 9x and my fsb to 445, so im running 4.0 Ghz, it will boot but is not stable my temp idle is 48C.... What can i do?? what should i change? thanks
My best score for the moment with Asus Maximus Formula SE and cascade :D
http://www.overclex.net/data/images/news/9.610.jpg
