^^^^ to the above poster... is there a link to that... would definitely help when i wanna go water cooling and have to take off the hard drive rack on the bottom part
http://www.silverpcs.com/index.php?c...558b37346179a3
http://www.frozencpu.com/products/56...t_-_Black.html
http://www.performance-pcs.com/catal...ducts_id=21294
http://www.svc.com/ex-34b.html
Look around on those sites for which one you want, there are different versions for different fans (80mm, 120mm)
whats the best household cleaner product that can polish/clean up the v2000/v1000s ???
Thought I would share some pic's of my silver V2000+, as it is probably gonna stay like this for a while.:D http://www.r5jones.aquiss.com/Pictures/P3080143.JPG
http://www.r5jones.aquiss.com/Pictures/P3080144.JPG
http://www.r5jones.aquiss.com/Pictures/P3080146.JPG
http://www.r5jones.aquiss.com/Pictures/P3080147.JPG
Far from the best camera in the world!
The V1000 was really tight for water cooling, this was a buddies of mine I did for him.
http://3dxtreme.net/other/Jeremiah/IMG_4991.JPG
Had to cut the front to allow the tubing to run to the bottom easier.
http://3dxtreme.net/other/Jeremiah/IMG_4996.JPG
My V2000 dwarfs it.
http://3dxtreme.net/other/Jeremiah/IMG_5000.JPG
This is my V2000.
http://3dxtreme.net/other/ontap/New%...e/IMG_4736.JPG
Notice both systems can be entirely be pulled out as one. So if there is a problem we don't even have to break the loop, can just remove the blocks and pull the whole setup in a few mins.
v2000 ftw :)
http://img183.imageshack.us/img183/7...85a2c2bav7.jpg
http://img183.imageshack.us/img183/2...9b0fbdbdw9.jpg
http://img144.imageshack.us/img144/2...eb5c18bix5.jpg
http://img147.imageshack.us/img147/4...7162bdbdg0.jpg
http://img144.imageshack.us/img144/6...4f0c29bcc6.jpg
in depth details, this is the earlier image don't mind the graphics card.:ROTF:
http://img147.imageshack.us/img147/8...ram2bg8ks8.jpg
Excellent paint job :clap:
:eek: the case is excellent :)
Here's my newest build:
http://img217.imageshack.us/img217/1...1223bq3.th.jpg
http://img230.imageshack.us/img230/1...1224hr7.th.jpg
http://img228.imageshack.us/img228/5...1231hg7.th.jpg
http://img210.imageshack.us/img210/11/img1232ss5.th.jpg
http://img221.imageshack.us/img221/1...1233jt6.th.jpg
http://img89.imageshack.us/img89/9259/img1234io5.th.jpg
http://img89.imageshack.us/img89/4651/img1235db6.th.jpg
http://img211.imageshack.us/img211/4...1225ru2.th.jpg
http://img217.imageshack.us/img217/9...1226hg8.th.jpg
Doesn't that one look good!
Hey, I've just sprayed my case, rad grill and fan guard. tidied up some wires (and managed to toast my fan controller....my ears are bleeding!!!!!!!!)
enjoy :)
http://i122.photobucket.com/albums/o...l/SSL24280.jpg
http://i122.photobucket.com/albums/o...l/SSL24288.jpg
http://i122.photobucket.com/albums/o...l/SSL24286.jpg
http://i122.photobucket.com/albums/o...l/SSL24283.jpg
http://i122.photobucket.com/albums/o...l/SSL24282.jpg
http://i122.photobucket.com/albums/o...l/SSL24287.jpg
http://i122.photobucket.com/albums/o...l/SSL24281.jpg
hope there's not too many ;)
Pet168,
Mate, you so need a red desktop. The blue on your monitor clashes badly.
Like your schema!
Just built a new machine and thought I'd post it on here. I spent several weeks perfecting it -- sleeving all cabling, cutting fan wires to their precise length, and so on. I'm using it mainly for graphic design, but I also do a little gaming every so often. My goal was a clean, professional looking exterior/interior that did not look like a home made machine. So no fancy LEDs, cathode tubs, or acrylic windows... this machine is all business.
Lian Li PCV1000
e8400 @ 4.0ghz / TRUE 120 / 27c idle / Both lapped
8800gtx @ 675mhz / HR03 GT / 48c idle / Both lapped
4 x 150GB Raptor / Raid 5
Asus P5E Motherboard
PC Power & Cooling 750watt Silencer
2 x Sanyo Denki Ace Fans
4 x Yate Loon SL Fans
http://dreamten.com/pc/01.jpg
http://dreamten.com/pc/02.jpg
http://dreamten.com/pc/03.jpg
http://dreamten.com/pc/05.jpg
http://dreamten.com/pc/04.jpg
http://www.performance-pcs.com/catal...ducts_id=21092
Here the one in Black ;)
http://hardware.feichti.com/gfx/quad...l-quad-007.jpg http://hardware.feichti.com/gfx/quad...l-quad-008.jpg
http://hardware.feichti.com/gfx/quad...l-quad-009.jpg http://hardware.feichti.com/gfx/quad...l-quad-010.jpg
And here my big Fileserver.
and in the near future the CPU,RAM, Raid-Controller are getting Watercooled ;)
Feichti
Watercooling the RAID controller? Ambitious.
Somehow, the while led's make your set up not look as bad even with the miles of cables :D
Good job!
Jor3lBR, i purchased those SATA cables off either Performance PCS or FrozenCPU...
i believe they were these...
Wow, that looks nice! The Maximus and maybe all ROG hav the double stack SATA and even when the clip's removed the $3 SATA's from the egg, plastic starts bulging. :( So I'm currently using the groovy red attention grabbers. Anyone have recs on some good quality SATA's wo/ clip?
Dreamtem, how is your San Ace staying on your TRUE?
I used zip ties and ran them through 2 holes on the fan. The pointed end of the zip tie is run through the whole and in between the fins on the heatsink, then I take another zip tie and attached it to the pointed end. Then I cut off both ends of the 2 zip ties. I did this on 2 corners of the fan and it holds in place quite nicely, and it almost looks like the fan is floating in place.
IMO it's a much cleaner solution than using the Thermalright wire bracket. Just make sure you use fairly thick/strong zip ties. Also, the sound proofing material I placed underneath it actually touches and supports the heatsink, so the zip ties and motherboard aren't being stressed from the weight.
