Whats Latest and Best BIOS for IP35 Pro and where I could get?
any Beta?
any Beta?
OK!...i think i broke the "code" on this Pro board for speed (overall system performance)!...FINALLY!:up:
one thing that i did not do when flashing to the 6 june (beta) bios was to flash the boot block!...well..today...i did flash with the "WB" switch and the results running PCMark 2005 was VERY satisfying...here are the before and after with PCMark 2005 as regards to not flashing and flashing the boot block.
net results...i am super close to the QuadGT at the same FSB (CPU Mhz) and memory clock speed!...QuadGT scored 9959...SO...i am within 78 points of my QuadGT...i call that a statistical tie!..YES!:up:
Built my new system this week
E6600 L646G batch
IP-35 Pro
2 x 1 gig OCZ 9200 Reaper (2 gig total)
EVGA 8800GTX
Scythe Mine cooler
Stacker 832 case with plenty of 120mm fans
Antec NEO HE 550 PSU
been overclocking today to see what the CPU and the mobo can do (i'm a bit of an OC noob tho haha)
Anyway, i reached 3.4 ghz @ 1.55 vcore, bit too much for me that, so right now i'm running it at 8 x 410 = 3,28 ghz @ 1.48
Orthos stable for over an hour now, I'll try to reduce the vcore a bit more
http://valid.x86-secret.com:80/show_oc.php?id=213403
So far the board has been great. My previous computer i ran an ASUS board, one before that i had the Abit KD-7 KT400 board with which i never had problems. Happy with this one sofar, i suspect the CPU + maybe my cooler are the ones at fault in not going further than 3.4 Guess the older Conroe's were better.
Of course if anyone has any tips :D
right now it runs at 53 degrees C under load (Core 1 and Core 2). It was up at 57, 58 when i was pushing at 3.4
also for the record, the OCZ Reapers booted up fine. no problems.
It's posted several time's throughout this thread.
http://pic.xfastest.com/hicookie/Abi...s/IP35P_11.rar
when you flashed the bios, what switches did you use ace-a-rue?
this is what i used since i did save the original bios to my USB thumb drive...if you do not have the capacity then change the "sy" switch to "sn"!
/py /sy /WB /cd /cp /cc /CKS
do not overclock while flashing...and...don't forget to clear CMOS after the flash is complete...load default bios settings after clearing CMOS, save and reboot back into the bios to change settings from there.
here is the "BEST" that i think i can produce from the Pro board..things could get better with subsequent bios updates.
normally you do not flash the boot block which contains all the memory straps and voltages unless the bios update is coded to flash that particular area...it is the last segment on a bios flash...if the area isn't flash during an update, you will see a green bar instead of a white bar on the very end of the flash line.
i used an USB thumb-drive.
if you want to find out what each switch does just type in DOS this syntax: awdflash.exe /?
Hey Ace-a-Rue, did flashing help at all with the wacky voltage issues?
I posted a few pages back that it does this to me too (even though I turned off the C1E and SpeedStep stuff); as a matter of fact, my vCore is currently at 1.26v...and when running two iterations of Prime95 it jumps as high as 1.375v (though CPU-Z and SpeedFan's voltage monitoring). Is that because of the CPUGTL Ref?
The bios 6 june (beta) is nice withe QuadCore :D
http://hwbot.org/signature.img?iid=25633&thumb=false
what is
C1E and EIST?
I'm using the shipped BIOS and I do have the EIST & C1E turned off, but I left the 'Thermal Protection" option enabled.
But yeah, it's bizarre; I was running Prime last night and just shut it off - while it was running it appears to have gone as high as 1.34v, but has now dropped to 1.3v...but the VID in the BIOS is 1.35v. :confused:
I'd remove the CMOS battery for 1/2 hour (also disconnect power from PC) and reflash the BIOS. Reset to Optimized default/Save/Exit. Boot into windows and recheck Vcore.
Don't have a schematic of this board so I can't tell you where to check for the actual voltage using a DMM.
Here in Slovenija price went up by 10%, wtf ????
