New Boy in town :toast: , Grim - get ready for a new entry in the 3060 List :slobber: :eek: :slobber:
Preview: 3.9GHz@1,47V and testing ... :
http://img258.imageshack.us/img258/1...m252wb7.th.jpg
Looks i finaly found a way to very nice clocks on the DFI ICFX3200`s :toast:
I,m new to this. How can i get teoseperte instance of prime 95 on ea
thnkas in advance
I know i'm a noob to this but how can i get 2 seperate instance to run in prime 95, tia scott
also is there a good guide to overclock the asus p5n32-e-sli and e6600?
tia scott
1 Attachment(s)
User Name:MVP JOR
Stability: Orthos blend 8 hours
CPU name E6300
OC: 3.22GHz
Stepping: B-2
Week: L625
Code: A705
Vcore: 1.288V
Cooling: Air
Cooler brand/model: Thermalright SI128
Motherboard: Gigabyte 965P DS3 Ver 1.0
Bios Version: F7
Operating System: XP 32
RAM brand: Corsair and OCZ
RAM rated speed: PC5400 and PC6400
RAM actual speed: 920
Latency: 4-5-4-15
Attachment 56598
Got my chip running on stock HSF and stock voltage, Please don't put this result to database yet. I have WC setup later this week, then will OC alot more. See the currently temp is COOKING, 79*C loaded. These HSF really sucks, i should lap the CPU IHS too.
User Name:hacgumyu
Stability: Orthos blend 10 hours
CPU name E6600
OC: 3.15GHz
Stepping: B-2
Week: L632
Code: A733
Vcore: 1.312V
Cooling: Air
Cooler brand/model: Stock HSF, WC soon
Motherboard: Asus P5B-Deluxe
Bios Version: 905
Operating System: Vista Ultimate x32
RAM brand: Buffalo Firestix
RAM rated speed: PC 6400
RAM actual speed: 900
Latency: 4-4-4-12
http://img376.imageshack.us/img376/4...ckhsfocnk9.jpg
1 Attachment(s)
username : SAFAN80
stability: ORTHOS Blend 8+ hours
CPU name: Core 2 Duo E6600
OC: 3375MHz
Stepping: 6 B2
Week: L642
Code: A289
Vcore: 1.55000
Cooling: Water
Cooler brand/model: D-TEK FuZion
Motherboard: Asus P5N32-e SLI plus
Bios Version: 0602
RAM brand: G.skill
RAM rated speed: PC8000
RAM actual speed: 1000MHz
Latency: 4-4-4-5
image resized from 2560x1600 to 1680x1050
you chip needs 1.55v to run 3.3ghz? even with water fuzion block!!! those newer batch chips really stinks, week after 40 is getting weak.
Guys i have the following problem..
I Oced my 6600 to 3400mhz, run orthos for 3 hours ( 49 degrees max - Using SCYTHE INFINITY ) and everything goes ok...All tests PASS.
However when i leave the PC on just running Windows after 1 hour the system HANGS !!!!
Any ideas ???
Im using 1.3V on the CPU..
Should i raise it more for a stable 3.4ghz ??
Hi, Guys. My post is not for statistics, but should be useful for many of You. Also, I need Your advice on the question, put below.
Well, yesterday my seller gave my the sample of 6600 L639A265-true uniq sample. I'm seeking the sample, which is to be stable at 3.8GHz (423x9-is perfect FSB for P5N32-E SLI).
Well, in comparison with L631A640 running stable at 3510 @1.51v (real),- I'd call this new one "Energy efficient".
For the first, it's stock voltage (auto) is 1.2000v (my L631A640 is 1.29v stock). This one is totally cold-27 degrees maximum while calculating Pi32M (Tt Big Water 745; 18 degrees room temperature).
What is much more interesting-this one makes 3.30GHz (367x9) at 1.18v(1.2125 set in bios) With this settings it was able to calculate 32M Super Pi.Temp didn’t exceed 28! Celsius.
Pretty good sample-one could say. I had such a thought, feeling excitement on the OC potential with higher voltage. But failed to reach such desired 3.8.
The problem was (you won’t even imagine) CPU’s extremely high temperature. After 3.3, I tried 3.6 (400x9); CPU demanded 1.365v (=1.32 monitored in bios and by Asus Probe). Load temperature raised up to 37º (SuperPi). I didn’t tru Orthos blending-for I don’t need 3.6GHz.
The next step was 3.8 (I set 423x9). The boot was successful at 1.475v (1.44 real). Pi 8M stable at 1.4875v (1.45). BUT... idle temp. rased to 40!!! Celsius. Orthos failed at 1st minute. 3 minutes under Orthos I could see at 3.73GHz. Probably, I could reach stability at 3.700, after increasing Vcore a little bit. Let me explain, why hadn’t I done it: because after 5 minutes in Orthos (1.45v) the temperature was !!62 degrees. I couldn’t believe that. Such a cold sample at nominal, while burning like hell with voltage not so high (for example, my L631A with 1.55=1.51real gives only 49º running Orthos).
Could You explain my such a mystery? I can’t tell, I’m such a skilled person in OC (only 5 years of expirience ;)), I had tried tens of samples of different CPUs – both AMD and Intel, and NEVER had seen such an intensive reaction for a slight voltage raising... I’m confused.
P.S. already thought about waterblock was mounted incorrectly. But: the trace, left on the heatsink surface by thermalgrease was flat and even; such low temp. at stock Vcore-it tells that waterblock works properly
As far as i know ORTHOS is ment to test the stability of the system while Super Pi is to test the ram stability...
Thats why in Orthos the CPU is 100% initialized and in Super Pi its not going more than 50-55%.....Thats why the temp is so low.
Ok steady at
CPU : 3400mhz / 1.35v
MEM : 850@4-4-4-14 / 2.15v
If you think 62°C is much under load you should check out the numbers you see in this thread.
Heat output of these C2D cpu's is quite shocking, especially when given some voltage.
Mine for example runs 47°C at 3.6GHz under load with 1.4V, 54°C at 3.7 GHz with 1.48V and 62°C at 3.85 GHz with 1.57V all in a 22°C ambient.
Load means Orthos small fft's at priority 9.
This is with mature watercooling.
Don't let temps frighten you, it hardly seems to affect stabilty of these cpu's.
Going through this thread you will see CPU's running at over 70°C still being Orthos stable.
Thanx for answers. Anyway, that sample doesn't suit me. Orthos-not more then 10 minutes at 3.7GHz... and 62-63 degrees (1.44v-real). To make it stable, it needs ~1.48v. I don't even want to imagine, what's the temperature level it will perform.
What I can't understand-is how my L631A makes only 52 Orthos load at 1.51v?
By the way, if thermal throttling starts from 62 degrees on the heatspreader surface?
Those rapid heat/temp gains for just a little more Vcore reminds me of the way the e4300's scale
Unlike the earlier samples that scaled linearly with voltage the e4300's I have tried and maybe some of the later cores dont like too much above default Vcore without some very serious cooling
Here is my entry for E6300. I have had it over 3.6 but longest Orthos SS was 4 hours. I'm submitting this until I can get a 3.6 SS with 8 hr Orthos.
User Name: dnottis
Stability: 13hr 40m Orthos Small FFTs
CPU name E6300
OC: 3570Mhz
Stepping: 6 B2
Week: L625
Code: A796
Vcore: 1.40v Bios
Cooling: Water
Cooler brand/model: Custom - in sig
Motherboard: Gigabyte DS3 rev. 3.3
Bios Version: F10
Operating System: XP SP2
RAM brand: OCZ
RAM rated speed: 1000
RAM actual speed: 1020
Latency: 5-5-5-12
http://www.3dxtreme.net/other/GB%20DS3/3570-1.40v.jpg
User Name: Zbomb5610
Stability: Orthos (10+ hours)
CPU: e6300
OC: 3500 mhz
Stepping: 6 B2
Week: L627
Code: A792
Vcore: 1.475
Cooling: Air
Cooler Brand/Model: Scythe Infinity
Motherboard: Gigabyte 965P DS3 Rev 3.3
Bios Version: F10
Operating System: Windows XP 32
RAM Brand: Micron Technology
RAM Rated Speed: PC4300
RAM Actual Speed: 1000
LATENCY: 4-4-4-12
http://aycu01.webshots.com/image/964...9708890_rs.jpg
1 Attachment(s)
Here's mine
User Name:Bootsy
Stability: Orthos blend 9 hours
CPU name X6800
OC: 3802
Stepping: B-2
Week: L617
Code: oem
Vcore: 1.55
Cooling: water
storm-d5-bix2
Motherboard: P5b premuim Vista edtion
Bios Version: 0402
Operating System: Vista64 Utimate
RAM brand: Mushkin 4GB
RAM actual speed: 975
Latency: 4-5-4-10
Xeon 3060 L631B115
so ... 1st stable result from my new toy, so it´s a new entry into the database ;) ... could be updated in a few hours :D
User Name: Pete@X
Stability: Dual Prime 24.14 8hours+ / 3DMark / Games / Name it :woot:
CPU name : Xeon 3060
OC: : 3870MHz (9x430) :slobber: :slobber: :slobber:
Stepping: : 6 B2
Week: : L631
Code: B115
Vcore: 1.5000 (Bios) / ~ 1.4500 under full load
Cooling: Water
Cooler brand/model: NexXxos XP Blocks
Motherboard: DFI ICFX3200-T2R/G
Bios Version: 02/12/2007
RAM brand: GSkill 2GBJS
RAM rated speed: PC6400
RAM actual speed: 860
Latency: 4-4-4-12
http://img258.imageshack.us/img258/8...20x4kb4.th.jpg
User Name: JohnnyV
Stability: Orthos Blend 11 hours
CPU name: E6600
OC: 3800Mhz
Stepping: 6 B2
Week: L632
Code: B173
Vcore: 1.47
Cooling: Water
Cooler brand/model: Watercool heatkiller rev 2.5
Motherboard: Asus P5N32-E SLI
Bios Version: 0903
Operating System: XP pro 32
RAM brand: G.Skill
RAM rated speed: PC6400 HZ
RAM actual speed: 950Mhz
Latency: 4-4-4-12
http://img01.picoodle.com/img/img01/...em_e2bbbf8.jpg
Hello, Here's My Entry
Username: Rommel
Stability: 8+ Hours Orthos
CPU Name: E6600
OC: 3906MHz
Stepping: 6 B2
Week: L630
Code: A962
Vcore: 1.5250
Cooling: Water
Cooler Brand/model: D-Tek Fuzion
Motherboard: Intel D975XBX2
Rev: 505
Bios Version: 2663
RAM Brand: Crucial Ballistix
RAM Rated Speed: PC6400
RAM Actual Speed: 868
Latency: 4-4-4-12
http://i169.photobucket.com/albums/u...3906_44412.jpg
User Name: foch3 -USA-
Stability: 9+ hours Orthos
CPU name E6600
OC: 3600mhz
Stepping: 6 B2
Week: L637
Code: A794
Vcore: 1.465
Cooling: AIR
Cooler brand/model: TT Big Typhoon
Motherboard: Asus P5B Dlx C1
Bios Version: 0910
Operating System: Vista Ultimate 64
RAM brand: G.Skill
RAM actual speed: 800
Latency: 4-4-4-12
http://members.cox.net/gtabor1/9%20hours%20orthos.jpg
User Name: n7/sardonic.n7
Stability: 8 hours+ Blend Orthos
CPU: E6600
OC: 3501 MHz
Stepping: 6 B2
Week: L632
Code: B173
Vcore: 1.45V bios/1.38V load
Cooling: Air
Cooler brand/model: Thermaltake Big Typhoon w/ Noctua NF-S12
Motherboard: P5B Deluxe WiFi-AP
Bios Version: 0711
RAM brand: Team Xtreem
RAM rated speed: 8000
RAM actual speed: 972.5
Latency: 5-4-3-4
CPU-Z validation: http://valid.x86-secret.com/show_oc?id=179300
http://img59.imageshack.us/img59/366...6600350ll6.jpg
User Name: douirc
Stability: 10 hours+ orthos
CPU name: E6600
OC: 3600MHz
Stepping: 6 B2
Week: L623
Code: B173
Vcore: 1.525
Cooling: Water
Cooler brand/model: Swiftech/STORM
Motherboard: eVGA 680i A1
Bios Version: P26
RAM brand: G.Skill
Latency: 4-4-4-5
http://valid.x86-secret.com/show_oc?id=179469
http://img124.imageshack.us/img124/5...1000jd3.th.jpg
User Name: theteamaqua
Stability: 8 hours+ orthos small fft
CPU name: E6600
OC: 3600MHz
Stepping: 6 B2
Week: L631
Code: F506T
Vcore: 1.47v during load in speedfan , 1.51v idle in speedfan , 1.54v set in bios (this board sux, vdrop too much)
Cooling: Water
Cooler brand/model: Corsair Nautilus 500 (heh, its 5c to 10c better than my Scythe infinity dual fan, and Bigtyphoon with 80CFM fan. not bad for $159.99)
Motherboard: Gigabyte-965P-DS3
Bios Version: F10
Operating System: XP PRO 32
RAM brand: OCZ
Latency: 4-5-4-15
PSU: Silverstine Strider 750W (well 4 PCI-E for sub $170 what more can u ask)
Ambient Temp: About 23C to 24C here in the room. not too hot outside, too. about 30C outside.
idle temp: 35c @ 1.51v
load temp: 52c ~ 53c full load @ 1.47v running Orthos Small FFT
CPU Z Validation:
http://valid.x86-secret.com/show_oc?id=179715
Screenshot:
http://i121.photobucket.com/albums/o...Shot0033-1.jpg
another one with names and what not:
http://i121.photobucket.com/albums/o...2/Shot0034.jpg
User Name: doom_st
Stability: 8 hours, 8 minutes Orthos
CPU name E6600
OC: 4200MHz
Stepping: 6 B2
Week: L627
Code: B042
Vcore: 1.47
Cooling: Custom Phase
Motherboard: Asus Commando
Bios Version: 0702
RAM brand: CellShock
RAM rated speed: PC2-8000 CL5
RAM actual speed: 1050
Latency: 4-4-4-4
http://img86.imageshack.us/img86/2043/shot0001so3.jpg
