I told you already, this board is not for CAS 4 !
Didn`t played with SuperPI, and the vDIM was 2.4v.
Btw, the kits are with D9GKX .
The MB was sent back, so i cant try more, or PI, sorry.
Nice kits, mate.
gskill F2-8500 HK 2x1GB
@ 750MHz 2.56v BIOS
http://img440.imageshack.us/img440/8...hkddr15eg0.png
kingston HyperX 9600 2x1GB
@ 775MHz 2.48v BIOS
http://img440.imageshack.us/img440/1...ddr1550te3.png
air cooling 2x80cm fans.
Odd, the Biostar does not have any problem running CAS 4....are you sure about this?Quote:
Originally Posted by M3kk
There are boards and boards,the DFI either doesn't like Cas 4,so stop comparing ;)
I have DFI DK P35 and now I have Biostar TP45 HP so I can say something ;) DFI was good to <=1200MHz Cas 4 or 5. Higher = crap ;) Biostar is good to almost 1400MHz Cas 5 :D I tested Cas 4 only to 1200Mhz, 5:6 divider, because I haven't any CPU to test it 1:1. I think that above 1200MHz CL4 is useless (5,4,4,x setting is better) - too much vdimm and not effects in performance.
Hmm, you ladies are a little bit too jumpy, am I hitting a nerve here?.... I see guys with DFI with CAS 4, I guess some can do it huh?
Team PC2-10400 CAS6 rated stuff @701mhz 5-5-5-18 at 2.675v
http://valid.x86-secret.com/cache/banner/437142.png
Nice one eva, what board was that on? Good to see those sticks reaching some impressive speeds.
DFI DK X48-T2RSB Plus http://i4memory.com/blogs/eva2000/8-...us-photos.html should have more results later next week :)
Brand : Crucial Technology
Modele : Ballistix PC8500
Chips: Micron D9GMH
Real Voltage : 2,8v (2,9v spi stable)
Timings : 5-5-5-15
Frequency : 754,1mhz (NL-record)
Sort of bench : CPU-Z Validation
Cooling : Air (Thermaltake 120mm fan)
Validation link: http://valid.x86-secret.com/show_oc.php?id=417998
http://i336.photobucket.com/albums/n...t/IMG_0442.jpg
http://i336.photobucket.com/albums/n...5001500mhz.jpg
__________________________________________
Modele : Ballistix Tracer PC6400
Chips: Micron D9GMH
Real Voltage : 2,7v
Timings : 5-5-5-15
Frequency : 750,6mhz
Cooling : None
Validation link: http://valid.x86-secret.com/show_oc.php?id=440957
http://i336.photobucket.com/albums/n..._0563groot.jpg
http://i336.photobucket.com/albums/n...4001500mhz.jpg
Brand : Team Group
Modele : Xtreem Dark PC6400
Chips: ProMOS (8-layer pcb)
Real Voltage : 2,8v
Timings : 5-5-5-15
Frequency : 714,2mhz
Validation link: http://valid.x86-secret.com/show_oc.php?id=418543
http://i336.photobucket.com/albums/n...IMG_0424-1.jpg
http://i336.photobucket.com/albums/n...4001428mhz.jpg
What divider are u using there MiBe??
Soon to be here maybe:
Crucial ballistix tracer 8500 2x1gb
Lanparty JR
2.4v for mem from bios, fast option
http://img378.imageshack.us/img378/9...e322ir8.th.jpghttp://img378.imageshack.us/images/thpix.gif
pending results
cellshock black 8500 GMH@742.5
and 4-4-4-12 697.9Mhz
http://valid.x86-secret.com/show_oc.php?id=448721
http://valid.x86-secret.com/show_oc.php?id=448739
no memest or something like that for timings
hey are both boot settings
voltage 2.68 real
OMG 4-4-4-12 @ 698MHz :shocked: W/ only 2.68v :eek:
Also thats the ram i'm about to order :D:D:D
Awesome work there :up:
M3kk
This is an open question.
G.SKILL F2-9600 plus GA-EP45-DS5, 80-mm fan - 1534Mhz 5-9-9-25 2х2gb 2.6v
http://s55.radikal.ru/i150/0811/a8/a6fd958cfb9et.jpg
Insane result for a 2x 2gb kit :shocked: only 2,6v :eek:
Great job! :up:
