As u see?;)
Mach II on CPU
Regular Mach on G-Card-r507 modded by :Zejtan
http://w1.825.telia.com/~u82507271/r507%20C.JPG
As u see?;)
Mach II on CPU
I hope it will work fine now...Some testing on Monday:toast:
http://w1.825.telia.com/~u82507271/DI11.JPG
Fint gabbax vad ska du lägga i rören svensk snö? :)
Just a little rule!
You don't post pics on tubes unless they have frost on them!
Okey :)
Na just some regular DIce:)
here's my current bench setup, in my new work area :)
here's the setup, while it WAS once working, hopefully i'll be able to revive it
http://www.digitalpose.com/mbr/1/150...8338600_vl.jpg
http://www.digitalpose.com/mbr/1/150...3305946_vl.jpg
http://www.digitalpose.com/mbr/1/150...6388147_vl.jpg
http://www.digitalpose.com/mbr/1/150...0558149_vl.jpg
http://www.digitalpose.com/mbr/1/150...3629989_vl.jpg
http://www.digitalpose.com/mbr/1/150...7600790_vl.jpg
you forgot the "/"
thanks, i always mess up once when posting :p:Quote:
Originally posted by MrSmash
you forgot the "/"
fixed now :)
I thougt i was a little bit crazy. But what i see here ist extrem crazy.
Sorry, my english is not very good but i tried my best.
I would like to show my X-Treme-X-Case.
Here are a few pics of it:
http://www.ersiedu.de/aqua/20.jpg
http://www.ersiedu.de/aqua/21.jpg
http://www.ersiedu.de/aqua/23.jpg
http://www.ersiedu.de/aqua/24.jpg
http://www.ersiedu.de/aqua/25.jpg
http://www.ersiedu.de/aqua/26.jpg
http://www.ersiedu.de/aqua/blau.jpg
http://www.ersiedu.de/aqua/rot.jpg
http://www.ersiedu.de/aqua/laufwerkstrom.jpg
http://www.ersiedu.de/aqua/netzteil.jpg
http://www.ersiedu.de/aqua/hddstrom.jpg
I know it is not finished yet, but i thougt you can see a lot of good ideas.
First....WELCOME TO XTREME MKFies! :D
:toast:
You belong here! That's X treme!
Very nice....very different...some great ideas there!
Please post more when you are finished and I hope you stick around here at Xtreme. ;)
hallo all my pc:banana:
http://membres.lycos.fr/m4inaction/m...te%20water.JPG
Oh, fine Case. I thougt the Eheim 1250 is a little to big for one cooler.
Aren`t it???
What a LAN machine! NOT!
MKFies,,,WOW,,,,Das Ist Sehr Gut!!!! Wunderbar!!! (Sorry if not perfect,,,I'm rusty on my Deutsch :)) Excellect work on that case,,tis a very nice piece of work! Can't wait to see it finished. :D:D:D:D
:toast:
EDIT: BTW,,,:welcome: to the sickness and the forum!!! :D:D:D
MKFies ! OMFG! thats IT I QuIT !!
Here is my first selfmade case:
http://www.ersiedu.de/Bilder/Monicase/041.JPG
http://www.ersiedu.de/Bilder/Monicase/042.JPG
http://www.ersiedu.de/Bilder/Monicase/044.JPG
http://www.ersiedu.de/Bilder/Monicase/045.JPG
http://www.ersiedu.de/Bilder/Monicase/046.JPG
I want a compact case like an Apple Macintosh. So i build an complete computer in an old case from a 17" CRT monitor.
There is an digital-sat card integratet and i use this pc to watch TV.
I hope, you like this case too.
WOW,,,,you have some talent there,,,,. An artist! :D:D
Man, what a cool idea!
Great job! :D
:toast:
wow...simply amazing case-building skills my man. welcome to the sickness...you are obviously already infected :toast:
i seen some amazing things here, and also, it is wonderfull what can be done with those mini-ITX systems...
I seen somone put a whole pc inside a ATX power suply!
Will try to finde link.....
nice system scanido! really clean lookin
Great job with the wiring and cables scanido!:D
:toast:
Very Nice! :toast: What coolant r u running? The blue in your case and coolant set each other off very nicely,,,and against the silver of your case......very nice to look at! :D:D
THanks all, much appreciated!
The coolant is simply 10% antifreeze and distilled water. I initially used water wetter and blu UV dye when i went water last year but had problems with that formula staining my tubes.
This antifreeze keeps my tubes clear even after half a year!
looks like a bit of work there jason.
lol, just realized thats 3 seperate boards...
in the middle one, it looks like there is no ram in it... or is that just the angle.
