When I first got into overclocking it was with an IC7-G Max and a P4 3.0c. Anyone know if the AW9D-Max will properly support the 7950 GX2?
Just recived my AW9D- MAX. :cool:
http://img159.imageshack.us/img159/2...0915ap2.th.jpg http://img180.imageshack.us/img180/8...0920ay1.th.jpg http://img180.imageshack.us/img180/3...0921il3.th.jpg http://img159.imageshack.us/img159/9...0919yf9.th.jpg
Just started with OC:
http://img180.imageshack.us/img180/3441/400cc3.th.jpg
Nightprowler:which BIOS are you using?
I`m using this:Quote:
Originally Posted by mykeos
http://www.xtremesystems.org/forums/...87#post1735287
what block is that one on the gpuQuote:
Originally Posted by Nightprowler_77
Its AquagrafX7950gx2Quote:
Originally Posted by thelostrican
http://img240.imageshack.us/img240/3...0799lq6.th.jpg
Can someone tell me how to disable speedstep/EIST on the AW9D MAX?
It's under Cpu feature in the advanced bios menu. what multi are you using?
Thanx. Should I set disable to all of the funktions in the advanced bios menu?Quote:
Originally Posted by Bootsy
Highest FSB so far is 425 with MCH 1.75. The screen goes black when rebooting at that speed.
I tested prime at 3.730ghz ( 10 x 370) stable so far, but coretemps are cloce to 80C :slobber: This was with EIST and all that stuff enabled
The mosfet heatsink on top need air circulation on it... you are using waterblock... considering putting small fan on it like what you did to the ramQuote:
that is where the heat need to go out....
:toast:
I got my board today as well. I thought there was gonna be more room between the PCIe slots but it's the same as i975Xa-YDG, 60mm only ;)
maybe a waterblock on NB would allow you to reach higher FSB,or at least better air cooling.eventhough, above 400 is quite ok and would be enough for me:)
maybe re-apply NB thermal paste with artic silver 5 or something like that... :hehe:
Yayy for me,mines coming today :)
Picked up on a few pointers from this thread so thanks,have the latest BIOS waiting already.
Hope to get some good clocks. :)
it is actually the same bios as 12 beta B02... no newer bios yet... :)Quote:
you will need to use the modded sli driver[in driver section] to get SLi to work with this board.... with sli bridge provided with the packages... there are a bit gain in score..Quote:
Originally Posted by Nettwerk
Tested it with 7600GT
My retail box abit AW9D-Max topped out at 440MHz FSB and is double super pi and prime 95 stable... I'm running the beta BIOS just like everyone else!
http://forums.legitreviews.com/image..._MAX_440pi.jpg
wow... nice 440MHz stable... cold booting at 440MHz or you need to use uguru to clock it up?
cold booting... it will cold boot up to around 450MHz, but it isn't stable.
Here is a link where I've been posting what I've been doing...
Tcase max is 85c so at least your not at the max. These conores really heat up when you up the clock speed even under water. I disbaled all the settings but I am no expert on this board, yet. I think my ddr667 ram is holding me back from hitting 400+.Quote:
Doa!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
that sucks!! my last Asus board was DOA and i spent 6 weeks waiting for ZZF to send a another one.Quote:
Originally Posted by situman
Any clock gen for this board? I could try, uguru clockgen its unstable.Quote:
Originally Posted by tictac
Looks like a nice board, may soon be replacing my DS3 :) Anyone know the technical specs on the CPU voltage regulation? 4phase, 8 phase?
Originally Posted by Apoptosis
What is this cold boot you speak of? Is it like the Asus with its temporary shut downs and stuff like that?
What???? there is the cold boot issue like the Asus board? I thought Fugger said there is NO cold boot.
Man!!! I ordered this board already. Someone pls confirm. I still have 1 day to cancel my order.
