Thanks for your time and information lawrywild
Quick questions. You have the onboard NICs disabled. What are you using instead?
And
What does the Virtulization Technology setting do?
And
http://www.intel.com/technology/computing/vptech/
I have a Belkin USB 54mbps wireless adaptor which I use instead ;)
Larry can't you set tighten timings for your ram?Quote:
With G skill 6400@350 mhz 1:1 I can run them at 3-3-3-12 and 4-4-4-12@438 mhz
I feel lucky with 24/7 3.5ghz@1.48v bios dual prime stable so
I have set the timings :stick:Quote:
Originally Posted by Mykou
I have crap adata stuff atm (stock ddr2-667 5-5-5-15) (cost £90 for 2GB off ebay) until I can afford better stuff.. (this isn't the adata extreme range stuff)
Ahh ok so Virtulization Technology really only helps if you are running some VM hosts on your PC. Like VMware and Microsoft Virtual machine software, otherwise its useless.
Cool i wondered about that
Also just to point out about your settings. If you set the PCIX Preq to 115 like yours is AND you are using the onboard Nic then it will fail. Just changed a couple of settings to like yours Inc the PCIX Freq and when windows loaded i had nio NIC. Changed it back and it works now. Must be somthing to do with the Onboard NIC using the PCIX bus.
Ya, depending on the board, at too high a pci-e freq, the onboard lan will crap out.Quote:
Originally Posted by topboy
The pci freq isn't really important, keep it at 105 or 110, whatever you want tbh lol..
ps: vmch and vich usually ( on my previous asus boards) allow you to run higher pci-e freq without loosing onboard lan
Hmm I didnt like the 1101 beta bios at all; very unstable. Is the 1101 official different? There is definitely a wall at 390-400 fsb but if you take out one stick of ram you can actually do 415 fsb; benchable 1M Super Pi
1101 was never in the BETA stage, it has only ever been an Official bios.Quote:
Originally Posted by syne_24
I get the same fsb "wall" (it's not really a wall btw, increasing vcore DOES help. A wall is where 1fsb increase will result in the board not POSTing or something) in every bios I've tried on this board
ok so i'm not going back to 1101 then. My wall is 415 right now even with 1.57v havent try 1.6 yet.
I really hope they unlock the Multi in this bios that and fix the stability problems. Im expecting my local dealer to get some X6800s and Bad axes in soon. Might jump ship and try that combo unless Asus fix this baord.
what really peeves me off is that ASUS have given the p5b-dlx an awesome bios with lots of memory timing options and multi adjustment.
The p5wdh is more expensive than the p5b-deluxe yet we get a crappy unstable bios.
I know thats another ghey part. I guess coming from an FX cpu I've been spoiled. But they should let you lower the multiply atleast so I can try that magical "7" on the DS3 board people are having. I know you can lower it in windows but it doesnt seem like the best approach.
I know thats whack too bro, I'm thinking of picking up one at Fry's to test it out. Are they having luck with it on a E6600 or lower?Quote:
I think they're doing better with e6600s than p5wdh's lol.. :rolleyes:
What's the highest FSB anyone can get to with this board, I dropped the multi in windows using CrystalCPUID and the highest I could get is 441 - anything above just freezes. Voltages didn't seem to make a difference. All on air ;)
I just read through Tony's post and I kinda get it a little bit. From what he's saying we are limiting around 400fsb is because of the NB chipset. When you raise the cpu fsb 400+ the chipset is maxing out and cause instability. I guess unless Asus give us an option to lock the chipset at 1066 strap; it's near impossible to overcome that 400 barrier.
syne_24, please link me :)
Originally Posted by matt1
I would like also ... :)
sorry I thought you guys read it before :)
http://www.bleedinedge.com/forum/showthread.php?t=22297
On the E6600's - it IS the chip holding us back NOT the mobos. I had a DS3 before my P5W DH and I was hitting the EXACT same wall with the DS3 as I am with the P5W. It's gotta be the extra cache. Hardly any of the 4mb chips are doing better than 1GHz OC on air without skyrocketing the VCore.Quote:
Originally Posted by Pjoeloe
So, if you want high FSB with a RETAIL E6600....you ain't gonna get it-not on air anyway. The chips don't do it. Desn't matter which mobo you have. This is my opinion and my experience. E6300/E6400 - different story. I'd buy another DS3 if I had one of those.
I don't even know if other forms of cooling would help. I don't have high temps at all, just requires way too much voltage after a certain point (around 3.4 ghz)Quote:
Originally Posted by Brahmzy
Yup. My experience EXACTLY. Sure you'll have the few folks that got a really good chip that can hit 3.6GHz on air without killing their CPU - but they're a VERY small percentage.Quote:
Originally Posted by miochza
well brahmzy, I don`t wanna have a discussion about this, I`m not such a guy :cool: ( franky I don`t give a xxxx what you or something think :cool: ) but I think it`s a bios issue. I don`t see the logic of needing major more Vcore or something else. We see in the near futureQuote:
Personally I don't think it's either
I think it is the Intel 965/975
Yes we will, and I don't give a hoot what you think either. :)Quote:
We'll soon find out how these new nVidia boards do. I'm tempted just to pick one up myself for an experiment.Quote:
