So which one is better? The Stilt modded BIOS ver IP96A803TSA, or official 914?
Good question. I think I'm going to do the Stilt mod. I'll have it done soon, so I will post back after. :)
Also, if anyone is having a HECK of a time finding 50k vr's, I have a few extras.
-Collin-
The Rebels have a modded 914 BIOS. I'm using that. Works great! See:
Biostar Mod BIOS Ip96a914.rh for TForce P965 Deluxe/965PT
My board won't boot with the 1066 strap using the 914RH BIOS.
Does 540 FSB with the Stilt BIOS.
Any suggestions?
Yes, be satisfied that you have a $100 board that will run a 540FSB. :rolleyes:
What do you mean? It doesn't boot at all?
Well, just thought I'd share that the stilt mod worked like a charm. I have to say though, it's a little odd that I had to crank on the VR for about 20 turns before it did ANYTHING. Then, it jumped from 2.3 to 2.7v! So I backed it off to a nice 2.46v to start. My Corsair 5400UL ram will be here tomorrow. Will post results as they come. :)
http://www.collindude.com/images/hosting/vmod.jpg
-Collin-
That's because you used a VR that was too high a value... 2K to 5K would have more control...
I was worried that it would start off too high of a vdimm though. Or do I have the wrong idea?Quote:
Originally Posted by JWilson
-Collin-
Voltage starts to increse below 2kohm measured on pot, so putting 50k pot is not good idea, jumps will be very huge and u will have less control on your memory. 10kohm will do the job perfectly.Quote:
Originally Posted by NinjaZX6R
Ok I try almost everything with stock BIOS (with one the board came).
I try all possible voltages, I also try with max PCI-E clock (I set it 200) using PCI Matrox card, but I can not go above 490Mhz no matter what I do, I didn't try single channel and I didn't try any of modded BIOS I will try that latter today
rest of rig is:
C2D 6300 628A147
2x512 Team Xtreem
ThermalTake BT
Enermax Liberty PSU
p.s. My PT is C2 revision
Its a good idea to start with fixed resistors.
Install a 100k resistor, test.
Install a 50k resistor, test.
Install a 25k resistor, test..
etc, until you find the point where voltage begins to climb. Old 3-pin fan headers and old power/LED connectors work perfect for swapping resistors fast without soldering.
I'm reasonably happy. But since I paid 128 Euro for the board I would prefer 550 FSB... :DQuote:
Originally Posted by uclajd
555 x 9 and I won't bother you again on this thread...
Let me try to be more precise:Quote:
The board will make an 'attempt' and then reset to 266 FSB. As said, the Stilt BIOS boots fine @ 398.
398!!! What happened to your 540????Quote:
Anyway, I'm booting at 7x500 with the 940Mod... May be due to memory and other things... Whatever....:rolleyes:
Hey guys, I have a question!
I did the vdimm mod and I'm still waiting for my ram to come in the mail today. There is something very odd going on though. Even when my computer is turned off, there is still ~2.5v going to the ram! Is this because there is no ram in the slots? The psu is on, but board is turned off...but I still get the vdimm reading. What's going on???
-Collin-
I'l boot with 398 to stay with the tighter strap and then use clockgen to crank the fsb up...Quote:
540 is here:
http://ziberia.1g.fi/kuvat/10.547.jpg/full
Since the board is very slow clock-per-clock compared to a P5B dlx I wanted to give the RH bios a try.
Where can i find this damn thing? All I can find is the Tforce965PT?
That's the same as the deluxe without the RAID. I have the PT.Quote:
Originally Posted by Lithan
-Collin-
where did you see that ? :confused:Quote:
Good question. The P5B Dlx outperforms this board by a good margin or what? :(Quote:
Originally Posted by metalazzo
-Collin-
I have a P5 dlx. SuperPi 8M is about 11 s. faster on the P5B @ 525 x 9 than Biostar :shrug:Quote:
An ATX motherboard is turned on simply by being connected to an atx PSU, the power switch simply turns on everything else.Quote:
Ok I manage to take same scrshots from win at 500 fsb but nothing else, if I run eny test win will reset, so maybe my CPU is FSB limited? I try with diferent BIOS its all same for me.
is that all ?Quote:
it seems to me that biostar has not the pcie@1X problem
if i had known, I would have chosen biostard instead of asux :/
I don't understand what's going on. I got this board all set and running with the Stilt volt mod, but the ram is totally unstable with the mod installed. I thought that corsair 5400ul loved voltage. I set the voltage to 2.4, 2.5, 2.6 and it still gets errors in memtest. I remove the mod, and the board can run 450fsb at 1:1 no problem. Why would the volt mod cause errors in memtest? This ram uses D9 fat body chips.
-Collin-
