take one stick of memory out and then interchange them to see if you get the same results.
do you have another type VC to try out?
have tried that , changed to a pci gfx and still no go even went and got another stick of ram but it wont show anything on screen = ( so dead e6600 ?
i was real carfull not to put the cpu in the wrong way aswell so running out of ideas here = (
does this mobo work with c2d regardles of wich bios it comes with ? or is it possible that i need a flash ?
This board is driving me nuts, would like to exchange it for a P5B. Grr. :mad:
How come?Quote:
Originally Posted by uclajd
I would really like to know cuz I've got a P5B Dlx right now and a P5W64 on the way. I thought the P5W64 would be better. I know it doesn't OC as high cuz of the FSB wall, but I'm looking more for 24/7 stability, speed and low temps. Even on my P5B Dlx I don't run my CPU over 400 24/7, so...
What do you (or anyone) suggest?
seems my board has a damaged pin in the socket = ( actually looks like it was there when i got it , its not bent but looks different then the other pins , cant find the right word , not damaged at the top but at the bottom of the socket.
Dont think i have caused this but cant be sure = ( going for antoher mobo monday as i cant wait for rma.
So what board to go with ? any suggestions all i want is 7 sata-2 gigalan and a the option to add a pci-e raid controller need 2x pci and 1x16x pci-e (for gfx)
Watercooled e6600 week 30 step A so i guess it will do around 3.8 ? so the board needs to to do 420-440 stable.
Any new boards being released soon ?
Would really appriciate any help deciding on a board as im going to be stuck with it for some time = )
I would hold out for the 680i. its coming soon. very soon.
FSB wall. 400 shouldn't be a problem on this board, but I need a lot more than that when I start phasing. :upset: Mine starts to die in the low 430's.
I think the P5W64's are best when paired with the X6800s and their fully unlocked multis.
Originally Posted by Makubex_GB
Hey guys, have had the motherboard for a while and flashed before to 0215. Today I just tried to flash to 0303 and now right after the XP logo loading screen it blue screens and reboots. I've tried reflashing 0303 a couple times, made sure I flashed while I had default settings set and such but it still I still get the BSOD.
I downloaded the 0215 bios again but when I try to flash it, it says the the bios is older (which it is) than the current bios and wont let me flash it. Anyone know how to go back to an older bios using the EZ Flash utility off of an USB drive???
Also, i just unplugged, switched of power supply, dissconnected 24 pin, took out battery, and took out bios chip. Im going to leave it out for a couple of minutes. While its out do any of you guys have any other ideas? I just got GW Nightfall and Company of Heroes so this delay is killing me lol :slap:
peace
Anyone got the new bios?
I don't see any value in pulling the BIOS chip. Afterall, removing the battery and jumpering CMOS reset is designed to clear the chip's settings. If you remove it, how can they be cleared?
Andrew
Originally Posted by TheReds
Originally Posted by aamsel
I know i know, i just under panic did anything under the category of bios problems lol. Anyone know how to flash back to an earlier bios? EZ flash with my usb key isnt doing it, and i dont have a floppy drive...
thanks
If all else fails, you can always pick up a cheap USB floppy drive, and then it is a breeze.
Andrew
Can you boot into Safe mode? If so then your problem lies within a driver and not hardware. If you cant get into Windows then I would look into finding another BIOS chip and using it to flash the board again. If you cant get a chip then buy a floppy drive for 8 bucks and use that to flash your board using the force flash commands.
Ya I tried getting into safe mode also with no luck. Looks like I will have to find a floppy drive...:( . Whatever. Oh, what are the force flash commands? :rolleyes:
Thanks guys, if anyone else has any ideas let me know!
thanks again:)
I appoligize, I was thinking VGA BIOS flashing. Hehehe.Quote:
I would download the BIOS to floppy and use the EZ Flash. Procedure found below:
http://support.asus.com/technicaldoc...Language=en-us
cool! Wait, will using EZ Flash with a floppy run into the same issue where it says the bios im trying to update to is older than the current one?
thanks for the help guys
No. With a floppy it will just flash whatever file you tell it to.
Andrew
sweet, thanks a lot guys. Time to salvage a floppy from my dads old laptop :banana: . Ill report back with the results
peace
A laptop floppy may be difficult if not impossible to hook up to your motherboard.
Andrew
....crap, laptop floppy drives dont hook up with 34 pin connectors? Maybe this is a sign that Im supposed to be doing my homework today instead of roaming the fields of Elona or commanding troops in major WWII battles.....or eliminating terrorist forces before they can set off a bomb, or capturing strategic military points until the other teams points count down while being hit by artillery.....Or...:D
Bios 0304
Dated on 01.11.2006
http://web54.nsi24.miniserver.de/wbb...tachmentid=123
Regards
changes?
thanks
304 already? Damn, I just flashed to 303 last night.
:( Annoying - same BS as 0303: Download = no go........:stick: why?:confused:Quote:
Originally Posted by īLotzi
Originally Posted by camouflage
download works FINE for me
regards
