Should OCZ Plat Rev. 2 work good as well...
Originally Posted by ugp
At the least, they should on a divider.
I tried 273 with a 9/10 divider and Prime Stable was a no go...but with a 5/6 Divider I belive it was...I can't remember...Quote:
Originally Posted by dnottis
I can get 310x10.0 with a 1:1 and be Bench stable and 1MB Pi stable but Prime fails in about 10 seconds...
I guess I will just need to spend my day off on Monday working on different combinations...
:woot: Finally made 24 sec 1m.:woot: [IMG]http://img219.imageshack.us/img219/6834/240hi.jpg[/IMG] Then ran this 32m at same everything but did not get quite far enough to save the screen before it 'froze'. Not very good 32m time...for now. [IMG]http://img219.imageshack.us/img219/6...012b9yz.th.jpg[/IMG]
This is my CABYE 0540 FPMW.
http://img484.imageshack.us/img484/5...014v0ky.th.jpg
not bad so far, pity that it works very hot :slap:
Update soon... :)
I tried putting 1.68V through my 146 Opteron and it idled at 55C :eek2:
Cant wait for my Watercooling... :banana:
This thing has some legs, [IMG]http://img458.imageshack.us/img458/1786/24e7rn.jpg[/IMG] Same settings and speed for a 32m, but once again it froze, immediatly this time. [IMG]http://img458.imageshack.us/img458/4227/p10306738ct.jpg[/IMG]
You need to remove your IHS then if you idled that high...it has poor contact...Quote:
Originally Posted by 5days
I idle at 30C on Air with a TT Big Typhoon and max load temps are 41C for me in a hot room.
EDIT:
OCCT Screen @ 300x10.0 @ v1.500
http://i5.photobucket.com/albums/y19...CCT-300x10.jpg
Heres my lowest Vcore @ 3GHz that is every type of torture stable
http://i16.photobucket.com/albums/b2...e/OCCT3GHz.jpg
:D :D
Any luck with prime yet?
Im just convinced some chips hate it..
Nah the Heatsink gets that hot too... which means heat is escaping the Core (meaning there must be atleast decent contact). Plus I'm not cutting th IHS on another CPU until it goes under DICE :p:.Quote:
I idle at 33C on Air with 1.40V going through it. I can tell this baby is going to be good under DICE. :D
my 146:
http://membres.lycos.fr/starostise/O...0mhz_1.53v.JPG
i have problem to have it stable il frequency is over 2700MHz whatever the vcore. do you think it's a bios problem or something else? the cpu?
EDIT: my mobo is a Dfi Ultra-D with 702-1 bios
How do we know what's your motherboard?
sorry, it's a dfi ultra-d with 702-1 biosQuote:
Originally Posted by bullit
I can't Prime at any clocks...it Primes for like 10 seconds LoL..Not sure why...but it survived OCCT so that is stable enough for me then.Quote:
I am able to drop volts even more and maintain stability even...
http://img472.imageshack.us/img472/4...rime4iv.th.jpg
Originally Posted by starostise
Is that prime stable or just Super PI though?
Dean
I do not know why nothing is Prime Stable for me...it doesn't like me... :(
thats from my Opteron146 0540APMW
& 3050Mhz Prime stable :)
Air Cooling Zalman cu7000
http://img223.imageshack.us/img223/6...mhz32pi1ex.jpg
PEaCE
What are your Read Preamble and Max Async Latency settings?Quote:
I Have the same problem here, i've got 3,122MHz 32M @ just 1,52v. But Prime fails even at 3 ghz, at the same voltage.Quote:
http://www.utforce.info/32M3122e.png
i think Prime it´s not always compatible with A64,there are cpus that at default speeds fail do pass 1 minute...
Well right now for OCCT Stable...Quote:
Originally Posted by LowRun
Max Async is at 9ns
Read Preample is at 8.5ns
just super pi, prime doesn't pass 10-15min with any frequency/vcore over 2700MHz, with occt it's the same thing. Occt passed at 3000MHz for 1.48V but i think it was luckQuote:
So this is not the problem, don't know then.Quote:
