You have an option in BIOS to enable IDE controller, I'm 100% sure...
Anyone have an idea why increasing IOH / ICH voltages make my board unbootable ?? Only at 1.11 - 1.12 i can boot to Win being at 210x21... :(
PS.
HARDWARE PREFETCHER - enabled or disabled ?
Adjacent Cache line Prefetch - enabled or disabled ?
A20M - enabled or disabled ?
Anyone using the new 1903 BIOS - can you tell me what the minimum voltage you can set for PLL is?
im hoping for some dry ice this weekend then il test out the new BIOS (hoping by some freak chance i can go above 250 bclk). if i update my bios will i lose my saved settings? it takes so long to write everything down
I'am using bios 1504 and it's working very well any one can tell me if the 1903 is better ? thank's
1903 probably sucks as much wang as any other BIOS in terms of overclocking. Asus ignore my requests for this board in terms of BIOS options etc, implement them in new boards I don't want to buy, and release new BIOS with "support new CPU" as change log. Short answer if you don't have problems with your current BIOS don't bother upgrading.
I can be stable at 221.5 X19 with bios 1504
http://www.zimagez.com/miniature/201...7h43-vcore.png
Anyone here using BIOS 1704? So far I cant see anyone use 1704, should I flash to a newer BIOS to get more stability in OC?
I am using v1802 . For what its worth v1704 was as stable at v1802 is now .
Not sure if this has been asked in the 100's of previous pages, which I have tried scanning through, but here goes.
Has anyone used aftermarket cooling for their NB and SB, something like a Thermalright cooler. If so could you please post a pick?
For me 1504 it's very stable i don't no if the news bios we have now are better ?
Im still a long time with 1504. Tried 1903 - make my system with the same setting not stable in Linx. Back to 1504.
@pcgamers i am on 1704 and its ok for stability for me.
for me, with the bios 1504, I have no problem "cold boot" with ram @2000MhZ but it's not stable
with the 1802, I have problems "cold boot" with ram @2000MhZ but it's stable with the same parameters....:confused:
I test 1903....
When I had my i7 920 D0, bios 1504 was very stable. But now that I have a Retail i7 980X cpu Batch#3003B475 i'm using bios 1903 on my R2E. I've had this motherboard for over a year now and its time to watercool it. I believe it deserves it. Thanks Firewire for the bios.
http://i572.photobucket.com/albums/s...m/P1010007.jpg
Custom Watercooling parts:
http://i572.photobucket.com/albums/s...m/P1010008.jpg
My Table of stuff:
http://i572.photobucket.com/albums/s...m/P1010006.jpg
XFX HD 5970 Black Edition:
http://i572.photobucket.com/albums/s...m/P1010229.jpg
Thanks guys for the all the replies..think i just stick with 1704 then, unless i'm moving to 980x [dreaming:)] . Nice Rig you got there psygnosi...you're using H50 or other watercooling kit? I can see H50 there, I use the same cooler but I cant get past 4.4GHz with my i7 930 chip due to heat problem...how about your temp using H50?
Hi pcgamers,
The corsair H50 will be replaced by this Swiftech Apogee XT Extreme waterblock:
http://i572.photobucket.com/albums/s.../P10100082.jpg
Mosfets and NB/SB blocks:
http://i572.photobucket.com/albums/s.../P10100062.jpg
close up of the 5970 Black Freezer GPU Block:
http://i572.photobucket.com/albums/s.../P10100072.jpg
Temp on the H50 is Okay but it does not compare to a dedicated CPU block like the swiftech. I get 35 on idle and 70+ on load for the Corsair H50. I need the load to get lower. Hopefully the swiftech will take me there.
Psygnosi
i got up to 230blk
but i seem to lose a memory slot after 226:shrug:
pcie@115
Hi,
sorry i'm such a noob in this kind of things, can we really get better OC on CPU by increasing PCI-E freq? I thought increasing PCI-e freq will eventually damages our GPU(s), am i correct? If it can be done, how much actually safe freq we can up over a stock of 100?
Sorry for so many questions...any old timer please help and I appreciate your help.
