Originally Posted by
iadstudio
So, if I have the Vista 64 upgrade from xp and I have to install xp first, this should work fine, right? (please say yes)
I knew about this and thought Vista had RAID drivers imbedded. I tought I'd try to install normally in xp, not having to deal with the f6 "add 3rd parts driver" thing in xp and once I got to vista I tried to create my array. Only thing is the matrix storage utility software that I remember from xp wasn't available for vista. I found a knowledge base somewhere that said if you edit the msahci registry to 0 before you switch from IDE to RAID in the bios, you should be fine, but I didn't know that until after I had a problem.
Long story short, from what I understand of your post, I should be able to install my RAID driver in xp, install OS on a single drive and create a storage array and then upgrade to Vista and be fine. Right?
