much obliged, praz
put a 6750 in and booted fine, only with 1 stick o f ram tho
but after an update took the 8500 n the second ram.
a happy bunny here
a lesson 4 the future - buying a wolfdale for the t2r - have an older processor handy.
cheers guys
much obliged, praz
a happy bunny here
cheers guys
I have replaced the OEM heat pipe assembly on my motherboard with a Enzotech Sapphire SLI water cooled NB block and an Enzotech SLF-1 solid copper SB heatsink with fan. I have also modified a Thermalright HR-09 U MOSFET Cooler to mount over where the factory had an aluminum block (I believe this is the PWM area). I cut out the thermal tape as per Praz's suggestion in another post, and then used Arctic Cooling MX-2 thermal paste on the raised components, before mounting the MOSFET cooler to the motherboard through the OEM holes in motherboard.
Also note, those two long chips that were inset on the MB from the aluminum block are being cooled with Swiftech MC 14 copper ram sinks, so that should help. Also, I have two 120 mm Yate Loon Fans directing cool air in from the top of my case (across MOSFET cooler, CPU and NB water blocks, and memory slots), and a 120 mm Scythe SFlex SFF21E fan exhausting air just above where the MOSFET cooler and exposed resistors are located.
I believe this setup will cool very well, but there were a couple small items that were under the OEM aluminum block that are no longer covered. I believe they are resistors, but am not certain. My question is this, do I need a heat sink over the couple of resistors which are now open to the air (used to be covered by the aluminum block on top left corner of MB), or will my current air cooling suffice?
i dont know if this has been covered or not , but this thread is way to long for me to check.
just wanted to know if the X38-T2R has any issues with crucial ballistix 1066 ? its not listed as compatible ram on there site .im about to order this board tonight.
thanks adya
do you mean the UT-P35 T2R? ;)
I ran my Ballistix 8500's at 600mhz 5-5-5-15 with 2.1v for months no problems.
no i just bought a LT X38-T2R on dfi's website it mentions compatible ram and crucials aint in the list . iknow some boards have issues with crucial ballistix so i am abit worried about wether it runs crucials ddr21066 with no issues.
edit* hahah soz i didnt relize i was on the wrong thread . thought i read x38t2r ill post somewhere else b4 i get into trouble.
I dunno, Crucial isn't on the P35 list either. I wouldn't worry about it.
How lame is the sticker on the NB saying void if removed. Ugh :rolleyes:
I have my Q6600 running at 24/7 voltages at 3.9, and I noticed a high pitch whine from the board, probably the PWMS. I stuck some ram sinks on the chips infront of the PWM heatsink, and I am ordering a 40mm fan for the PWM HS, but is there any way to get rid of the whine (other than lowering the speed)?
On a side note, it seems that a single MCR320 isn't enough for my system anymore. Time to add more radiators to my small P182 :(
I think you'll be fine there. If i remember correctly the stock heatsink only made contact with the PWM anyway.Quote:
What do you mean Crucial is not on the LP P35 list?:confused:
Hey guys I am having trouble getting my e8400 over 4.1 ghz stable. I have vcore set to 1.37 in bios, and I am a little worried about going higher.
Temps through coretemp register at about 67c @load.
Any ideas?
Thanks guys
Do you have the latest beta bios and have you played with the GTL settings in the bios?
http://us.dfi.com.tw/Product/xx_prod...RODUCT_ID=5497
Seems outdated and incomplete...oh well.
Yes, i've looked it myself now, cheers.:up:
What's your VTT voltage and your's cpu vid?
guys what's the difference between these?
• Intel ICH9R chip (SATA 1-6)
- SATA speed up to 3Gb/s
- RAID 0, RAID 1, RAID 0+1 and RAID 5
• JMicron JMB363 (SATA 7-8)
- RAID 0 and RAID 1
coz i was thinking of adding more hard drives (no RAID in mind atm)..
& which slot is best for optical drives?
E8400 02/14 BIOS
266/667 Strap/Divider
2x1GB OCZ PC2 9200 Reaper
XFX8800 GTX
C1E and VDROOP enabled. VCORE was set using VID Special Add leaving VID Control on Auto. Adjusting VCORE this way allows the voltage to decrease along with frequency while idle. Measured voltage at idle - 1.276.
Measured under load - 1.330. Frequency at idle - 2670MHz. Frequency under load - 4005MHz.
http://www.edgeofstability.com/image...main_266_s.jpghttp://www.edgeofstability.com/image...volt_266_s.jpg
http://www.edgeofstability.com/image...ram1_266_s.jpghttp://www.edgeofstability.com/image...ram2_266_s.jpg
http://www.edgeofstability.com/image...ock1_266_s.jpghttp://www.edgeofstability.com/image...ock2_266_s.jpg
http://www.edgeofstability.com/image...elay_266_s.jpghttp://www.edgeofstability.com/image...ture_266_s.jpg
Code:CPU Feature Page
Thermal Management Control................Enabled
PPM (EIST) Mode...........................Enabled
Limit CPUID MaxVal........................Disabled
CIE Function..............................Auto
Execute Disable Bit.......................Enabled
Virtualization Technology.................Enabled
Core Multi-Processing.....................Enabled
Main BIOS Page
Exist Setup Shutdown......................Mode 2
Shutdown After AC Loss....................Disabled
O. C. Fail Retry Counter..................0
CLOCK VC0 Divider.........................Auto
CPU Clock Ratio...........................9x
CPU Clock.................................445 MHz
Boot Up Clock.............................Auto
DRAM Speed................................266/667
PCIE Clock................................100MHz
PCIE Slot Config..........................1X 1X
CPU Spread Spectrum.......................Disabled
PCIE Spread Spectrum......................Disabled
SATA Spread Spectrum......................Disabled
Voltage Setting Page
CPU VID Control...........................Auto
CPU VID Special Add.......................110.86%
DRAM Voltage Control......................2.15V
SB 1.05V Voltage..........................1.070V
SB Core/CPU PLL Voltage...................1.55V
NB Core Voltage...........................1.50V
CPU VTT Voltage...........................1.10V
VCore Droop Control.......................Enabled
Clockgen Voltage Control..................3.45V
GTL+ Buffers Strength.....................Strong
Host Slew Rate............................Weak
GTL REF Voltage Control...................Disabled
CPU GTL1/3 REF Volt.......................N/A
CPU GTL 0/2 REF Volt......................N/A
North Bridge GTL REF Volt ................N/A
DRAM Timing Page
Enhance Data Transmitting.................Fast
Enhance Addressing........................Fast
T2 Dispatch...............................Auto
Clock Setting Fine Delay..................Listed Below
CAS Latency Time (tCL)....................5
RAS# to CAS# Delay (tRCD).................5
RAS# Precharge (tRP)......................5
Precharge Delay (tRAS)....................15
All Precharge to Act......................4
REF to ACT Delay (tRFC)...................28
Performance Level.........................7
Read Delay Phase Adjust...................Listed Below
MCH ODT Latency...........................3
Write to PRE Delay (tWR)..................14
Rank Write to Read (tWTR).................11
ACT to ACT Delay (tRRD)...................3
Read to Write Delay (tRDWR)...............8
Ranks Write to Write (tWRWR)..............4
Ranks Read to Read (tRDRD)................5
Ranks Write to Read (tWRRD)...............4
Read CAS# Precharge (tRTP)................3
ALL PRE to Refresh........................4
Read Delay Phase Adjust Page
Channel 1 Phase 0 Pull-In.................Enabled
Channel 1 Phase 1 Pull-In.................Auto
Channel 1 Phase 2 Pull-In.................Auto
Channel 1 Phase 3 Pull-In.................Auto
Channel 1 Phase 4 Pull-In.................Auto
Channel 2 Phase 0 Pull-In.................Auto
Channel 2 Phase 1 Pull-In.................Auto
Channel 2 Phase 2 Pull-In.................Auto
Channel 2 Phase 3 Pull-In.................Auto
Channel 2 Phase 4 Pull-In.................Auto
Clock Setting Fine Delay Page
Ch1 Clock Crossing Setting................More Aggressive
DIMM 1 Clock fine delay...................Current 1424s
DIMM 2 Clock fine delay...................Current 574ps
Ch 1 Command fine delay...................Current 974ps
CH 1 Control fine delay...................Current 512ps
Ch2 Clock Crossing Setting................More Aggressive
DIMM 3 Clock fine delay...................Current 1300ps
DIMM 4 Clock fine delay...................Current 486ps
Ch 2 Command fine delay...................Current 1024ps
CH 2 Control fine delay...................Current 400ps
Ch1Ch2 CommonClock Setting................More Aggressive
Ch1 RDCAS GNT-Chip Delay..................Auto
Ch1 WRCAS GNT-Chip Delay..................Auto
Ch1 Command to CS Delay...................Auto
Ch2 RDCAS GNT-Chip Delay..................Auto
Ch2 WRCAS GNT-Chip Delay..................Auto
Ch2 Command to CS Delay...................Auto
http://www.edgeofstability.com/image...266_orthos.jpg
http://www.edgeofstability.com/image...266_3d06_s.jpg
http://www.edgeofstability.com/image...66_everest.jpg
E8400 02/14 BIOS
333/800 Strap/Divider
XFX8800 GTX
C1E and VDROOP enabled. VCORE was set using VID Special Add leaving VID Control on Auto. Adjusting VCORE this way allows the voltage to decrease along with frequency while idle. Measured voltage at idle - 1.276. Measured under load - 1.330. Frequency at idle - 2670MHz. Frequency under load - 4005MHz. NB voltage can be reduced to stock if tRD is set to a straight 7 (no phases pulled in).
http://www.edgeofstability.com/image...800/main_s.jpghttp://www.edgeofstability.com/image...800/volt_s.jpg
http://www.edgeofstability.com/image...00/dram1_s.jpghttp://www.edgeofstability.com/image...00/dram2_s.jpg
http://www.edgeofstability.com/image...0/clock1_s.jpghttp://www.edgeofstability.com/image...0/clock2_s.jpg
http://www.edgeofstability.com/image...00/delay_s.jpghttp://www.edgeofstability.com/image.../feature_s.jpg
Main BIOS Page
DRAM Speed................................333/800
DRAM Voltage Control......................2.10V
NB Core Voltage...........................1.41V
DRAM Timing Page
All Precharge to Act......................5
ALL PRE to Refresh........................5
Channel 1 Phase 2 Pull-In.................Enabled
Channel 1 Phase 3 Pull-In.................Enabled
Channel 1 Phase 4 Pull-In.................Enabled
Channel 2 Phase 0 Pull-In.................Enabled
Channel 2 Phase 3 Pull-In.................Enabled
Channel 2 Phase 4 Pull-In.................Enabled
DIMM 1 Clock fine delay...................Current 156ps
DIMM 2 Clock fine delay...................Current 556ps
Ch 1 Command fine delay...................Current 868ps
CH 1 Control fine delay...................Current 623ps
DIMM 3 Clock fine delay...................Current 156ps
DIMM 4 Clock fine delay...................Current 623ps
Ch 2 Command fine delay...................Current 868ps
CH 2 Control fine delay...................Current 556ps
http://www.edgeofstability.com/image...0/orthos_s.jpg
http://www.edgeofstability.com/image...800/3d06_s.jpg
