Raising NB Voltage can help you with the higher FSB clock.
Raising VTT can help you lower your Vcore once you get a more or less stable voltage. It's also called FSB Termination Voltage since it's related to the FSB...
...But I had actually confused it with PLL, so it might not be as important for your overclock :rolleyes:Quote:
System Bus Input Supply Voltage, often referenced as FSB termination voltage (VFSB) simply the voltage the fsb is running on. logic levels on the fsb are relative to this voltage. higher vtt results in higher logiclevels and thus in increased noise ratios. increasing vtt might help overclocking.
