numbers looks good :up:
just to make sure can you check the drive? look for jumpers and scan over the manual, see if they require jumpers on there for sata2 support. i know with seagate to get higher numbers you have to removed the jumper, since it limits the hd to sata I. if you see benches it does make a difference.
