it's a cpu-z bug.Quote:
Originally Posted by 187(V)URD@
vcore was at 1.504V :)
I think I got a dud :stick:
Opteron 146 CAB2E 0545 CPMW
Only 2750 MHz at 1.5 V...getting load temps of 48*C :stick: :stick:
For those wonder'n what stepping neweggs got. The 148 i ordered friday came in today and is a CABYE 0543FPMW
k, a 146 CACJE 0546BPMW, won't prime at this yet but I have one foot in FX-57 territory :) :
http://www.0wned.org.uk/pics/shots/146-2g8spi32a.JPG
BIOS voltages: vcore 1.425, vdimm 2.8; stock HSF 30C idle, 42C load.
More vcore coming right up. Looks as if it's made for a bit of phase. Good.
Edit: priming with 1.45 vcore, 1.49 indicated.
Very nice!Quote:
Originally Posted by Mongoose420
Same as the 148 I got the other week that does 3GHz @ 1.5v stable,, how's this one going?Quote:
Jazz club. Nice.
Yea, I am testing mine out but got the same stepping from newegg
CABYE 0543 FPMW its a 148, so far at 2.5 w/ auto in bios for core voltage, not much i know, but i take it slow, will keep you posted.
Well mine tops out at 2950. My temps are a bit high. 50-51c with IHS off. I guess this is safe.
How do different multis affect the OCing. I haven't tried any except 10 and 11.
I'm keeping mine at 2930Mhz. It seems like the optimal frequency for my chip.
Same stepping as the 146 I got, with almost identical results.Quote:
Originally Posted by stone_cold_Jimi
Max I've had out of it is 2950MHz, but it's a great FX spec chip. :)
Chips with the CABYE 0543 stepping out of this thread(condenced for others convience since i was looking anyway). This list only goes back to page 135. Looks like 2.9ghz on air cooling isnt much to ask for:woot: .
gjwilds 148 got 3100 air
alpha1's 146 got 2966 water?
bbq's 146 got 2449*
lemonlime's 148 got 3300 vapo
yasoumalaka 148 got 2948 water
ChkDsk's 148 got 3000 unknown
szukalski's 148 got 3130 unknown
coop's 148 got 3100 on water(chilled?)
mouawad's 148 got 3400 on water chiller i presume? -2c
d4nnyOcean's 148 3080 on water
r2's 148 got 2916 on air
* He's not positive thats his stepping:slapass:
Too true! It's game stable at 2.8/1.45v and I've booted at 2.92/1.55v. Daren't do too much at that as the temps really start to climb with stock HSF. Gotta mod my case, then it'll be Vapo LS time. :cool:Quote:
Originally Posted by szukalski
Well I'm not sure I'm reinstalling windows because I was getiing some wierd shut downs at low settings. This happend to me before with my venice. At on point in time it would blue screen now matter what then I did a reinstall and no problems. I think it was from trying to go over ddr 600 1t with the patriot.
Well that was funny. I just reset everything to default in the bios to transfer some files before the reinstall and I got the blue screen. Maybe my hdd is messed up??? I have 2 new ones laying around so I can test this. If it is WD will be on my sh1t list.
Has anybody seen a good thread on windows corruption from too much OCing? Is it needed? I was always thinking my setting were screwed, until I got random reboots at stock with my venice. It would be cool if there was a program that would detect corruption. Is there one??
hi gys i bought my DFI NF4 ULTRA-D and my opty 144 that in ABIT AN8 ultra just run at 2950MHZ@1.71v , now in DFI i can run at 3GHZ@1.67v :banana:
just for pic im testing board yet >>> http://img368.imageshack.us/img368/5...167v7kp.th.jpg
Finnaly i put my Opteron 148 CABYE 0536GPMW in phase change and this are some scores, this cpu have cold bug at -28ยบ:(
For now this is the suicide shot:
http://valid.x86-secret.com/show_oc?id=56373
Super PI 1MB @ 3396Mhz:
[IMG]http://img357.imageshack.us/img357/7442/pi3zi.th.jpg[/IMG]
For now im trying to put at 3600 to suicide shot but until now no luck.
For day use i use at 3300Mhz: 300x11 - 1.6v - 300HTT 2.5-4-3-6 1T 1:1
Nice list Mongoose :clap: , we need more like this for relevent steppingsQuote:
I will update soon with a sreenshot, ATM I am @ 2980MHz torture stable using 1.408Vcore as reported in MBM, CPU-Z, CBId
I am using a modded Apex kit with 2 Papst 8 ~ 16 volt low speed 120mm aluminium housing fans @ 9 volt ( totally silent :D )
thx, yea its not a bad idea but to keep up with it would be a pain unless you did like a Mbot that should prolly work pretty good.Quote:
Originally Posted by alpha0ne
Im type'n on my CABYE 0543FPMW 148 right now at 2.8ghz 280x10@1.5vcore(lowest my 9nda3+ will go) 2x512 ocz3700EB@233 3-2-2-10 1T runn OCCT in the background(if it pass's while im surfing thats gotta be good right?) 43c Load temps from a slk948u+92mm tornado running at 4k rpm(still loud).
Played a stint at CoD and CoD2 for a couple of hours for my gaming 24/7 oc test and everything was fine so if OCCT comes back good i'll let it run here a few days before grabbing for more.
Also torched my old 2k1 maxbench score with my 3500 for kicks:D
http://service.futuremark.com/compare?2k1=8825624
Early next week sometime i'll have some max oc results with the tornado at full tilt for you guys as this is just testing for 24/7 overclocks.
Alright. I kinda 'lost' MS Paint :S I pasted this into a Word document. Central Brain Identifier. Don't worry, no viruses.
http://s5.yousendit.com/d.aspx?id=3A...E11TIWCE2P6YFH
For those of you who don't trust me, heres the specs
Vendor name: AuthenticAMD
Central Processor: AMD Opteron 2.00 GHz Processor
Platform: Socket 939 (939-pin CuPGA package)
Family: 15
Model: 7
Stepping: 1
Clockspeed: 2597.70 MHz
Series: 146
HT Clock: 259.77 MHz
HTL Speed: 1299.35 MHz
Clock Ratio: 10.0
Voltage: 1.472
L1 Data Cache: 64KB
L1 Cache: 128KB
L1 Instruction Cache: 64KB
L2 Cache: 1024 KB
CPU String: AMD Opteron(tm) Processor 146
OPN Number: OSA146DAA5BN
Processor Core: San Diego
Version: 4.1
Generation: 15.0
Model: 7.2
Stepping: 1
Process Technology: 0.09 micron DSL SOI
Revision: SH-E4
Announce Date: June, 2005
cheers!
Change your HTT/FSB Multiplier to 3x and try overclocking again...Quote:
Originally Posted by Bbq
Or did you want to show how much you overclocked the HTT by? :slapass:
I can buy a 148 CAB2E 0545 CPAW it is good steeping?
Another one for the list Mongoose :D
148 CABYE 0543 FPMW. Not as good as me 0540 146 but not bad at all. Stock Mach II. Time isnt that great, its 2x256 BH5 on 150 divider...
http://img.photobucket.com/albums/v6...oc/test148.jpg
Stepping: CABYE 0540 APMW
This was with Kingston 2x256MB TCCD, they quite suck. CPU was limited by RAM.
Cooling: TT Big Typhoon
Next week maybe more with modded Mach II and BH-5.
http://img204.imageshack.us/img204/1807/273448ag.jpg
My CAB2E 0545 CPMW is at 2700 MHz with 1.408 volts. Still needs burning in...Failed prime 4 times at this speed, 1st for 17 mins, then 22, then 35, and now its been priming for over an hour :) *touches wood like mad*
Is it just me, or do these chips run quite hot? I'm at 44*C under full load at these speeds and volts.....My venice which does 2610 MHz didnt exceed 44*C at even 1.53 volts. :confused:
Fedex just dropped my 148 from newegg....retail box stepping
CAB2E 0545CPAW ordered from newegg on Friday 12/9/05.
Will post back with results asap....may be a while though
cause the whole a64 thing is new to me.
my opty 148's been running a day now at 280x10 1.5vcore solid as a rock. I'll let her run here a couple more days before i crank it up some more.
http://img212.imageshack.us/img212/1...pass7wq.th.jpg
Originally Posted by Txaime
i just got a 148 from newegg with this stepping and was able to hit 3.03 (10x303) on it with 1.54v (in bios. cpu-z shows 1.52) with a zalman 9550
