Nice! I'm doing the same thing in a SG06, though for silence, and with only a HD5770 :p:
It's one of those cranky opinionated days so,
http://img517.imageshack.us/img517/8...t480521242.gif
zer0xCry, Very very nice. :up: May I suggest you put it the SFF gallery as well.
http://www.xtremesystems.org/forums/...d.php?t=254494
ADay2Long, Not bad but, you need some serious cable management there. I suggest you add your to the SFF gallery as well. ;)
Thanks.
Cable management and sleeving is part of Phase 2 aka me make money during summer to finance Phase 2. :up:
THANKS, WL, for the rules reminder - dang internet has me behind the pace today!
Nice SFF builds. @ ADay2Long ... actually your cable management looks pretty good to me. Just built a quick one in the LL Q09 case, and it's hard to handle the PSU cables unless you cut to custom lengths.
Dude! very nice! I feel the need to shake your hand. that is really well done. very clean and easy on the eyes. Im a fan keep it going please!
Is this the only MM case you have? i was looking into the extended UFO... how was the build process?
HA HA HA!!! Up yours Alienware... not that they don't make good computers.... or do they... HA HA!! :up: i enjoy!:cool:
That looks alot like a Mountain mods case. did you build that from scatch or mod a MM case?
Looks good!
so it turns out i need to do more reading! the rules are not to quote pictures to which i had just done.... sorry XS. will pay more attention!
EDIT by shazza: We'll forgive you, Th-I3riG02 ;) Posts fixed, quoted images deleted. Glad to see you are enjoying the builds here!
@knet370 After working on my V351B, I must say you've done an amazing job with that case....it's hard enough to hide all of the wires let alone WC it.
@ knet370 That is so clean and simple that it is startling!! Very nicely done. :clap:
Case: Fractal Design Define XL (redfined)
http://img39.imageshack.us/img39/2336/dscf2273m.jpg
http://img207.imageshack.us/img207/9828/dscf2278c.jpg
http://img546.imageshack.us/img546/8562/dscf2288.jpg
http://img151.imageshack.us/img151/9513/dscf2261y.jpg
http://img545.imageshack.us/img545/4...cf2321p.th.jpg . http://img407.imageshack.us/img407/4335/dscf2318.th.jpg . http://img812.imageshack.us/img812/3133/dscf2280.th.jpg . http://img96.imageshack.us/img96/4871/dscf2295p.th.jpg
LC configuration:
1 x Triple 140mm Magicool Hi-Flow Slim Radiator
2 x EK XT Dual 120mm Hi-Flow Radiators
1 x EK Supreme LT waterblock
1 x Swiftech Chipset waterblock
1 x Danger Den GPU Full Card waterblock
1 x Swiftech v2 Reservoir
1 x DDC 18w Pump with XSPC Hi-Flow Top
1/2" ID plumbing between radiators, res, pump
Dual 8mm OD plumbing to Legaris hi-flow Banjo fittings to CPU waterblock
Single 8mm OD plumbing to Legaris hi-flow Banjo fitting to Chipset waterblock
Single 8mm OD plumbing to Legaris hi-flow Banjo fitting to GPU waterblock
The usual drain-ball-valve and Bitspower fillport, etc etc...
Pump and fans controlled by the mCubed T-Balancer BigNG
Yate Loon SH's 140mm and 120mm
My Lian Li PC-50R @New Lian Li Club ThaiLand
http://image.ohozaa.com/i/c58/0gc61.jpg
http://image.ohozaa.com/i/f78/d9kv2.jpg
http://image.ohozaa.com/i/ad8/fx1r3.jpg
http://image.ohozaa.com/i/077/djn50.jpg
sorry sorry
EDIT: photos deleted ... see updates here.
Thanks....
1) Yes 4 fans...3 of which are in push pull and one without due to the drive bays as per pic.
Here's a pic to show the rad cut out....was a beast as the case is two parts...one steel and one aluminium....It was a challenge for me being a complete modding noob!:rofl:
http://i51.tinypic.com/14mdmjc.jpg
http://i53.tinypic.com/2il28fp.jpg
http://i51.tinypic.com/140igw.jpg
2) Noise for me is acceptable...I have the fans running on low 24/7 even if ripping or folding....cpu temps below 77...much better than last time when in the alienware case and how at 4.2ghz oc rather than 4ghz.
3)Side panel doesn't make that much of a difference.
@tipgo
Incredible cable management :up:
Kun Tipgo:Beautiful,clean, very interesting. Waiting to see your project X 58 EVGA
sudyod 5555
Wow, ZeroxCry, :banana::banana::banana::banana:ing amazing, im so jealous that thing looks sooooo beautiful
Heres an update :) i sleeved the wires and cleaned up some stuff, what do u guys think? :)
http://img89.imageshack.us/img89/1726/img2061c.jpg
Very clean and very very nice :D
http://img15.imageshack.us/img15/3623/cimg0454r.jpghttp://img840.imageshack.us/img840/1631/cimg0455hk.jpg
Sandy is in the house ! ;)
radiator - XSPC RX480 + 8 x Gentle Typhoon 1850 rpm.
motherboard block - EK Water Blocks EK-FB ASUS Crosshair 4
reservoir - 2 x Aquacomputer aquatube copper
pump - Laing DDC-1T 10W with Phobya silver nickel DDC top
GPU block - 2 x EK Water Blocks EK-FC5850 and 2 x EK Water Blocks EK-FC5850/5870 backplate
tubing - Primochill PrimoFlex Pro 13/10 mm.
fittings - Enzotech 13/10 mm. G1/4 compression
liquid - PrimoChill ICE Non-Conductive Water Cooling Coolant
CPU cooler - Corsair H5O + 2 x Gentle Typhoon 1850 rpm.
case - Lian Li PC-A17b
Here is my first attempt at water cooling.
I bought the XSPC RS240 kit from Frozen since it sounded like a pretty good starter kit. Some of these rigs in this thread have more in fittings than I paid for my whole kit. Wish I had that kind of bankroll :shocked: :D :p:
Rig specs in sig. Trying to decide which camp to go to for my video card upgrade now.
Here are a couple cell phone pics. Went to turn my camera on today and it made a noise and died. Something must have fried inside. It got a little wet when I spilled some liquid from the kit on it :down:
Have a couple fan wires I need to extend and I would like to find a modular PSU with flat wires because the back panel is extremely hard to fit now.
http://i956.photobucket.com/albums/a...g?t=1296155791
http://i956.photobucket.com/albums/a...g?t=1296155825
@ blackcat_mtb......
Is there a reason for two reservoirs in the GPU loop or was it for S & Gs – bling – or because you had them? :shrug:
I like the way laid everything laid out…..however never cared for “outside” rads, but find I may have to do one as my case is a mid-tower and I may not even have room for the pump! :shocked:
The two reservoir setup is a test to see if I have enough room in the case for two reservoirs. I intend to do another loop for the CPU and the top reservoir will be in that loop but until then I thought it would not hurt to include it in the GPU-MB loop.
