Since a few days my GPU temp isn't showing anymore, it's the 191.07 drivers it's their fault right?
Hey Kevin, I have a new one for you :)
http://lab501.ro/wp-content/uploads/...0/i650-RT1.jpg
http://lab501.ro/wp-content/uploads/...0/i650-RT2.jpg
I'm not sure what Nvidia has changed recently in their driver that is giving RealTemp a headache.
http://img384.imageshack.us/img384/9452/nvidiagpu.png
All I can say is that GPU temps still work on my 9800 GTX+ card. I'm using Vista x86 in this screen shot. When you install the drivers, make sure that RealTemp isn't running. That might be preventing the new driver from installing properly. :shrug:
Anyone with this problem, let me know what card you have so I can try and find out if this problem is card specific or can happen to anyone. That part of RealTemp hasn't changed in at least 8 months. Also let me know what OS you're using.
Monstru: The rest of RealTemp has been getting a work over recently and is almost ready for a new release. You look like a good candidate for a new version. Are you using XP in your screen shot. I recently found a bug in XP that seemed to be causing the missing core issues. The same RealTemp code would work fine in Visa or Windows 7. I'm hoping that I've found a way to work around the issue I found in XP and for all the long lost cores to finally be found. I'll try to send you a fresh test version by tomorrow.
Edit: I just noticed. Your CPU only has two cores. The APIC ID is different than what most dual core CPUs report so I'll try to get them lined up side by side. Your CPU looks more like a Quad core internally with two cores disabled. Given that it's an ES processor, you never know what Intel has created under the skin. I think that's why RealTemp is choking.
Can you check out i7 Turbo 6.94? That's been recently updated and should fully support your new CPU. It should show a 9X multi at idle if your Control Panel -> Power Options -> Minimum processor state is set to a low number like 5%. If you are using XP then you might need to set the Power Options to a mobile processor for your CPU to be able to use its lowest multiplier. When running a single thread of Super PI, you should see the multiplier on the hardest working core or cores approach 24X if you have C3/C6 enabled. I plan to drag the i7 Turbo code back into RealTemp so it would be nice to know that it works OK. Thanks.
Hi Kevin,
I am using Windows Vista x64 SP1. The stock multi is 24x, the Turbo multi is 25x, but I had that option disabled in the screenshots above. The CPU has 2 cores and hyper-threading, so it might as well be some sort of i750 with 2 cores cut, BUT do not forget that there is a IGP there somewhere, even if P55 does not use it. So the CPU might be built a little bit different in terms on chip placing on the PCB.
I will most gladly help in testing the newest release of RealTemp. For starters, I will try the i7 Turbo above to see what I get.:)
When I saw your screen shot my first thought was, Oh, sh_it, more missing cores!
On a dual core with hyper threading, the APIC ID would typically show 0123 with thread 0 and 1 belonging to core 0 and threads 2 and 3 belonging to core 1. Your CPU is a little different and reports 0145. It looks like RealTemp is saving some room in the GUI in case threads 2 and 3 ever show up someday. I'll have a look at this but I might not change anything until the retail chips are released. Maybe it's a sign that Intel is working on a way that they can run 4 threads per core. That would be interesting. :)
I'm running Vista x64 with an 920.
EVGA GTX 260 core 216 SC with 191.07 drivers.
Reinstall them w/o RT running might help or do you need a reg. fix?
Try installing your Nvidia drivers again with RealTemp turned off. If RealTemp is running and has the old Nvidia driver open, it might be preventing the new driver from getting installed properly. That's the only thing I can think of at the moment. I know someone with the same card that you are running and the same OS and he was having the same issue but now that issue is fixed. I don't yet know what's causing this problem.
Here you go Kevin. BTW, you have my email adress if you want to send me some beta version of RT? :)
The story bellow is like this - Idle most of the time, then PI1M, then WPrime 32M, then idle again.
Code:DATE TIME CMULTI STDEV MSR LOAD% NOTES
10/07/09 20:56:12 13.505 2.551 9.000 4.22
10/07/09 20:56:13 10.694 1.341 9.000 2.70
10/07/09 20:56:14 12.821 3.372 9.000 3.41
10/07/09 20:56:15 13.860 2.930 9.000 3.66
10/07/09 20:56:16 10.316 0.677 9.000 2.82
10/07/09 20:56:17 13.578 2.594 9.000 4.54
10/07/09 20:56:18 11.071 1.115 9.000 3.39
10/07/09 20:56:19 13.025 3.062 9.000 3.43
10/07/09 20:56:20 13.800 2.964 9.000 3.75
10/07/09 20:56:21 9.980 0.699 9.000 2.60
10/07/09 20:56:23 13.355 3.069 9.000 3.57
10/07/09 20:56:24 10.464 1.260 9.000 2.71
10/07/09 20:56:25 13.074 3.086 9.000 3.64
10/07/09 20:56:26 13.734 2.636 9.000 4.19 i650
10/07/09 20:56:27 11.004 0.664 9.000 3.22
10/07/09 20:56:28 13.121 2.706 9.000 4.44
10/07/09 20:56:29 10.347 1.314 9.000 2.70
10/07/09 20:56:30 13.118 3.321 9.000 3.40
10/07/09 20:56:31 13.562 3.022 9.000 3.66
10/07/09 20:56:32 9.958 0.713 9.000 2.53
10/07/09 20:56:33 13.465 3.114 9.000 3.52
10/07/09 20:56:34 10.374 1.334 9.000 2.66
10/07/09 20:56:35 13.146 3.333 9.000 3.41
10/07/09 20:56:36 13.573 3.016 9.000 3.68
10/07/09 20:56:37 10.028 0.675 9.000 2.53
10/07/09 20:56:38 13.318 3.212 9.000 3.46
10/07/09 20:56:39 10.372 1.346 9.000 2.62
10/07/09 20:56:40 13.251 3.248 9.000 3.44
10/07/09 20:56:41 13.524 2.435 9.000 3.71
10/07/09 20:56:42 12.822 2.809 9.000 3.14
10/07/09 20:56:43 13.809 3.031 9.000 3.56
10/07/09 20:56:44 10.959 1.390 9.000 2.75
10/07/09 20:56:45 12.768 3.188 9.000 3.31
10/07/09 20:56:46 13.217 3.043 9.000 3.73
10/07/09 20:56:47 10.144 0.740 9.000 2.67
10/07/09 20:56:48 13.273 3.173 9.000 3.54
10/07/09 20:56:49 11.125 1.471 9.000 2.76
10/07/09 20:56:50 12.713 3.103 9.000 3.33
10/07/09 20:56:51 13.802 2.885 9.000 3.84
10/07/09 20:56:52 9.899 0.848 9.000 2.54
10/07/09 20:56:53 13.467 3.079 9.000 3.53
10/07/09 20:56:54 11.158 1.405 9.000 2.85
10/07/09 20:56:55 12.942 3.047 9.000 3.28
10/07/09 20:56:56 13.717 2.935 9.000 3.76
10/07/09 20:56:57 9.960 0.718 9.000 2.55
10/07/09 20:56:58 13.361 2.444 9.000 3.49
10/07/09 20:56:59 11.382 1.473 9.000 2.72
10/07/09 20:57:00 13.370 3.039 9.000 3.31
10/07/09 20:57:01 14.398 2.512 17.000 4.02
10/07/09 20:57:02 15.710 1.643 9.000 4.70
10/07/09 20:57:03 13.483 2.970 9.000 3.69
10/07/09 20:57:04 11.334 1.325 9.000 2.77
10/07/09 20:57:05 13.107 3.014 9.000 3.30
10/07/09 20:57:06 13.733 3.005 9.000 3.66
10/07/09 20:57:07 10.144 0.680 9.000 2.60
10/07/09 20:57:08 13.276 3.143 9.000 3.49
10/07/09 20:57:09 13.542 3.019 13.000 3.54
10/07/09 20:57:10 9.955 0.556 9.000 2.44
10/07/09 20:57:11 13.929 2.208 9.000 3.87
10/07/09 20:57:12 10.087 0.700 9.000 2.52
10/07/09 20:57:13 13.310 3.132 9.000 3.50
10/07/09 20:57:14 13.709 2.863 9.000 3.70
10/07/09 20:57:15 11.123 2.033 9.000 2.62
10/07/09 20:57:16 13.997 2.862 9.000 3.73
10/07/09 20:57:17 10.025 0.722 9.000 2.55
10/07/09 20:57:18 13.666 1.686 9.000 3.50
10/07/09 20:57:19 13.840 2.948 9.000 3.65
10/07/09 20:57:20 9.812 0.745 9.000 2.47
10/07/09 20:57:21 13.180 2.962 9.000 3.80
10/07/09 20:57:22 10.018 0.634 9.000 2.56
10/07/09 20:57:23 13.230 3.140 9.000 3.52
10/07/09 20:57:24 13.900 2.776 9.000 3.68
10/07/09 20:57:25 9.812 0.769 9.000 2.43
10/07/09 20:57:26 16.556 1.368 25.000 11.44
10/07/09 20:57:27 18.837 0.606 21.000 20.81
10/07/09 20:57:28 16.180 1.483 9.000 8.35
10/07/09 20:57:29 14.518 0.992 13.000 11.94
10/07/09 20:57:30 18.353 1.129 9.000 13.44
10/07/09 20:57:31 15.541 0.650 13.000 11.45
10/07/09 20:57:32 13.588 1.626 17.000 13.42
10/07/09 20:57:33 21.637 0.986 9.000 14.48
10/07/09 20:57:35 13.151 1.798 9.000 6.82
10/07/09 20:57:36 10.457 0.509 13.000 7.18
10/07/09 20:57:37 13.802 2.022 9.000 5.24
10/07/09 20:57:38 9.979 0.682 9.000 2.54
10/07/09 20:57:39 13.224 3.146 9.000 3.50
10/07/09 20:57:40 13.713 2.895 9.000 3.74
10/07/09 20:57:41 9.972 0.671 9.000 2.51
10/07/09 20:57:42 14.271 2.144 9.000 3.81
10/07/09 20:57:43 10.003 0.646 9.000 2.65
10/07/09 20:57:44 13.736 3.067 9.000 3.50
10/07/09 20:57:45 14.017 2.065 9.000 3.65
10/07/09 20:57:46 9.598 0.521 9.000 2.39
10/07/09 20:57:47 13.975 3.146 9.000 3.83
10/07/09 20:57:48 10.197 0.722 9.000 2.52
10/07/09 20:57:49 13.438 3.107 9.000 3.53
10/07/09 20:57:50 13.673 2.368 9.000 3.73
10/07/09 20:57:51 9.482 0.342 9.000 2.39
10/07/09 20:57:52 13.717 2.994 9.000 3.68
10/07/09 20:57:53 10.203 0.618 9.000 2.54
10/07/09 20:57:54 13.484 3.160 9.000 3.48
10/07/09 20:57:55 13.515 3.096 9.000 3.66
10/07/09 20:57:56 9.457 0.462 9.000 2.37
10/07/09 20:57:57 13.762 3.015 9.000 3.60
10/07/09 20:57:58 10.012 0.769 9.000 2.47
10/07/09 20:57:59 13.393 3.096 9.000 3.50
10/07/09 20:58:00 14.050 2.897 9.000 3.71
10/07/09 20:58:01 10.698 0.927 9.000 2.68
10/07/09 20:58:02 13.932 2.806 9.000 3.99
10/07/09 20:58:03 10.438 1.302 9.000 2.70
10/07/09 20:58:04 12.571 3.417 9.000 3.37
10/07/09 20:58:05 13.791 3.053 9.000 3.64
10/07/09 20:58:06 9.456 0.441 9.000 2.37
10/07/09 20:58:07 13.324 2.367 9.000 3.79
10/07/09 20:58:08 10.410 1.311 9.000 2.61
10/07/09 20:58:09 13.142 3.361 9.000 3.33
10/07/09 20:58:10 14.085 2.978 9.000 3.67
10/07/09 20:58:11 9.551 0.300 9.000 2.41
10/07/09 20:58:12 13.360 3.030 9.000 3.68
10/07/09 20:58:13 11.204 1.335 9.000 2.79
10/07/09 20:58:14 13.098 3.334 9.000 3.39
10/07/09 20:58:15 13.793 3.006 9.000 3.65
10/07/09 20:58:16 10.062 0.709 9.000 2.50
10/07/09 20:58:17 13.533 3.133 9.000 3.47
10/07/09 20:58:18 10.493 1.352 9.000 2.59
10/07/09 20:58:19 12.925 3.321 9.000 3.42
10/07/09 20:58:20 13.971 2.948 9.000 3.67
10/07/09 20:58:21 10.049 0.698 9.000 2.47
10/07/09 20:58:22 13.478 3.146 9.000 3.45
10/07/09 20:58:23 10.381 1.315 9.000 2.64
10/07/09 20:58:24 13.150 3.374 9.000 3.36
10/07/09 20:58:25 13.999 2.200 9.000 3.64
10/07/09 20:58:26 10.020 0.726 9.000 2.53
10/07/09 20:58:27 13.434 2.617 9.000 3.45
10/07/09 20:58:28 10.403 1.344 9.000 2.56
10/07/09 20:58:29 12.900 1.998 9.000 3.37
10/07/09 20:58:30 13.523 3.069 9.000 3.64
10/07/09 20:58:31 10.119 0.731 9.000 2.56
10/07/09 20:58:32 14.043 1.384 9.000 3.45
10/07/09 20:58:33 10.405 1.353 9.000 2.62
10/07/09 20:58:34 13.486 3.283 9.000 3.80
10/07/09 20:58:35 13.575 3.061 9.000 3.65
10/07/09 20:58:36 10.061 0.751 9.000 2.48
10/07/09 20:58:37 13.504 3.074 9.000 3.49
10/07/09 20:58:38 10.425 1.297 9.000 2.65
10/07/09 20:58:39 13.055 3.325 9.000 3.38
10/07/09 20:58:40 13.997 2.934 9.000 3.67
10/07/09 20:58:41 10.153 0.755 9.000 2.58
10/07/09 20:58:42 12.702 2.324 9.000 3.54
10/07/09 20:58:43 10.438 1.333 9.000 2.62
10/07/09 20:58:44 12.881 3.349 9.000 3.38
10/07/09 20:58:45 13.689 2.988 9.000 3.70
10/07/09 20:58:46 10.130 0.680 9.000 2.54
10/07/09 20:58:48 13.528 3.095 9.000 3.48
10/07/09 20:58:49 16.012 5.494 9.000 9.17
10/07/09 20:58:50 12.755 2.193 9.000 3.54
10/07/09 20:58:51 13.733 2.996 9.000 3.68
10/07/09 20:58:52 10.142 0.712 9.000 2.55
10/07/09 20:58:53 13.476 3.108 9.000 3.52
10/07/09 20:58:54 10.420 1.314 9.000 2.65
10/07/09 20:58:55 12.834 3.396 9.000 3.36
10/07/09 20:58:56 13.797 2.857 9.000 3.70
10/07/09 20:58:57 10.071 0.670 9.000 2.51
10/07/09 20:58:58 13.513 3.044 9.000 3.49
10/07/09 20:58:59 10.391 1.359 9.000 2.58
10/07/09 20:59:00 13.332 3.294 9.000 3.43
10/07/09 20:59:01 14.660 2.431 9.000 3.96
10/07/09 20:59:02 11.730 1.768 13.000 3.01
10/07/09 20:59:03 13.260 3.069 9.000 3.61
10/07/09 20:59:04 10.422 1.343 9.000 2.62
10/07/09 20:59:05 12.832 3.424 9.000 3.38
10/07/09 20:59:06 14.025 2.948 9.000 3.68
10/07/09 20:59:07 9.983 0.725 9.000 2.51
10/07/09 20:59:08 13.509 3.074 9.000 3.56
10/07/09 20:59:09 11.073 1.555 9.000 2.68
10/07/09 20:59:10 12.674 3.079 9.000 3.32
10/07/09 20:59:11 13.764 2.996 9.000 3.66
10/07/09 20:59:12 10.285 0.703 9.000 2.69
10/07/09 20:59:13 13.173 2.808 9.000 4.12
10/07/09 20:59:14 11.764 1.201 9.000 3.66
10/07/09 20:59:15 13.464 3.005 9.000 3.68
10/07/09 20:59:16 13.973 2.401 9.000 4.50
10/07/09 20:59:17 12.777 1.684 9.000 3.99
10/07/09 20:59:18 14.668 1.617 9.000 5.31
10/07/09 20:59:19 21.209 0.920 9.000 12.58
10/07/09 20:59:20 13.991 2.117 13.000 4.45
10/07/09 20:59:21 14.756 2.185 9.000 4.70
10/07/09 20:59:22 14.397 2.008 9.000 5.14
10/07/09 20:59:23 13.459 2.280 9.000 4.82
10/07/09 20:59:24 13.184 1.522 9.000 4.28
10/07/09 20:59:25 19.569 2.873 9.000 15.82
10/07/09 20:59:26 14.152 2.426 9.000 4.83
10/07/09 20:59:27 11.632 0.854 9.000 3.93
10/07/09 20:59:28 13.676 2.657 9.000 4.07
10/07/09 20:59:29 12.101 0.870 9.000 4.05
10/07/09 20:59:30 13.609 2.238 9.000 4.07
10/07/09 20:59:31 13.729 2.794 9.000 3.98
10/07/09 20:59:32 10.022 0.666 9.000 2.70
10/07/09 20:59:33 13.097 3.058 9.000 3.71
10/07/09 20:59:34 12.270 0.789 17.000 4.07
10/07/09 20:59:35 15.987 1.653 9.000 5.03
10/07/09 20:59:36 14.844 1.676 13.000 4.95
10/07/09 20:59:37 12.805 0.685 13.000 3.85
10/07/09 20:59:38 14.623 2.397 9.000 4.39
10/07/09 20:59:39 14.377 0.398 9.000 4.90
10/07/09 20:59:40 16.352 1.239 9.000 5.59
10/07/09 20:59:41 15.319 1.651 13.000 5.26
10/07/09 20:59:42 11.904 0.439 9.000 3.47
10/07/09 20:59:43 13.724 2.172 9.000 4.06
10/07/09 20:59:44 12.670 0.631 9.000 3.63
10/07/09 20:59:45 14.224 2.030 9.000 4.78
10/07/09 20:59:46 14.678 2.372 9.000 4.95
10/07/09 20:59:47 12.364 0.889 9.000 3.59
10/07/09 20:59:48 13.497 2.606 9.000 4.35
10/07/09 20:59:49 11.758 0.870 9.000 3.30
10/07/09 20:59:50 12.635 3.130 9.000 3.63
10/07/09 20:59:51 13.095 2.617 9.000 3.84
10/07/09 20:59:52 13.384 2.029 9.000 3.93
10/07/09 20:59:53 13.881 2.422 13.000 4.31
10/07/09 20:59:54 11.473 0.882 9.000 3.74
10/07/09 20:59:55 15.328 2.105 9.000 5.14
10/07/09 20:59:56 13.689 2.523 9.000 4.54
10/07/09 20:59:57 11.350 0.653 9.000 4.04
10/07/09 20:59:58 13.722 2.230 9.000 4.75
10/07/09 20:59:59 16.397 1.138 13.000 5.88
10/07/09 21:00:01 16.483 1.502 9.000 6.70
10/07/09 21:00:02 16.544 2.097 9.000 7.52
10/07/09 21:00:03 15.791 0.510 9.000 5.54
10/07/09 21:00:04 13.519 2.461 9.000 4.70
10/07/09 21:00:05 13.095 1.770 9.000 4.29
10/07/09 21:00:06 13.522 3.025 9.000 3.80
10/07/09 21:00:07 14.950 2.830 9.000 4.39
10/07/09 21:00:08 11.016 0.985 9.000 3.07
10/07/09 21:00:09 14.591 1.687 9.000 5.19
10/07/09 21:00:10 14.074 1.157 9.000 4.19
10/07/09 21:00:11 13.817 2.279 9.000 4.44
10/07/09 21:00:12 14.612 2.300 13.000 4.70
10/07/09 21:00:13 12.658 0.230 9.000 4.05
10/07/09 21:00:14 14.690 2.013 9.000 4.85
10/07/09 21:00:15 12.346 1.239 9.000 4.18
10/07/09 21:00:16 19.930 0.741 9.000 10.26
10/07/09 21:00:17 14.073 2.302 9.000 5.31
10/07/09 21:00:18 11.722 1.127 9.000 4.05
10/07/09 21:00:19 15.277 1.829 9.000 5.43
10/07/09 21:00:20 11.331 1.193 9.000 3.56
10/07/09 21:00:21 13.393 2.355 9.000 4.61
10/07/09 21:00:22 13.792 2.426 9.000 4.73
10/07/09 21:00:23 11.002 0.542 9.000 3.63
10/07/09 21:00:24 13.770 2.555 9.000 4.27
10/07/09 21:00:25 12.337 0.917 9.000 4.10
10/07/09 21:00:26 18.147 1.982 9.000 8.22
10/07/09 21:00:27 14.302 1.934 9.000 4.82
10/07/09 21:00:28 15.230 2.041 9.000 5.40
10/07/09 21:00:29 15.403 4.963 9.000 7.07
10/07/09 21:00:30 10.613 1.243 9.000 2.84
10/07/09 21:00:31 13.210 3.168 9.000 3.51
10/07/09 21:00:32 14.033 2.863 9.000 3.73
10/07/09 21:00:33 11.708 1.986 9.000 3.15
10/07/09 21:00:34 13.925 2.664 9.000 4.15
10/07/09 21:00:35 11.237 1.030 9.000 3.44
10/07/09 21:00:36 13.612 1.205 9.000 3.91
10/07/09 21:00:37 14.614 2.170 9.000 5.33
10/07/09 21:00:38 17.474 3.680 13.000 10.79
10/07/09 21:00:39 21.868 2.674 21.000 27.97
10/07/09 21:00:40 18.751 5.377 25.000 27.11
10/07/09 21:00:41 21.573 2.807 25.000 27.82
10/07/09 21:00:42 21.408 3.322 21.000 27.99
10/07/09 21:00:43 18.735 5.364 17.000 26.95
10/07/09 21:00:44 20.911 3.987 25.000 27.79
10/07/09 21:00:45 21.941 4.117 17.000 26.94
10/07/09 21:00:46 23.572 2.607 17.000 27.56
10/07/09 21:00:47 21.324 3.406 13.000 27.82
10/07/09 21:00:48 18.881 5.223 17.000 26.98
10/07/09 21:00:49 21.261 3.172 21.000 27.75
10/07/09 21:00:50 19.238 5.134 17.000 27.17
10/07/09 21:00:51 21.377 3.757 9.000 14.95
10/07/09 21:00:52 13.426 2.818 9.000 4.25
10/07/09 21:00:53 10.810 0.617 9.000 3.49
10/07/09 21:00:54 14.094 2.194 9.000 4.61
10/07/09 21:00:55 11.881 0.983 9.000 4.71
10/07/09 21:00:56 13.507 1.477 9.000 4.43
10/07/09 21:00:57 13.970 1.305 9.000 4.83
10/07/09 21:00:58 12.719 1.389 9.000 4.05
10/07/09 21:00:59 13.989 2.702 9.000 4.43
10/07/09 21:01:00 20.113 1.386 9.000 11.34
10/07/09 21:01:01 15.100 1.416 9.000 4.97
10/07/09 21:01:02 16.701 2.226 9.000 7.10
10/07/09 21:01:03 10.667 0.681 9.000 2.89
10/07/09 21:01:04 13.631 2.569 9.000 3.97
10/07/09 21:01:05 13.227 0.806 17.000 4.19
10/07/09 21:01:06 13.072 2.195 9.000 3.98
10/07/09 21:01:07 13.471 2.663 9.000 4.37
10/07/09 21:01:08 10.152 0.648 9.000 2.69
10/07/09 21:01:09 13.019 3.171 9.000 3.51
10/07/09 21:01:10 13.007 1.233 13.000 4.20
10/07/09 21:01:11 12.501 2.267 9.000 3.81
10/07/09 21:01:13 14.512 1.800 9.000 5.61
10/07/09 21:01:14 11.504 1.027 9.000 3.82
10/07/09 21:01:15 14.334 2.288 9.000 4.59
10/07/09 21:01:16 24.914 0.014 25.000 89.42
10/07/09 21:01:17 25.000 0.000 25.000 100.00
10/07/09 21:01:18 25.000 0.000 25.000 100.00
10/07/09 21:01:19 25.000 0.000 25.000 100.00
10/07/09 21:01:20 25.000 0.000 25.000 100.00
10/07/09 21:01:21 25.000 0.000 25.000 100.00
10/07/09 21:01:22 25.000 0.000 25.000 100.00
10/07/09 21:01:23 25.000 0.000 25.000 99.98
10/07/09 21:01:24 25.000 0.000 25.000 100.00
10/07/09 21:01:25 25.000 0.000 25.000 100.00
10/07/09 21:01:26 25.000 0.000 25.000 100.00
10/07/09 21:01:27 25.000 0.000 25.000 100.00
10/07/09 21:01:28 25.000 0.000 25.000 100.00
10/07/09 21:01:29 25.000 0.000 25.000 98.35
10/07/09 21:01:30 19.998 1.412 9.000 8.38
10/07/09 21:01:31 16.274 2.385 9.000 5.73
10/07/09 21:01:32 13.843 2.472 9.000 4.80
10/07/09 21:01:33 11.670 0.428 9.000 4.00
10/07/09 21:01:34 17.698 2.164 9.000 7.99
10/07/09 21:01:35 13.243 1.410 17.000 4.55
10/07/09 21:01:36 15.782 2.347 13.000 6.31
10/07/09 21:01:37 15.548 1.735 9.000 5.39
10/07/09 21:01:38 13.750 1.179 9.000 4.51
10/07/09 21:01:39 14.361 2.086 13.000 4.64
10/07/09 21:01:40 14.415 0.534 13.000 4.51
10/07/09 21:01:41 17.629 2.100 13.000 7.13
10/07/09 21:01:42 14.176 1.930 9.000 5.42
10/07/09 21:01:43 12.974 0.959 9.000 5.77
10/07/09 21:01:44 13.544 2.555 9.000 4.07
10/07/09 21:01:45 10.858 1.124 9.000 3.03
10/07/09 21:01:46 14.011 2.396 9.000 4.38
10/07/09 21:01:47 13.639 2.599 9.000 4.43
10/07/09 21:01:48 10.837 0.817 9.000 3.21
10/07/09 21:01:49 13.553 3.145 9.000 3.49
10/07/09 21:01:50 10.506 1.331 9.000 2.65
10/07/09 21:01:51 12.630 3.281 9.000 3.59
10/07/09 21:01:52 14.492 1.146 9.000 4.03
10/07/09 21:01:53 10.069 0.863 9.000 2.55
10/07/09 21:01:54 13.412 3.030 9.000 3.67
10/07/09 21:01:55 11.873 1.243 9.000 3.39
10/07/09 21:01:56 13.302 2.624 9.000 4.07
10/07/09 21:01:57 14.139 2.215 9.000 4.44
10/07/09 21:01:58 11.613 1.300 9.000 3.48
10/07/09 21:01:59 13.887 2.553 9.000 4.10
10/07/09 21:02:00 12.553 1.266 9.000 3.78
Thanks, that log file looks OK. A solid 25.0 multi when fully loaded looks correct. If you set your Power Options -> Minimum processor state to a low number you should see the Calculated multiplier settle down at idle. You might need to enable C1E as well but usually not.
Stay tuned for the next version of RealTemp. I don't know if I can do anything on my side to fix the GPU temperature issue but I don't think I can make it any worse.
Good to know unclewebb,
prolly my stupid fault anyway.
EDIT: Just noticed that even EVGA Precision doesn't have temp. monitor anymore.
Also in my Nvidia config. screen I can't seem to find anything anymore about the temps. Maybe that's why?
C1E was enabled. Power pforiles were set on balanced. So I guess the results are ok. What puzzles me are the temps WAY to low from the sensor test.
I don't think it's your fault. :shakes: I have the same problem. Stumbled upon it some weeks ago, IIRC when 19x.xx drivers came out. Reinstalling didn't help. Uninstalling and then installing helped, IIRC. :yepp:
BTW, too many "IIRC", so I'll give it a try, cause right now don't have GPU temps anywhere but Everest.
EDIT: Uninst/inst didn't help. Used DriverSweeper http://www.guru3d.com/category/driversweeper/ then installed 191.07 and it works great.
Sorry for all this relatively off topic chat, but this is proof that missing temps has nothing to do with RT. Maybe there is many driver leftovers on this 18x.xx to 19x.xx crossover and regarding it has some power management additions, it could be the reason for mess up.
Monstru: The version of RealTemp you are using is not correctly recognizing your processor so it is not reading the TJMax value from the CPU like it should be doing. Perhaps Intel has lowered this. When RealTemp finds an unknown CPU, it takes a wild guess and assumes 100C. If that is wrong then your temperatures might not be reported correctly. I made a lot of progress today so I should have something ready for testing by tomorrow. Core Temp was updated recently. Maybe see what that says for TJMax.
donmarkoni: Thanks for figuring that out. Hopefully your fix works for other users. This bug came about somewhere around the late 180 series Nvidia drivers.
Ok Kevin, I will wait for the new version. I will also try the latest CoreTemp a little bit later.
Unwinder, the programmer of RivaTuner, has also had some issues lately with Nvidia's latest drivers and GPU temperatures. Here's his fix:
http://www.evga.com/forums/tm.asp?m=...key=%EF%BF%BD#
Thanks for that info burebista. :up:
I'm using 191.03 and my temps show up in Real Temp 3.30 RC 10.
EDIT: 150 page milestone has been reached :D
Here you go Kevin, with the beta:
http://lab501.ro/wp-content/uploads/.../RT-Beta-1.jpg
http://lab501.ro/wp-content/uploads/.../RT-Beta-2.jpg
Thanks Monstru, that looks better. Intel must be using TJMax = 105C on your CPU. Core 0 has always been the most accurate temperature wise. How does this look now compared to your room temperature? These new Dual Cores are going to run a little cooler than the Quads but it might still be a couple of degrees too low. I'll try to change RealTemp so it correctly calls your CPU a Core i5 instead of a Core i7. Intel has so many CPUs that are overlapping each other in specs these days that it's becoming more work for programmers to keep them all sorted out. :)
Can you try running this program and post your results?
http://www.fileden.com/files/2008/3/...507/MSR1AD.zip
It reads Model Specific Register (MSR) 0x1AD which should show me how many bins of turbo boost this CPU is capable of. I don't have any Intel documentation to go by so it's always best to ask the CPU to tell me what it can do.
No problem Kevin, I will use the program and report back. My room temp is 25 oC.
Hey Kevin, I ran MSR1Ad and it says
1818191A
With a room temperature of 25C, it looks like your sensors read a little on the low side. The original Core i7-9xx series had very consistent and accurate sensors at idle and at TJMax. I can't yet say the same thing based on some of the socket 1156 screen shots I've seen. I hope Intel didn't decide to cheap out again like they did with the 45nm Core 2 sensors.
I've also seen another issue recently where on a retail Core i7-920, the TJMax written into the processor was 93C instead of the usual 100C. This resulted in temperatures being reported that looked to be too low compared to every other Core i7-920. More core temperature games? :shrug:
Edit: Here's how those numbers in MSR 0x1AD translate. There are 4 numbers in that MSR that correspond to the maximum multiplier available when 4, 3, 2 or 1 core is active. It might just be a coincidence that you have 4 numbers in there or another sign that your CPU might have started life as a Quad. Maybe it's like an AMD chip where the mobo guys found a trick to unlock some hidden cores.
Those numbers are in hexadecimal and so the numbers in decimal are 24, 24, 25, 26
For your CPU, when two cores are active, the maximum multiplier is 25 which you already know. When only one core is active, the maximum multiplier can go up as high as 26. If you can disable a core in the bios, you should be able to see the full 26 times multiplier all the time. The other way to get this is to enable C3/C6. This allows one core to go to sleep which Intel classifies as an inactive core. When running a single threaded activity, you should see the multiplier continuously cycle between 25 and 26. The multiplier on the hardest working core will approach 26 but any background processing will activate the second core and kick you back to a 25 times multiplier. This multiplier cycling is happening hundreds of times a second based on load when C3/C6 is enabled. Post a screen shot of RealTemp or i7 Turbo if you can see this happening.
http://www.fileden.com/files/2008/3/...alTempBeta.zip
Lots of minor changes behind the scenes including better support for Intel's new socket 1156 CPUs as well as their new Core i7 mobile CPUs.
Changes include:
-the use of the i7 Turbo method to calculate the multiplier for all CPUs. If this causes a problem for older Core 2 CPUs that may have the internal timers disabled then you will need to add this line to the RealTemp.INI file to use the previous method:
MSRMulti=1
The new i7 Turbo based method when used on a modern Core i7 or i5 CPU with C3/C6 enabled in the bios will be able to show you the multiplier of the hardest working core which in my opinion and Intel's opinion, best represents how fast your CPU is actually working. This method also works well with Core 2 mobile CPUs that support Intel Dynamic Acceleration (IDA).
The i7 Turbo method allows Super Low Frequency Mode (SLFM) to be displayed correctly on the Core 2 mobile processors that support this feature. A multiplier of 3.0 at idle when this feature is enabled is typical.
-the elapsed timer has been fixed so it shouldn't lose time any more.
-a work around for an incorrect bios setting was found for the missing core issues that sometimes plagued Quad core owners.
-a Task Manager based load meter (TM Load) was added as an option. The original load meter is based on the percentage of time a CPU is in the C0 state which is very accurate for many CPUs. Mobile CPUs work completely different and this number does not accurately reflect the load of the CPU at idle so now you have an option.
-the XS Benchmark was changed slightly so now you can Cancel it while it is running and you shouldn't see any more, "Program isn't responding" messages when it is fully loaded testing.
-an option to display your temperatures in Fahrenheit was added. Just add this to your RealTemp.INI file.
Fahrenheit=1
-the Settings window has been reworked for better consistency in preparation for possible future upgrades.
-only maximum VID is displayed in the Settings window for Core 2 owners for less confusion. This option will display real time VID on the main screen.
-an option to Disable Turbo Mode on Core i5/i7 CPUs.
etc., etc., etc., etc.
Lots of changes so if you see any problems let me know as soon as you can so I can get things fixed up. An official release is way overdue which I'd like to do in the near future. The RivaTuner plugin is next in line for an upgrade to better support the new CPUs.
Thanks rge, burebista, Monstru, somebody on TPU and my other contacts for your infinite testing and for helping to make RealTemp better and more compatible with a wider range of CPUs. :clap:
