Originally Posted by [O-CuK]MCRacer
I have two Opteron 170s. I have a 0550 VPMW and also a 0550 UPMW. Both steppings are reported to be good clockers.
I got the VPMW first and right out of the box I managed to get it running at 2.8GHz (SPD timings for RAM) at a Vcore of 1.44v on the stock AMD HSF that comes in the box. This chip is F@H stable on both cores as well as stable for COD2 and FEAR.
I tried to run the VPMW under my Mach II GT but it wouldnt clock past 2.4GHz or 240HTT. So it has the cold bug :(
I bought the UPMW as I wanted to get hold of a chip that didnt have the cold bug.
Anyway I threw the chip in my rig under the stock AMD HSF and I couldnt get it past 2.4GHz for love nor money, and it wouldnt even boot to Win XP past 2.5GHz... I initially assumed it was a poor chip within the batch.
But then I started reading this thread and it was comments made by mag|c on Data and Drive strength that caught my eye. I read about his testing and I decided I had nothing to lose and tried his 5/1 recommendations..
WOW what a difference this made. Basically it cured all my stability issues and the UPMW now runs at exactly the same settings (2.8GHz) as the VPMW and is 24/7 stable for F@H and plays COD2 and FEAR not problems...
So a big thanks to mag|c for making his posts and let others know that it is worth fiddling about as even if you think you have taken the ram out of the equation to find max overclock by using a divider, it is not always the case. My ram runs 280FSB without any tweaking of the ram settings under the VPMW. My UPMW wont go past 2.4GHz on SPD settings even using a ram divider... But change the Data and Drive settings and BANG, problems solved, its like the chip has been given a new overclocking ceiling.
Cheers mag|c :toast:
