good to know
good to know
Well I've managed 275 X 10 with 1.456Vcore & stock Vdimm. RAM is on 133 divider, upping the Vdimm didn't help any.
Looks like my CPU tops out at 2750, Try 276 X 10 & BSOD even though Memtest is ok. At 9X I get 303 (2727MHz) but have to drop the RAM divider to 100... :(
what ram are you using?Quote:
Originally Posted by banshee[OCAU]
At the moment I have some Corsair XMS3700 (3, 4, 4, 8) and some PQI Turbo 3200 (2.5, 3, 3, 7). I am currently using the PQI as it clocks better than the Corsair on this MB. Neither of them go much higher than 200, but the Corsair I have to severely underclock once the HTT goes up (<200), where the PQI can go to ~220MHz before I have to drop to the next divider.
I would like to find out what memory works best with this MB so I can get some...
hopefully Tony can modd this Bios so we can get more voltage.:toast:
I love this board it runs rock stable but my x2 4400 just needs a lil bit more juice!! :)
http://home.comcast.net/~elcangri/4400260fsb.bmp
Im trying to get hold of the latest AMI editor, base code has been changed so the editors I have here will not open the files.
I have done the vcore mod on mine here ansd it works real well...maybe a quicker option for you
Does anyone know where to measure the Vdimm on this board? I got the DDR booster to work in this, but my bh-5 hits a wall at around 3.6v's.
I would love to get it right up to the wall but I need to measure with my MM to do that.
Not bad, I got my setup running now.
Opteron CCBWE 0550 UMPW 165 @ 300mhz @ 3xhtt @ 1.44v
166/200 for Mushkin Redline 4000 2x512 @ 3.2V 2T
Priming it now. Not bad. I used bios 402 and it is way better than 201.
Aside from that like the mobo so far. Just need to tweak it a little more to get more performance out of it.
Nice to hear that news, can u give us your modded bios which allows more Vcore?Quote:
Originally Posted by Tony
You didn't read Tony's post correctly, he did the hardware vmod, no vmodded bios yet.Quote:
Originally Posted by Pumbaa
Alright so the DDR booster is flaky on this board (I guess that is why it is not supported).
Anyone know how I could go about getting a Vdimm mod for this?
just in case the volt mod is here--> http://www.vr-zone.com/?i=3135
That has already been done to this board, now I just need to find a Vdimm and I will be in heaven.Quote:
Originally Posted by xploit
10 days left beforce this board will fly out of the window :D
Gonna buy a ABiT AT8 X32 ( RD580 ). I should be released at the 24e of febuari.
If that one is not for sale i can also thy to but a DFI with the RD580. But this asus has to go its working on my nerves.
We all waiting to see if the rd580 is really worth it.
if u whant te run crossfire its worth it. Because it has 16x pci lanes per VGA card. Where the Rd480 Had only 8x.Quote:
Originally Posted by althes
And i should clock better. ( Maybe because its build for the AM2 ? And maybe the AM2 gets a faster HTT ? )
But we will see :)
Originally Posted by Astennu
Would you please tell us where you got that release date?
so the at8 32x will be am2 and 16x lanes
Nope AT8 X32 will be the RD580 for S939. I head it from someone @ a other forum. he alst told us in december that there would be a nice thing at the 24e of januari. And that was the R580 release. The RD580 was also planned for Januari but somehow ATi did not make it.Quote:
I'm not 100% sure about that 24e Februari. But some of the boards are ready. And manny are waiting with a RD580 solution untill the AM2 will be out. So we can only wait hope and see it it will be the 24e.
Is anyone running this board with TCCD? I have some Corsair PC-4400 TCCD sticks that I can not get past 260 at 2.5-4-4-8 (2T of course :D). I had my BH-5 running at 265 with 3.6volts while the Booster was up and working.
Just need some help with the various memory settings, so that maybe I can at least get this TCCD to run at its rated speed (275).
Well I am just waiting on the at8 rd580 hope they fix the vcore issue
Here's what i've been running for a while, now running 4x512.Quote:
Originally Posted by Ad Rock
(sorry for the crappy pic, i had to resize)
LowRun, how high can you go with 4x512 on this board? 240 seems to be my maximum stable ceiling.Quote:
Originally Posted by LowRun
AFAIK :nono:Quote:
Abit RD580 = AT9
Its an Asus issue not a chipset issue. Current AT8 and DFi / MSI Express 200 motherboards do not have this issue.Quote:
The Asus RD580 clould have the same issue.
