azereus for the mac and utorrent on the pc, mininova & tpb
uTorrent FTW:up:. Honestly, I figured all the rest would have dried up by now. Azureus/Vuze? Bit Comet? Really?
uTorrent hands down, at one point I was into BitComet but now I'm not looking back, uTorrent ftw.
uTorrent concept is exactly what I like in a software, it does what it's supposed to do with no extra bling bling, keeping resource usage to the minimum, basicly you don't notice it's running.
All I've ever used is uTorrent; works fine for me.
got to echo everyone else, Utorrent FTW!
uTorrent domination.
Too bad. Azuerus was pretty good before it got bloated, then bought out.
rtorrent, hands down! Definitely the best torrent client for fastest speeds (on connections 10 megabits to 1 gigabit) probably not much different if you aren't on a fast connection.
I use bitlord kinda nice didnt like all the extra crap in vuze so maybe I'll try out utorrent.
utorrent but i have started to look at bitorrent is there any mind to change ?
uTorrent :D:up:
Deluge!
Bitcomet.
uTorrent
BitSpirit for sure
i love it:up:
definitely utorrent, low memory usage and very clean interface. azureus sucked up too much ram when i had a slow com in the past
vuze (azureus), utorrent is partly owned by the mpaa, if you use peerguardian youll see utorrent being blocked, azureus is heavy on the ram, but i got a server that runs it so i dont care
uTorrent.
U.TORRENT and demonoid.com iptorrents.com BOTH for downloading always clean awsome speeds :)
utorrent
azureus (vuze with old 2.xxx interface) on private trackers almost exclusively.
uTorrent here.
Vuze, but i miss ABC.
With ABC, when i added a torrent it would download as a normal P2P program would.
With Vuze, when i add a torrent it allocates that torrent's complete file size to my hard disk, and then starts downloading :down:
uTorrent on my main comp, Deluge on my server and lappy.
