I did not say that you OC sucks.
I said just what to expect from your cpu with the info you already gave.
well, here is my sempy. its based on palermo core which is just a venice core with disabled cache. so i think it belongs here.
SDA2800AIO3BX
LBBWE 0550BAJ
does 363x8=2902 SNM stable.
watercooled. on a dfi nf3.
28c idle, 38c load. average.
http://flytek.sa3doc.co.za/screens/air3g.jpg
http://flytek.sa3doc.co.za/screens/3gprime.JPG
ada3500daa4bw
cab2e0605fpmw
1422609b60025-t
25' ambient
That has to be the best 3500 I've seen in ages - 2006 vintage again. :banana3:
flytec can you post a 32M?
It will have a good time along with BH.
Which dividers are working?
An A64 tweaker will be helpful.
10x300 with uccc@166
approximate temps
36' idle 70mm fx55fan at 3200rpm
51' loaded fx55fan at 3300rpm
23' ambient
13 hours prime95
http://valid.x86-secret.com/show_oc?id=82795
benching now :)
flytek that's one sweet 3500, I thought my 3000 @ 2.7GHz was impressive. Opterons have really stole the limelight, that chip is awesome :toast:
very nice 3500+ man :)Quote:
Originally Posted by flytek
starostise just seen your 3000 in your signature using 1.6v. What idle and loads temps did you get with it? Mines running 2.7GHz on 1.5v but not sure I'd like to put 1.6v through it... I get idle of 29.C and loads of 41.C at the moment.
Load temps blow 50 is ok . So if oyur temps wont pass 50 C under 1.6v ur safe.
Even little over 50 C wont hurt.
I got myself a venice 3000+
it is the one in this picture
http://img132.imageshack.us/img132/6034/dsc015311ir.jpg
I thought 0520fpaw was good, but it just won't do 1m @2,8ghz 1,65v?
aircooled
Any tips?
it was just max screen for 3024MHzQuote:
Originally Posted by matt1
idle @ nearly 35°C idle and 46-47 @ full
it was prime stable 2.7GHz on 1.32v air, 2.8 1.40v and 2.85 1.45v. but it's dead now :(
check here:
http://membres.lycos.fr/starostise/LBBLE0517DPMW/
3000 Venice
LBBLE 0516GPAW
320x9 2880MHz @ 1.55
VLDT 1.3
VDIMM 2.9
XP90-C/TT 92mm
SilenX 600W PSU
http://img101.imageshack.us/img101/1719/2880air8oa.jpg
How does this stack up?
Gah, looking at all the posts above i feel like i'm going to cry.
0518APMW - 255x10 @ 1.55V - load temps are around 40C, i'd go higher but i've got a crappy motherboard. :P
NBBWE 0608 GPMW
2820 @ 1.5v 35c - This is 24/7 level. Rock steady at this setting, primes all nite, but more importantly, plays oblivion at max settings 1600*1200 for 16 hours straight on the weekend. (this game is gonna eat my life) --- I don't have a screenie of this setting but I included one of 2800@1.46v (I upped the voltage to guarantee stability and added 2 mhz on the FSB just to get even numbers with the dividers - not sure if that makes any difference tho)
http://img183.imageshack.us/img183/7...t1461vv.th.jpg
3000 @ 1.7v - 32m prime stable, can't say if it could withstand anything else. There's no way I was gonna run this voltage for hours to test stability/load temps. Hitting 3.0 GHz was like an obsession to me. It ate me up inside until I could think of nothing else. Strangely though, once I hit that magic number I realized how meaningless it is and I will never run that high again with this chip.
http://img183.imageshack.us/img183/3...pi329qp.th.jpg
Overall Impression -- In a word, WOW. I prefer this chip over my old opty 165. My opty was not the best stepping. It would do 2.6GHz 24/7, but was quite hot and did not run oblivion as well as the venice. Many people rave about the quickness and multi-tasking of the dual-cores but for me, it's a non-issue. I have so many computers lying around that I have one setup for each task. I just moved so my network is completely down (except oblivion - that was priority :D) but my previous setup was one file server that holds my mp3s and movies, One HTPC for the stereo and TV, and one for intensive, time-consuming tasks (burning, decoding etc,) -- why bother with two cores when you can have 2 (or more) whole computers?
barmanmyk where did get that theme its cool
- MB : A8N-SLI Deluxe
- CPU : A64 3000+ @ 2600mhz (LBBLE 0545XPMW) @ 1.45v running at 32c idle and 34c stressed (Arctic cooling 64 pro)
- RAM : G.Skill ddr400 @ 238mhz 2.5-3-3-6
- GFX : 6600gt SLI setup
Ran 32m SuperPI last night, passed without any problems. Ran 3DMark 01/03 got 22000/16235 points.
3DMark 03 URL: http://service.futuremark.com/compare?2k3=4758786
CPUZ @ 2700mhz: http://valid.x86-secret.com/show_oc.php?id=89432
CPUZ @ 2600mhz: http://valid.x86-secret.com/show_oc.php?id=89547
Lowered the speed a bit for daily use so i won't have to use more VCore.
- Schmetterling
LBBLE 0520 (forgot packing code) 3200+
Doing 2550 @ stock voltage, dont know how this stacks up, and Im only using it for 1 day, but I thought I'd post some results, still working my way up to find it's limits, which seem to be high!
looks like my limit is ~2575 @ stok voltage, how are Venices doin these days?
Got another 3000+ today, stepping: LBBWE 0611DAG gonna do some testing tonight will keep you guys posted.
- Schmetterling
DAG? That must be a Chinese (assembly) one, only ever seen it with s754 Venices.Quote:
Originally Posted by Schmetterling
Indeed, it says 'assembled in China'. Will make a picture of my two cpu's before i mount my DAG.Quote:
Originally Posted by stone_cold_Jimi
- EDIT:
CPUZ Validation for 'LBBLE 0545XPMW'
CPUZ Validation for 'LBBWE 0611DAG'
CPUZ Validation for 'LBBWE 0611DAJ'
Just installed the DAG in my a8n-sli deluxe and booted to windows without any problems. Ran SuperPI 1.5 / XS and got 33.687/1m on 2600mhz (289 * 9). Will keep you guys posted.
Upped the HTT to 300mhz, running 300 * 9 now but it seems i need 1.55v to run on this ... ran SuperPI again and got 32.907 so it already improved a bit ... too bad that my G.Skill mem won't do more then 238mhz :( will have a look and see how far i can push this cpu today.
Seems that it will max out between 290/300mhz HTT, for some reason i don't think that the CPU's are causing this as the CPU's are totaly different but do about the same speed. I think my Asus a8n-sli is a piece of crap which is bugging me lol ... time to save some money and go for a DFI and some OCZ mem with TCCD or BH5 :)
- EDIT:
Both the CPU's run stable at 289 * 9 @ 1.45v (I use this so i can use the my ram as 333 so i runs at ~236mhz)
The TCaseMax for both:
'LBBLE 0545XPMW' = 57c
'LBBWE 0611DAG' = 53c
'LBBWE 0611DAJ' = 53c
- EDIT:
Got another one in my hands today (LBBWE 0611DAJ) for a customer of me but it's exactly the same as the DAG. As i promissed here's a picture of the DAG (The DAJ is the same just 1 letter changed)
http://img55.imageshack.us/img55/7963/0611dag8be.th.jpg
All three hit 2600mhz rock solid but until now only the 0545 is known to hit 2700 rock solid aswell. Pushed my memory up to 250mhz yesterday @ 3v with the 0545 running at 2745mhz and hit the 30.812s on SuperPI. Atm i'm waiting for my DFI Expert to come in so i can tweak the mem/cpu a bit more and hopefully hit the 17000 in 3dmark 03 with 2 6600gt's in SLI. (Got until 16867 now)
- Schmetterling
Anybody here reach 2.8-3.0+ Ghz for DH-E6?
Pls help me squeeze more juice out of my DH-E6 please...
Thanks a Alot, my comes with my Sig...
