Ive attached it to this post so everyone should be able to see it now.
G
G
congrats nubius! i remember the time when u all you could say about ur liquid cooling setup was how it sucks so bad. look MUCH better now, congrats again. :woot:
lol yeah, well just look at the difference, bigwater was chumpstyle, now I got 1/2" tubing going on with a good pump and good blocks.
Temps were hitting 50C when folding with 1.875Vcore at 2.5GHz, now Im running 1.925Vcore with 2.6GHz and it's hitting 45C during the hottest part of the day :D Normally it'd be hitting probably 55C or so with the tornado at full blast.
GPU Idle WAS 70C and load was 84C
now it's 47C idle and 51C load :D
I like that....4C different between idle and load...yummy :D
Now that it's up and running I gotta get pics of it without the paper towel :P not only that, but man I gotta add more dye lol, so it doesn't look so damn pink.
looks kind of neat but I'm not a believer in 'passive' anything :p
Guess technically water cooling without being chilled can be considered passive in a sense though
It looks aluminum. No thanks.
Convection only works if you have some serious surface area, and for anything more than a chipset that little passive rad wouldn't cut it. :rolleyes:
And then of course, it's aluminum...so you'd have the whole corrosion thing coming into play sooner or later. Another thoughtless, flow killing, unpractical product from innovatek.
My comp with WC
love your fans on the top. btw, welcome to XS :woot: :toast:
my comp 2 with WC
Aight .... this is the final setup for this puter... it was WIP for a few weeks while waiting for the Maze4 Acetal Gpu block.. came a few days ago and this is it. Gonna skip the NB block since it will serve no purpose on Amd64 setup. Enjoy !!
FYI.. Cpu idles/loads at 27/34C and X800 XT PE idles/loads at 32/43C.
http://img.photobucket.com/albums/v3...4/IMG_2990.jpg
http://img.photobucket.com/albums/v3.../A64/close.jpg
http://img.photobucket.com/albums/v3...64/farther.jpg
It's my WC; simple and efficiently :)
http://members.lycos.co.uk/ckukla/wc/caloscs.jpg
http://members.lycos.co.uk/ckukla/wc/bloczeks.jpg
http://members.lycos.co.uk/ckukla/wc/calosctyls.jpg
Interesting pump, do you have any specs?Quote:
Originally Posted by Pc juice
/Thomas
Yes, it's Laing S1-15/700 B
Spec:
http://www.laing.de/10Produkte/40Pum...pumpen/pdf.pdf
Here's the beginning of my setup: ( I don't want to hear anything about the wiring, it's getting fixed. Or for that matter the ghetto cardboard. ) :)
http://www.thepengellys.com/stuff/Wa...g/DSCN2100.JPG
This is my w/c
Decided to put a server together and had some extra watercooling parts so I thought, might as well put them to use. Still missing RAM, but the loop is done and running fine.
OK, first I want to apologize in advance because I do not own, nor am I proficient in the use of, a digital camera. Some of the pictures are sideways which sucks, I wish I could flip them around but I am too lazy. Everything is in 1600x1200 so major 56k warning (for those not Xtreme enough for broadband). Also all of the pictures are incredibly blurry when viewed full size, so you are probably better off just looking at the thumbnails. Damn I wish I had good pictures. Whatever, enjoy!
http://img150.echo.cx/img150/434/kif24512gx.th.jpg
http://img150.echo.cx/img150/6580/kif24526ls.th.jpg
http://img180.echo.cx/img180/4396/kif24532gb.th.jpg
http://img180.echo.cx/img180/9899/kif24541sb.th.jpg
http://img180.echo.cx/img180/5372/kif24556cp.th.jpg
wow zach i am speechless :D awesome case! that's my swify block i sold you!! i'm glad it's going to a good cause :)
thx man!
What case is that zeebs?
Silverstone Temjin TJ-03 in black. It is the same one falcon northwest uses on the Mach V. It is just like a huge Praetorian/Wavemaster on the inside.
EDIT: Water loop specs
Swiftech 6002
Danger Den Maze 4 Acetal GPU
Aquaextreme 50z pump
Black Ice Pro 3
HDPE reservoir
Panaflow fans on everything
I absolutely love the look of those, its my new favorite looking case. You could fit a triple 120mm radiator at the top? Could you measure clearance on the bottom more me? Width between drive cage and distance from case floor to third pci slot on your mobo?
(edt: also, what panaflos and is it quiet overall?)
Overall it is very quiet with all the fans running on low, silence was a priority with this case. The BIP3 fit only because I was using a smaller PSU, the PC Power and Cooling Turbocool 510 express. A deeper PSU like the OCZ powerstream would not leave enough room for the BIP3 to fit. I will try to take better pics or get someone to come over who can. Also I am a little confused by your measurement requests aside from the "3rd PCI slot from the bottom one" PM with details of what you want and I will measure for you.Quote:
Originally Posted by EnJoY
PM Sent! Thanks. What fans btw? L1A's?
M1A's on everything. I like the M1A's because they are decently quiet but still spin fast enough so that undervolting is effective.
