Morpeus Remix Extreme video driverset
seems can't find it :(
I hope this is what you're looking forQuote:
Originally Posted by TEDY
All Morpheus driver :
http://www.envynews.com/index.php?ID=626
that's it thanks :>
Sorry if its a little bit late...
I try 1/21 and 1/31 BIOS....
1/21 BIOS do prime95 for 11seconds
1/31 BIOS do prime95 for 2minutes and more (I stopped it since it longer than the 1/21)
I heard that 1/21 use 133Mhz ROM sip table?..how this is possible...does the use of BIOS is very dependent on hardware too???
what's the next update BIOS which use the "exact" same as 1/31 ROMSIP table?
btw for testing I use this spec :
Barton Mobile 2600+ (250x8) at 1,65v (btw at 1,65v its prime stable at 2,4Ghz,so proc won't be the problem)
Corsair PC3500 2x256 BH5@250Mhz@3,3v
Vdd@1,9v
memory timing 2-2-2-11-12-15
what's difference between 6/19 and Hellfire's Rev#3 ?
Many code optimizations... and performance-stability-modded romsip tables :DQuote:
It's the best one for me. I dunno, he may have changed the sata bios, too.
Hello Guys, sorry for the OT... someone knows if ocz ddrbooster work on dfi infinity?
Thanks ;)
No, it won't. The booster works using the 3.3V rail, the DFI NF2U400 boards (Inf./LP B) use the 5V rail.Quote:
Originally Posted by Remixes
Thanks SAE, you are clearly as always ;)
Compliment for you 30' second in superpi with A32... in these month we will try to get the same result but...12,5X264 is too difficult to keep :D
See you soon
It runs from the 5/12 rails SAE.
So???? You 're saing that ddrbooster can works on dfi?
dual channel works properly?
Have you try it?
Sorry for the many question but I've just killed one more mainbord :D
nope it doesnt work on DFI NF/INF as SAE said...just do vdimm mod on mobo to boost vdimm to 3.6vdimm LOL
I'm a dreamer :D
Thx Guys ;)
Heard about those mixed drivers, but do they ready make any difference, compared to official NVidia ones? Which do you use SAE ? I've always used the officials, since they are constantly updated and never had any trouble with them...
PS: Now testing @ 255x10.5 @ 2.0v... gotta do vdimm mod & vcore mod to see what can I get from this sucker :D
Thanks. Good luck catching me :DQuote:
Hehe, that's equal ;)Quote:
Originally Posted by STEvil
I meant, it only works with boards using the 3.3V rail for vdimm... :D
Yeah, the ones powered from +5 dont like the feedback I guess.
Could disconnect the power supply to the mosfets and they'd work fine I bet... but dont take my word on this ;)
I am still using the rmx 3.30 extreme without the hdd driver... but with my internet rig I am using the 5.15 package official with ide driver without major probs ;)
Hehe.... guys, don't take this guy seriously ;) :p:Quote:
lol ;)
Where i can find this remix driver forn nf2?Quote:
Originally Posted by SAE
I've always used 2.03 fors system bench and 5.15 for sytem "all days" :D :)
what?? :rolleyes: ...you could still at least see this page first...I gave tedy the link to all morpheus remix, and it still on this page :wave:Quote:
Sorry Massive :( , now I 've find all I need
Driver, alpha timing setting, mainboard mod and bios ("Hellfire Bios for Infinity Rev#3").
Thx :)
My Infinity runs Prime95 @ 260MHz 1h+, but over 260 it just goes unstable. SP 1M runs sometimes 266MHz, but 8M not even 264MHz.
I dont'n think my mem (Memtest @ 264MHz 1h+ @ 5-2-2-2, SP 1M @ 274MHz) is limiting FSB.
AXP-M 2500+, L12 mod, Vdd 2.01V (stock sink + 80mm fan), Vdimm 3.6-3.7V @ 11-2-2-2-2-9-12 e-e-f-e 1-3-3-3-3-3-4, Hellfire 1/21 RS rev#3 bios, ACPI enabled
:confused:
No, that's the board limiting ya! As mine is limiting me... ;)Quote:
Originally Posted by Electroid
And if you also noticed the errors in memtest at 266 dualchannel (only a few - but still there), at singlechannel you can increase the clocks alot higher till error appear. NB is maxed, board design is maxed, vregulation is maxed... it's just not made for clocks like ours :D
damn...such a board you got there...I wish mine could do the same too :rolleyes: ....Quote:
I'm curious...you're using Kingston PC2700...did it get very hot using it on that voltage?
have you other BIOS?...maybe it BIOS related too?
and SAE, how did you know that its mobo limited not ram limited?
I think thats the pc3000 or pc3200. CPU-z just doesnt recognize that ram correctlyQuote:
Originally Posted by Massive
