Originally Posted by Rodzilla
Ther is no problem at all, the wire resistance is pretty small, and no componentes betwenn them to increse the current delay.
Sweet! Thanks! :up:Quote:
Originally Posted by Barr3l Rid3r
Which cap is the best for IC7-MAX3? Is it ok 2200uF 6.3v...
LP
the link to hipro5's IC7 etc modding MASTERPIECE is down :eek: , anyone know if and when it will be fixed :confused:
Looks fine to me...
If the caps are black (or dark purple) with gold writting then use these.Quote:
Originally Posted by LitleDevil
Motherboard Caps Capacitor 10mm 2200uf 6.3v UltraLowESR
i have just tried again (about the 15th time in the last two days) and still nothing :cussing:Quote:
Originally Posted by alpha0ne
I just tried again... :confused: I can see it just fine... It's got to be your ISP...
got it this afternoon after days of trying :banana: :toast: , at one point i thought that a worldly treasure had been lost to me, i will now guard it with my life :DQuote:
Does anyone have mooded bios 18 for IC7-MAX3?
tnx
I have it some where,give me a hour or so and ill post a dl link for the 3 moded bioses i have for the max3
Does anyone have clear pictures of VAGP and VTT mod on IC7-MAX3, can you post it please or can you draw on my picture.
http://www.slo-volt-mod.com/slike/MA...d/IMG_0080.jpg
http://www.slo-volt-mod.com/slike/MA...d/IMG_0076.jpg
I done two mods for now.
http://www.slo-volt-mod.com/slike/MA...d/IMG_0034.jpg
http://www.slo-volt-mod.com/slike/MA...d/IMG_0001.jpg
http://www.slo-volt-mod.com/slike/MA...d/IMG_0002.jpg
BB mods's do you have BIOS?
tnx all :)
Moded max 3 bios(s) Happy OC'ing ;)
Is that what ya wanted?
Yes it's OK :) I get 18 modded bios :)
Does anyone have cleare picture of VCORE and VAGP mod?
thanks
http://snt-systems.com/forum/showthread.php?t=75
http://www.snt-systems.com/tommy/max3/max3mod2.jpg Vcore is Yellow and Black, Red& red is V drop
Let me dig my pic's out and ill post pic's of the Vagp.
has anybody experiences with vAGP set to 1,9V and GF6800 Series?
I'm trying to perform mod 1: "Electrolytic Cap" mod. I went to radioshack, and they only had a "non-polarized" cap; that means for the mod, I can hook up either end to either side right?
Also the instructions said: "high internal resistance"... the box mades no mention of that... here's the cap:
272-997 RadioShack
2.2 uF Electrolytic Capacitor
Non-Polarized
For speaker crossover: 8kHz at 8 ohms
50V maximum
Axial Leads
Operating Temp: -40* to 185*F (-40* to 85*C)
Tol: +/- 20%
Thanks for the help guys
Edit --
PS -- I just DL'd and flashed BB Mod's modded BIOS. What are the x1,x2,x3,x4 settings that appeared in the list with the AGP voltages?
Thanks again!
Radio Shack will not have any caps the quality you will need. The "high internal resistance" he speaks of are "LOW ESR" or "Ultra LOW ESR" caps. Usually marked with gold writing. The reason for this is the short rise times and superior ripple handling. A poor cap in this position will actually lower performance or damage the MB. Look for Rubycon or Nichicon brand.
what doese the moded biose giv extra ?Quote:
Originally Posted by BB mods's
yeah what does the modded bios do?
the moded bioses open up a few features,changed setting's and stuff like that.I have tested all of them and they all work great.
Hi! Have just finished the VDDR and VTT mod. Started the system and with the VDDR set to 2.5 V in BIOS adjusted the VDDR to 2.92 V real V, set the VTT to 1.46. Voltages stabel and no problems. Upped the volts to 2.55 V in BIOS and rebooted. Now VDDR are down to 2.8V and VTT to 1.41 V !!!! :confused:
Tried to increase the voltage step by step and volts do come up. Set VDDR to 2.5 V in BIOS again and adjusted VDDR to 2.91 V real. Rebooted and this time it holds and upping volts makes VDDR increase as it should. :(
What was the strange behavior the first time I increased voltages in BIOS???? :rolleyes: Had rebooted a couple of times before the first time I increased VDDR in BIOS, VDDR stable at 2.92 V. So why volt droop, may I have damaged something????
Buy the way, thanks HIPRO5 for all the mods. Done the VAGP and electrolytic cap and they both work great! :toast:
http://www.snt-systems.com/tommy/pics/ocd2.jpg got that on water with my moded max3,all is well in the land of 4+ ghz celeron d's! (btw ill be making a nother oc with this chip as soon as my cascade is done :) )
