Can Infrnl hold off the host with no name?
HMMM..Getting there! :D
Attachment 130476
Will hold off updating until the gpu dust settles. Looks like the 5000 point minimum may have to be increased to 50000+ :eek:
ya this will be interesting. a 990x with no gpu could be outclassed by a q6600 running 4 7990s :O
Do I have to add GPU manually or will that info be taken from the stat sites when you update?
Latest SC week stats added :yepp:
So, shall we resurrect this thread?
You already did... Necromancer
I am not sure about the "WE" bit but you might consider asking Sam nicely.
Not sure either how much work went into this so don't be offended if he declines ;)
No plans to revive this at present :shakes:
i'll look into it and if i can somehow automate this stuff
well i can see why you stopped updating this
that 300M xml file is not fun at all :mad:
Alpha version
should have every host over 5k+ that is not hidden and belongs to XS
still have a lot to do but it should be working now
http://goo.gl/Ze6RLe
Looking good.
You have been getting some sweet numbers from that 8 core
thanks, it's 4 core actually, boinc has a really weird(inconsistent) way to report cores/threads
Nicely done :up:
Thanks. :up:
And I see I need to get my points up a little. I had slowed my 2600k a little to save some energie, but got it back up to 4500 MHz. Should be good to get back onto the list.
also how to find out your host id
on linux
(/var/lib/boinc-client is where your boinc configs areCode:egrep -i 'project_name|hostid' /var/lib/boinc-client/client_state.xml
on windows open c:\program data\BOINC\client_state.xml
use ctrl+f to find World community grid
then ctrl + f hostid
boinc tasks:
go to projects tab
right click world community grid -> properties
find the part where it says computer id
Hahahahahhaaa...
My oldtimer in top 20. In team XS :D
You guys....work harder.
