That ram should run 1866 8-8-8-24 easy Panther.
Otherwise for the CPU bit why would it matter? Changing the frequency to 4.3 is as easy as bumping the multiplier and voltage a little. (Provided the CPU is capable)
I am just testing it atm
The chip /boards seems a bit finicky now especially with the NB as I have it at 3Ghz at 1.3
I will have to try tomorrow to see if i can get 1866 cas 8
Will I see any real differences going to that from cas 7 1600?
Does anyone know why Asus doesn't include caching in their raid rom??
in last BIOS is issue with HT link at auto (for FX)...Only 2200 MHz than right 2600 MHz, so a bit lower performance :(, or u must manually change it :)
Is it normal, that the SB850 has worse performance than the intel P55? I noticed slightly longer boot times with my new Crosshair IV Formula, compared to my "old" P55-GD65...also the performance-score is lower than on the intel?
You need to be more specific as to how you loaded your chipset drivers if you need some help. There should be no practical difference in speeds. Need to know your motherboard #s, too.
And the title does say "ASUS - Official AMD 9xx Chipset Series Motherboard Support"
From my limited knowledge and experience, for best operation you should F6-load the AMD sata.inf with your BIOS set to 'AHCI'
I have a Crosshair IV Formula, running Win7 x64. The controller is in RAID-mode, installed the driver with F6-method from USB-memory during Windows-setup.
How about a CHIVF Bios!!!!
WTF? Not looking to jump ship, CHIVF is totally capable of running BD...4.8GHz for me day to day, but the rest is bull-ish! Lets get some real going!
Unfortunately noone from Asus cares anymore. It just need fix for turbo mode, cores control (on/off) and probably higher mem dividers.
The board even clocks memory fine, but seems we won't get the desired update.
PS: Oh, TurboEVO won't be updated as well.
:D
Crosshair Formula V
ftp://ftp.asus.com.tw/pub/asus/mb/So...-ASUS-1402.zip
New Sabertooth bios:
ftp://ftp.asus.com.tw/pub/ASUS/mb/So...-ASUS-1208.zip
C5F+GSkill over 2400 MHz
http://www.xtremesystems.org/forums/...13#post5106813
New M5A99x EVO bios:
http:
http://dlcdnet.asus.com/pub/ASUS/mb/...-ASUS-1208.zip
ftp:
Seems every 9xx board has got the 1208 build?
Guys, what about Asus Crosshair V Formula-Z ?:up:
+Thunderbolt
+post display
+better VRM and OC
+new integrated soundcard with LED red line (as Maximus V series)
-maybe BIOS flashback utility
Attachment 127448
Attachment 127449
http://vr-zone.com/articles/asus-s-a...rt-/16207.html
Need bios update for original Sabertooth 990FX board. Only the R2.0 got an update :(
+1 for that sabertooth update.
need croshair V version one bios update
Are you serious? Does that mean all Asus AM3+ motherboards that are not "R2.0" will not get an update to support Piledriver?
i just looked for crosshair V original NOTHING but crosshair V formula Z cpu is listed
UEFI builds with Vishera support are already posted for V1 990FX boards. 1605 or 1503 (depends on board model).
looks, AMD life will be again back this year here...FX Vishera is much better than old one.
Found it posted today - go to Asus's global site - don't know if this link will work or not.
http://www.asus.com/Motherboards/AMD...90FX/#download
Bios 1604 out now for Sabertooth 990FX R1.0:
http://support.asus.com/download.asp...GanpgqHG8yN8yQ
But as Raja so graciously pointed out, the 1503 bios also supports it :)
